//这是测试sdram的代码
  static volatile unsigned short *g_pusEPISdram[1];
  g_pusEPISdram[0] = (unsigned short *)0x60000000;
  g_pusEPISdram[0][0]=0x1234;
  g_pusEPISdram[0][1]=0x5678;
  unsigned short int Temp45=0,Temp46=0;
  for(unsigned long k=0;k<0x3fffff;k++)
    g_pusEPISdram[0][k]=0x1234;
    Temp46=g_pusEPISdram[0][k];
    if(Temp46!=0x1234)
      Temp45=Temp46;
    Temp46=0;
	for(unsigned int j=0;j<NETFIFOLENGTH;j++)
      {unsigned char tt=0,tt1;
  memset((unsigned char *)(GetFiFoOfNet[0].GetEthArrary[j]),j,MAX_RX_PACKET);
                //test
                memcpy(TempRx_ETH_PacketA,GetFiFoOfNet[0].GetEthArrary[j],MAX_RX_PACKET);
                for(unsigned long k=0;k<MAX_RX_PACKET;k++)
                  tt=GetFiFoOfNet[0].GetEthArrary[j][k];
                  if(tt!=j)
                    tt1=0;
                memset(GetFiFoOfNet[1].GetEthArrary[j],j,MAX_RX_PACKET);
                //test
                  tt=GetFiFoOfNet[1].GetEthArrary[j][k];
                  if(tt!=j)
                    tt1=0;
                memset(TempRx_ETH_PacketA,254,MAX_RX_PACKET);
                memcpy((unsigned char *)(GetFiFoOfNet[0].GetEthArrary[j]),TempRx_ETH_PacketA,MAX_RX_PACKET);
                memcpy((unsigned char *)(GetFiFoOfNet[1].GetEthArrary[j]),TempRx_ETH_PacketA,MAX_RX_PACKET);
                  tt=0;
                  if(tt!=254)
                    tt1=0;
                  tt=0;
                  if(tt!=254)
                    tt1=0;
