又case到30了
能优化一下结和数据定义构不,童鞋
本次作业没能按照老师的要求完成,数码管只能显示0~9,想要在数码管显示两位数时,十位数正确,个位数显示错误,一直都是显示8,比如当输入“data=29”时数码管显示的是 28 。
先贴代码,请大神们指教。
我不懂字符串转整型,是套用熙熙的……#include "stm32f10x.h" #include "stm32_eval.h" #include "stdio.h" #include "math.h" #define buff_size 16; char rx_buff[], rx_buff_count=0; GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; uint16_t Dis_tab[]={GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8,//0 GPIO_Pin_9|GPIO_Pin_12,//1 GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5,//2 GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5,//3 GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5,//4 GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5,//5 GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5,//6 GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12,//7 GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14,//8 GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14//9 }; void RCC_Configuration(void) { RCC_DeInit(); RCC_HSICmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); RCC_HSEConfig(RCC_HSE_OFF); RCC_LSEConfig(RCC_LSE_OFF); RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); RCC_ADCCLKConfig(RCC_PCLK2_Div4); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器 } void GPIO_INIT() { //GPIOB(数码管)初始化 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能PB时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15; //PC1--PC15 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化PB } void USART_int(long BaudRate) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA USART1 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//TX位于PA9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure);//TX初始化 PA9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//RX位于PA10 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//悬空输入 GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化 PA10 /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate;//传输速率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8比特 USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1 USART_InitStructure.USART_Parity = USART_Parity_No;// USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//流控位none USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收和发送模式 USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟 USART_Init(USART1, &USART_InitStructure);//初始化USART1 USART_Cmd(USART1, ENABLE); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); /* Configure four bit for preemption priority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//优先级 /* Enable the USART1 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择USART1中断通道 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure);//初始化中断 } /*delay_us*/ void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } /*delay_ms*/ void delay_ms(u32 n) { while(n--) delay_us(1000); } void USART_SendStr(char *str)//发送字符串 { while((*str)!='\0')//到字符串的末尾才停止发送数据 { USART_SendData(USART1,*str++); while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); } } unsigned int translate(char *S,char j)//将字符串组成的数字转换成整型数据 { unsigned int a[2],i=0; char c; for(c=0;c<j;c++) { a[c]=S[5+j-1-c]-48;//将字符转成整型数据 i=a[c]*pow(10,c);//按照每一位的权值相乘再相加,还原data=n的本来面貌 } return i;//i保存目标整型数据 } void func(char *S,char LEN) { char count;// 计数函数 unsigned int i,c,j,k; if((LEN!=6)&(LEN!=7))//data=0~99 {USART_SendStr("\r\n Erro input!!!\r\n");}//如果输入格式错误,发送提示 else { count=LEN-5;//从“=”后面开始是目标数据 i = translate(S,count);//count记录“=”后有多少位,传递到translate中 GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); //关闭数码管 switch(LEN){ case 6 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,Dis_tab[i%10]); GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off delay_ms(80); break; case 7 : GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on GPIO_ResetBits(GPIOB,Dis_tab[i/10]); delay_ms(20); GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off GPIO_ResetBits(GPIOB,Dis_tab[i/10]); delay_ms(2); GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1 on GPIO_ResetBits(GPIOB,Dis_tab[i%10]); delay_ms(20); GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off GPIO_SetBits(GPIOB,Dis_tab[i%10]); //off delay_ms(2); break; } } } void input_ASK() { char j; func(rx_buff,rx_buff_count); rx_buff_count=0; for (j=0;j<rx_buff_count;j++) {rx_buff[j]='\0';}//判断读入信息是否结束,如果结束则准备下一次读入 USART_SendStr("\n>"); } int main(void) { RCC_Configuration(); GPIO_INIT(); USART_int(9600); USART_SendStr("SyStem booting......\r\n");// USART_SendStr("\n>");// while(1) {} } void USART1_IRQHandler(void) { while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET) { } if(USART_ReceiveData(USART1)==0x0d)//如果输入完毕,按下了回车 {input_ASK();} else { USART_SendData(USART1,USART_ReceiveData(USART1)); rx_buff[rx_buff_count]= USART_ReceiveData(USART1); rx_buff_count++; } USART_ClearFlag(USART1, USART_FLAG_RXNE); }
可能是因为我强行套用才会出现错误吧……![]()
char c;
for(c=0;c<j;c++)
在显示两位数时,是case7,我觉得这部分代码大体是正确的,不过闪现应该就是延时不对吧……大神们,求不鄙视……
case 7 :
delay_ms(20);
delay_ms(2);
delay_ms(20);
delay_ms(2);
break;
接下来,我只能交作业了,头脑一片混乱,想不出来办法了 ,求指教
/* Includes ------------------------------------------------------------------*/
#include
EXTI_InitTypeDef EXTI_InitStructure;
/* Private function prototypes -----------------------------------------------*/
void EXTIkeyS1_Config(void);
void EXTIkeyS2_Config(void);
void EXTIkeyS3_Config(void);
void EXTIkeyS4_Config(void);
RCC_DeInit();
RCC_HSICmd(ENABLE);
RCC_PLLCmd(ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
/* PA10 USART1_Rx */
- One Stop Bit
- No parity
USART_InitStructure.USART_BaudRate = BaudRate;//??????
