.text
_start: INTM=#1 ; mask interrupts
sp=#1000h ;初始化堆栈指针
pmst=#1a0h ;初始化堆栈指pmst,中断向量重定位道200h
BSCR=#0800h ; Set Wait States for Bank Switching
; STM #SWWSR_VAL, SWWSR ; Init S/W Wait State Register
;(commented out: power–up default value used)
SWWSR=#2000h ;7个等待状态
TCR=#10h ; Stop on–chip timer
OVM=#1 ; overflow mode enabled
SXM=#1 ; sign extension mode enabled
IFR=#0ffffh ; clear pending interrupts (if any)
IMR=#0200h ; select host to DSP interrupt
INTM=#0 ; enable maskable interrupts
loop: xf=1 ;turn off led
nop
nop
nop
nop
dcall delay_1s
nop
nop
nop
nop
xf=0 ;turn on led
nop
nop
nop
nop
dcall delay_1s
nop
nop
nop
nop
dgoto loop
nop
nop
****************delay 1s program*****************************
delay_1s:
push(ar6)
push(ar7)
ar6=#1000
d_wait: ar7=#1000
d_wait1: nop
nop
nop
nop
nop
nop
nop
if (*ar7- != 0) dgoto d_wait1
nop
nop
if (*ar6- != 0) dgoto d_wait
nop
nop
ar7 = pop()
ar6 = pop()
dreturn
nop
nop
* dsp interrupt service routine
DSP_ISR:
ar5=#hostcommand; pointer to host command
ar1=#flashaddr ; pointer to flash addr
ar2=#flashdata ; pointer to host data
ar3=#dspstate ; pointer to dsp statue
ar4=#dspresult ; pointer to flash data
* Bit test host command and process num1 and num2 accordingly
CHK_BIT0:
TC = bit(*ar5,15-0) ; test bit0 of host command
if (NTC) dgoto CHK_BIT1 ; if bit0=0 check bit1
nop
nop
a=*ar1;
ar5=a
nop
nop
dcall _WRITEFlash ; program flash a word
nop
nop
*ar3=#0001h
dgoto EXIT
nop
nop
CHK_BIT1:
TC = bit(*ar5,15-1) ; test bit0 of host command
if (NTC) dgoto CHK_BIT2 ; if bit1=0 check bit2
nop
nop
a=*ar1;
nop
nop
ar2=a
nop
nop
a=*ar2
*ar4=a
nop
nop
*ar3=#0001h
dgoto EXIT
nop
nop
CHK_BIT2:
TC = bit(*ar5,15-2) ; test bit0 of host command
if (NTC) dgoto EXIT ; if bit2=0 then bad host command
nop
nop
dcall _ERASEFlash ; erase the flash chip
nop
nop
*ar3=#0001h
dgoto EXIT
nop
nop
* DSP_ISR exit point
EXIT: IFR=#0FFFFh ; clear interrupt flags
dreturn_enable
nop
nop
****program flash a word
_WRITEFlash:
push(ar0)
ar0=#(05555H+OFFSET)
nop
nop
*ar0= #0AAAAH ; 周期1(解锁)
nop
nop
ar0=#0AAAAH
nop
nop
*ar0=#05555H ; 周期2(解锁)
nop
nop
ar0=#0d555H
nop
nop
*ar0=#0A0A0H ; 周期3(建立)
nop
nop
a=*ar2
nop
nop
*ar5=a ; 周期4(编程)
nop
nop
dcall Check_Toggle_Ready ;检测编程是否正确,见Flash的操作检测
nop
nop
ar0=pop()
dreturn
nop
nop
**********flash erash,whole chip
_ERASEFlash: ;擦除宏
push(ar0)
push(al)
push(ah)
push(ag)
ar0=#0d555H
*ar0=#0AAAAH; 周期1(解锁)
nop
nop
nop
nop
ar0=#0AAAAH
*ar0=#05555H; 周期2(解锁),应该对地址2aaa操作,但2aaa在5402中不可见,所以加一个偏移量8000h
nop
nop
nop
nop
ar0=#0d555H
*ar0=#08080H; 周期3(建立)
nop
nop
nop
nop
ar0=#0d555H
*ar0=#0AAAAH; 周期4(解锁)
nop
nop
nop
nop
ar0=#0AAAAH
*ar0=#05555H; 周期5(解锁)
nop
nop
nop
nop
ar0=#0d555H
*ar0=#01010H; 周期6(片擦除)
nop
nop
nop
nop
ar0=#2000;;delay 1ms
nop
nop
erase_wait1:
nop
nop
if (*ar0- != 0) dgoto erase_wait1
nop
nop
a=#0;
ar0=#8000h;
erase_wait2:;check data polling
a=*ar0;
nop
nop
a=a & #0080h
nop
nop
if (aeq) dgoto erase_wait2
nop
nop
ag=pop()
ah=pop()
al=pop()
ar0=pop()
dreturn
nop
nop
Check_Toggle_Ready:
a=*ar5 ; read a word form the chip
nop
nop
a=a & #0040h ; mask out the TOGGLE bit (DQ6)
nop
nop
CTR_Tog2:
b=*ar5 ; read the same word from the chip again
nop
nop
b=b & #0040h ; mask out the TOGGLE bit (DQ6)
nop
nop
a=a-b ; is DQ6 still toggling?
nop
nop
if (aeq) dgoto CTR_Tog3 ; No, then the write operation is done
nop
nop
a=b
nop
nop
dgoto CTR_Tog2 ; YES, then continue checking...
nop
nop
CTR_Tog3:
dreturn
nop
nop
