电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » EDA第5次作业
EDA第5次作业
2014-11-14 22:02:29     打赏
EDA第5次作业.doc
EDA5次作业
姓名:李二猛  学号:201405080011  班级:14级电信(专升本)
3-5 VHDL设计一个3-8译码器,要求分别用(条件)赋值语句、case语句、if else语句或移位操作符来完成。比较这4种方式中,哪一种最节省逻辑资源。
解(1):条件赋值语句
3-5 3到8译码器设计(条件赋值语句实现)
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL; --为使用类型转换函数,打开此程序包。
ENTITY decoder3to8 IS
port(   DIN: IN  STD_LOGIC_VECTOR(2 DOWNTO 0)
DOUT: OUT BIT_VECTOR(7 DOWNTO 0));
END decoder3to8;
ARCHITECTURE behave OF decoder3to8 IS
BEGIN
WITH CONV_INTEGER(DIN) SELECT
DOUT<="00000001" WHEN 0,
"00000010" WHEN 1,
"00000100" WHEN 2,
"00001000" WHEN 3,
 "00010000" WHEN 4,
"00100000" WHEN 5,
"01000000" WHEN 6,
 "10000000" WHEN 7,
UNAFFECTED WHEN OTHERS
END behave;
解(2):case语句
LIBRARY IEEE;
port(   DIN: IN  STD_LOGIC_VECTOR(2 DOWNTO 0);
END decoder3to8;
BEGIN
PROCESS (DIN)
BEGIN
CASE CONV_INTEGER(DIN) IS
WHEN 0 => DOUT<="00000001";
WHEN 1 => DOUT<="00000010";
WHEN 2 => DOUT<="00000100";
WHEN 3 => DOUT<="00001000";
WHEN 4 => DOUT<="00010000";
WHEN 5 => DOUT<="00100000";
WHEN 6 => DOUT<="01000000";
WHEN 7 => DOUT<="10000000";
WHEN OTHERS => NULL;
END CASE;
END PROCESS;
END behave;
解(3):if_else语句
LIBRARY IEEE;
END decoder3to8;
BEGIN
PROCESS (DIN)
BEGIN
IF    CONV_INTEGER(DIN)=0 THEN DOUT<="00000001";
ELSIF CONV_INTEGER(DIN)=1 THEN DOUT<="00000010";
ELSIF CONV_INTEGER(DIN)=2 THEN DOUT<="00000100";
ELSIF CONV_INTEGER(DIN)=3 THEN DOUT<="00001000";
ELSIF CONV_INTEGER(DIN)=4 THEN DOUT<="00010000";
ELSIF CONV_INTEGER(DIN)=5 THEN DOUT<="00100000";
 ELSIF CONV_INTEGER(DIN)=6 THEN DOUT<="01000000";
 ELSIF CONV_INTEGER(DIN)=7 THEN DOUT<="10000000";
END IF;
END PROCESS;
END behave;
解(4):移位操作符
LIBRARY IEEE;
port(   DIN: IN  STD_LOGIC_VECTOR(2 DOWNTO 0);               DOUT: OUT BIT_VECTOR(7 DOWNTO 0));
END decoder3to8;
BEGIN
DOUT<="00000001" SLL CONV_INTEGER(DIN); --被移位部分是常数
END behave;
Quartus II 9.0 (64-Bit)仿真截图
3-14 用循环语句设计一个7人投票表决器。
LIBRARY  IEEE;
ENTITY vote_7 IS
PORT( DIN:  IN STD_LOGIC_VECTOR(6 DOWNTO 0);--7位表决输入(1:同意,0:不同意)
G_4: OUT STD_LOGIC;                   --超过半数指示
CNTH: OUT STD_LOGIC_VECTOR(2 DOWNTO 0));--表决结果统计数
END vote_7;
ARCHITECTURE BHV OF vote_7 IS
BEGIN
PROCESS(DIN)
VARIABLE Q: STD_LOGIC_VECTOR(2 DOWNTO 0);
BEGIN
Q:="000";
FOR n IN 0 TO 6 LOOP  -- nLOOP的循环变量
IF(DIN(n)='1') THEN Q:=Q+1; END IF;
ENDLOOP;
CNTH<=Q;
 IF Q>=4 THEN G_4<='1'; ELSE G_4<='0'; END IF;
END PROCESS;
END BHV;
关键词: EDA第5次作业     LOGIC