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
USART_InitStructure.USART_Parity = USART_Parity_No;//????
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
int main(void)
{RCC_Configuration();
/* Configure PA.00 in interrupt mode */
EXTIkeyS1_Config();
/* Configure PB.09 or PG.08 in interrupt mode */
EXTIkeyS2_Config();
EXTIkeyS3_Config();
EXTIkeyS4_Config();
USART_int(115200);
printf(" Config done,waiting for interrupt......\r\n");
while (1)
* @brief Configure PA.00 in interrupt mode
* @param None
* @retval None
/* Enable GPIOA clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能时钟区
/* Configure PA.00 pin as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_Init(GPIOA, &GPIO_InitStructure);//使用PA8
/* Enable AFIO clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
/* Connect EXTI0 Line to PA.00 pin */
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8); //GPIOC.8 中断线以及中断初始化配置 下降沿触发
/* Configure EXTI0 line */
EXTI_InitStructure.EXTI_Line = EXTI_Line8;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure); //根据指定的参数初始化中断线的参数
/* Enable and set EXTI0 Interrupt to the lowest priority */
NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;//使能按键所在的外部中断通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;//抢占优先级15
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;//子优先级15
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//使能外部中断通道
* @brief Configure PB.09 or PG.08 in interrupt mode
* @param None
* @retval None
/* Enable GPIOB clock */
/* Configure PB.09 pin as input floating */
/* Connect EXTI9 Line to PB.09 pin */
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource9);// GPIOC.9 中断线以及中断初始化配置 下降沿触发
/* Configure EXTI9 line */
EXTI_InitStructure.EXTI_Line = EXTI_Line9;
/* Enable and set EXTI9_5 Interrupt to the lowest priority */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource10); //GPIOC.10 中断线以及中断初始化配置 下降沿触发
EXTI_InitStructure.EXTI_Line = EXTI_Line10;
NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;//使能按键所在的外部中断通道
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource11); //GPIOC.11 中断线以及中断初始化配置 下降沿触发
EXTI_InitStructure.EXTI_Line = EXTI_Line11;
void EXTI9_5_IRQHandler(void)
if(EXTI_GetITStatus(EXTI_Line9) != RESET)
/* Toggle LED2 */
GPIO_SetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
printf("S2 interrupt ......\r\n");
/* Clear the EXTI line 9 pending bit */
EXTI_ClearITPendingBit(EXTI_Line9);
if(EXTI_GetITStatus(EXTI_Line8) != RESET)
/* Toggle LED1 */
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
printf("S1 interrupt ......\r\n");
/* Clear the EXTI line 0 pending bit */
EXTI_ClearITPendingBit(EXTI_Line8);
void EXTI15_10_IRQHandler(void)
if(EXTI_GetITStatus(EXTI_Line10) != RESET)
/* Toggle LED2 */
GPIO_ResetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
printf("S3 interrupt ......\r\n");
EXTI_ClearITPendingBit(EXTI_Line10);
if(EXTI_GetITStatus(EXTI_Line11) != RESET)
/* Toggle LED1 */
GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
printf("S4 interrupt ......\r\n");
EXTI_ClearITPendingBit(EXTI_Line11);
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the USART */
USART_SendData(EVAL_COM1, (uint8_t) ch);
/* Loop until the end of transmission */
while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
return ch;
/* Infinite loop */
while (1)
#endif
| 为遥控小车巧添功能被打赏¥26元 | |
