电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » EDA第五次作业
EDA第五次作业
2014-11-07 22:32:14     打赏
3-5 VHDL设计一个3-8译码器,要求分别用(条件)赋值语句、case语句、if else语句或移位操作符来完成。比较这4种方式中,哪一种最节省逻辑资源。
解(1):条件赋值语句
--3-5 38译码器设计(条件赋值语句实现)
    LIBRARY IEEE;
    USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY decoder3to8 IS
    port(   DIN: IN  STD_LOGIC_VECTOR(2 DOWNTO 0);
          DOUT: OUT BIT_VECTOR(7 DOWNTO 0));
 END decoder3to8;
  ARCHITECTURE behave OF decoder3to8 IS
 BEGIN
      WITH CONV_INTEGER(DIN) SELECT
  DOUT<="00000001" WHEN 0,
 "00000010" WHEN 1,
 "00000100" WHEN 2,
"00001000" WHEN 3,
 "00010000" WHEN 4,
"00100000" WHEN 5,
 "01000000" WHEN 6,
 "10000000" WHEN 7,
            UNAFFECTED WHEN OTHERS;
  END behave;
 解(2):case语句
--3-5 38译码器设计(case语句实现)
 LIBRARY IEEE;
port(   DIN: IN  STD_LOGIC_VECTOR(2 DOWNTO 0);               DOUT: OUT BIT_VECTOR(7 DOWNTO 0));
END decoder3to8;
 BEGIN
      PROCESS (DIN)
 BEGIN
        CASE CONV_INTEGER(DIN) IS
WHEN 0 => DOUT<="00000001";
    WHEN 1 => DOUT<="00000010";
    WHEN 2 => DOUT<="00000100";
     WHEN 3 => DOUT<="00001000";
     WHEN 4 => DOUT<="00010000";
WHEN 5 => DOUT<="00100000";
 WHEN 6 => DOUT<="01000000";
 WHEN 7 => DOUT<="10000000";
  WHEN OTHERS => NULL;
 END CASE;
  END PROCESS;
END behave;
解(3):if_else语句
--3-5 38译码器设计(if_else语句实现)
 LIBRARY IEEE;
   END decoder3to8;
  BEGIN
      PROCESS (DIN)
 BEGIN
      IF    CONV_INTEGER(DIN)=0 THEN DOUT<="00000001";
      ELSIF CONV_INTEGER(DIN)=1 THEN DOUT<="00000010";
   ELSIF CONV_INTEGER(DIN)=2 THEN DOUT<="00000100";
   ELSIF CONV_INTEGER(DIN)=3 THEN DOUT<="00001000";
ELSIF CONV_INTEGER(DIN)=4 THEN DOUT<="00010000";
ELSIF CONV_INTEGER(DIN)=5 THEN DOUT<="00100000";
   ELSIF CONV_INTEGER(DIN)=6 THEN DOUT<="01000000";
    ELSIF CONV_INTEGER(DIN)=7 THEN DOUT<="10000000";
     END IF;
      END PROCESS;
  END behave;
 解(4):移位操作符
--3-5 38译码器设计(移位操作实现)
  LIBRARY IEEE;
  END decoder3to8;
   BEGIN
      DOUT<="00000001" SLL CONV_INTEGER(DIN);
     END behave;
3-14 用循环语句设计一个7人投票表决器。
解:3-14 用循环语句设计一个7人投票表决器,及一个44输出最大数值检测电路。
  LIBRARY  IEEE;
ENTITY vote_7 IS
      PORT( DIN:  IN STD_LOGIC_VECTOR(6 DOWNTO 0);--7位表决输入(1:同意,0:不同意
            G_4: OUT STD_LOGIC;      --超过半数指示
           CNTH: OUT STD_LOGIC_VECTOR(2 DOWNTO 0));--表决结果统计数
  END vote_7;
    ARCHITECTURE BHV OF vote_7 IS     BEGIN
      PROCESS(DIN)
        VARIABLE Q: STD_LOGIC_VECTOR(2 DOWNTO 0);
    BEGIN
        Q:="000";
        FOR n IN 0 TO 6 LOOP  -- nLOOP的循环变量           IF(DIN(n)='1') THEN Q:=Q+1; END IF;         END LOOP;
  CNTH<=Q;
   IF Q>=4 THEN G_4<='1'; ELSE G_4<='0'; END IF;
    END PROCESS;     END BHV;
关键词: EDA
