电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » msp43018B20
msp43018B20
2014-10-05 20:20:59     打赏
#include <GLOBAL.h>
#include <stdlib.h>
#include <stdbool.h>
#include <msp430f4371.h>
#define SdaDirOut          P6OUT &= ~BIT6//---弱拉输出
#define SdaDirIns          P6DIR &=~ BIT6//---弱拉输入
#define SdaLow             P6DIR |=  BIT6//---被动低
#define SdaHig             P6DIR &=~ BIT6//---被动高
#define SdaInSt            P6IN  &   BIT6//---
#define SdaDirOut          P6DIR |=  BIT6//---强拉输出
#define SdaDirIns          P6DIR &=~ BIT6//---强拉输入
#define SdaHig             P6OUT |=  BIT6//---输出高
#define SdaLow             P6OUT &=~ BIT6//---输出低
void InitRTC(void)
    SCFQCTL=SCFQ_2M;//---------------------时钟为2M
    FLL_CTL0 |= XCAP10PF;
    WDTCTL=WDT_ADLY_1000;//---工作于定时状态
    IE1=WDTIE;//---使能看门狗定时中断;
void DelayTempa(unsigned int Time)
    unsigned char i,j;
    i=Time;
    j=Time;
    _NOP();
    while(i--);
    _NOP();
    while(j--);
    _NOP();
void TempaInit(void)
    SdaDirOut;
    SdaHig;
unsigned char ChkTempaChip(void)
    unsigned char Chip;
    SdaDirOut;
    SdaHig;
    DelayTempa(10);
    SdaLow;
    DelayTempa(480);//---等待480微秒
    SdaHig;
    SdaDirIns;
    DelayTempa(10);
    if(P6IN  &   BIT6)
        Chip=0xff;
    else
        Chip=0x00;
    SdaDirOut;
    SdaHig;
    DelayTempa(10);//---等待480微秒
    return Chip;
//-----***-从slave端读取一个数据-***-----//
unsigned char ReadByte(void)
 unsigned char i;
 unsigned char ByteData=0;
        SdaDirOut;
        SdaLow;
 for(i=0;i<8;i++)
            SdaDirOut;
            SdaLow;
            ByteData>>=1;
            SdaHig;
            SdaDirIns;
            if(P6IN  &   BIT6)
                    ByteData |=0x80;
            DelayTempa(5);
            SdaDirOut;
            DelayTempa(25);
 return ByteData;
//-----***-传送一个 Byte 数据到 slave-***-----//
void WriteByte(unsigned char DataByte)
    unsigned char i;
    SdaDirOut;
    for(i=0;i<8;i++)
        SdaLow;
        if(DataByte & 0x01)
         SdaHig;//IicSda=1;
        else
            SdaLow;
     DelayTempa(30);
        SdaHig;
        DataByte >>=1;
    DelayTempa(10);
void ReadTempa(unsigned char *RecData)
    *(RecData)=0;
    *(RecData+1)=0;
    if(ChkTempaChip()==0x00)
        WriteByte(0xCC);
        WriteByte(0x44);
        DelayTempa(3000);
        WriteByte(0xCC);
        WriteByte(0xBE);
        *(RecData)=ReadByte();
        *(RecData+1)=ReadByte();
void TempPack(void)
    if(SecondsConn&0x40)//---秒使能控制
        _DINT();
        TempaData=0;
        ReadTempa((unsigned char*)&TempaData);
        TempaData=TempaData*625;
        TempaData=TempaData/100;
        _EINT();
        SecondsConn&=0xbf;
int main(void)
 InitRTC();
 TempaInit();
 for(;;)
  TempPack();
#pragma vector=WDT_VECTOR
__interrupt void WDT_Delay(void)
    SecondsConn=0xff;
    LPM3_EXIT;
