#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
volatile int flag;
//板子已将PC12脚接到18B20
#define Set_B20() GPIO_SetBits(GPIOC, GPIO_Pin_12) //关上PC12
#define Reset_B20() GPIO_ResetBits(GPIOC, GPIO_Pin_12) //打开PC12
#define Read_B20() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12) //读PC12
unsigned char Error_Flag=0;
unsigned char zf=0;
/*延时函数 微秒*/
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
/*延时函数 毫秒*/
void delay_ms(u32 n)
while(n--)
delay_us(1000);
void SysTick_Configuration(void)
/*==========此次作业的部分===========*/
if (SysTick_Config(48000)) //SysTick配置。48000/48ms=1ms
while (1);
NVIC_SetPriority(SysTick_IRQn, 0x0); //SysTick中断优先级
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_6); // PLLMul_X就是X的倍数,即8*6=48HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
// SystemInit();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* PA10 USART1_Rx */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
USART_InitStructure.USART_BaudRate = BaudRate;//??????
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
USART_InitStructure.USART_Parity = USART_Parity_No;//????
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
USART_ClockInit(USART1, &USART_ClockInitStructure);
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void delay_18b20(u32 nus) //18B20时序要求严格精确,为18B20写的延时函数
u16 i; //这个函数写的貌似是1us
while(nus--) //nus每减一次,i减12次
for(i=12;i>0;i--);
void Init18B20(void)
u8 aa=0;
u8 count =0;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //打开PC时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //选中管脚12
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; //开漏输出
Set_B20() ; //拉高
delay_18b20(1);
//一、复位:至少480us的低电平信号,当18b20接收到此信号后会回发芯片一个存在脉冲
Reset_B20(); //拉低
delay_18b20(480);
//二、存在脉冲:将数据单总线拉高,接收存在脉冲,通信双方达成基本协议,双方开始数据通信
Set_B20(); //拉高
delay_18b20(480);
count=0;
aa=Read_B20(); //aa为读得的温度、
/*=====我觉得下面这几句用来统计18B20出现错误的次数,次数到99次的时候报错======*/
while(!aa && count<100) //如果温度值和count数都大于100时
aa=Read_B20(); //再次读温度值
count++; //发生错误了,数值+1
if(count>=99) //如果发生错误的次数大于99次,那么报错,标志位为1
Error_Flag=1;
else
Error_Flag=0; //报错次数未达到99次,正常工作
//读一个字节
unsigned char Read18B20(void)//读18b20里的数据,由于是单数据总线,需要一位一位地读
unsigned char i=0;
unsigned char date=0;
u8 tempp;
for(i=8;i>0;i--)//循环8次
Reset_B20(); //拉低读数
date>>=1; //右移一位
delay_18b20(1);
Set_B20(); //拉高
delay_18b20(1);
tempp=Read_B20(); // tempp为读得的温度
if(tempp)
date|=0x80;
delay_18b20(60);
return(date);
void Write18B20(unsigned char date) //写一个字节
unsigned char i=0;
for (i=8; i>0; i--)
Reset_B20();
delay_18b20(1);
if(date & 0x01)
Set_B20();
else
{ Reset_B20();}
delay_18b20(60);
date>>=1;
Set_B20();
delay_18b20(1);
delay_18b20(15);
float Read_T()//
unsigned char TUp,TDown;
unsigned char fTemp;
u8 TT=0;
float Temp = 0;
Init18B20();
Write18B20(0xcc); // 跳过读取序列号
Write18B20(0x44); //
Init18B20();
Write18B20(0xbe); //
TDown = Read18B20(); //低8位
TUp = Read18B20(); //高8位
if(TUp>0x7f)
TDown=~TDown;
TUp=~TUp+1;
TUp/=8;
zf=1;
else
zf=0;
fTemp=TDown&0x0f;
TUp<<=4;
TDown>>=4;
TT=TUp|TDown;
Temp=TT+(float)fTemp/16;
return(Temp);
int main(void)
int i;
unsigned char ID1[8]; //定义一个用于18b20id读取和存放的数组
RCC_Configuration();
USART_int(115200);
SysTick_Configuration();
Init18B20 (); //初始化DS18B20
Write18B20(0x33); //写入“读取序列号”命令
delay_18b20 (15);
for(i=0;i<8;i++)
ID1[i]=Read18B20(); //读取18b20发回的64位地址
printf(" config done...\r\n");
delay_ms(1000);
while(1)
if(flag == 300){ //300us读一次id
printf("The id is:");
for(i=0;i<8;i++)
printf("%u",ID1[i]);
if(i==7){printf("\r\n"); }
if(flag == 500){ //500us读一次温度
printf("The Temperature is:%f\r\n",Read_T());
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
while (1)
#endif
#ifdef __GNUC__
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
USART_SendData(EVAL_COM1, (uint8_t) ch);
/* Loop until the end of transmission */
while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
return ch;
while (1)
#endif
