电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » EDA第五次作业
EDA第五次作业
2015-01-06 19:46:51     打赏
3-5:
解(1):顺序赋值语句
     3到8译码器设计(顺序赋值语句实现)
    LIBRARY IEEE;
    USE IEEE.STD_LOGIC_1164.ALL;
    USE IEEE.STD_LOGIC_UNSIGNED.ALL;
    ENTITY decoder3to8 IS
      port(   DIN: IN  STD_LOGIC_VECTOR(2 DOWNTO 0);
              DOUT: OUT BIT_VECTOR(7 DOWNTO 0));
    END decoder3to8;
    ARCHITECTURE behave OF decoder3to8 IS
    BEGIN
      WITH CONV_INTEGER(DIN) SELECT
      DOUT<="00000001" WHEN 0,
            "00000010" WHEN 1,
            "00000100" WHEN 2,
            "00001000" WHEN 3,
            "00010000" WHEN 4,
            "00100000" WHEN 5,
            "01000000" WHEN 6,
            "10000000" WHEN 7,
            UNAFFECTED WHEN OTHERS;
    END behave;
解(2):case语句
     3到8译码器设计(case语句实现)
    LIBRARY IEEE;
    END decoder3to8;
    BEGIN
      PROCESS (DIN)
      BEGIN
        CASE CONV_INTEGER(DIN) IS
          WHEN 0 => DOUT<="00000001";
          WHEN 1 => DOUT<="00000010";
          WHEN 2 => DOUT<="00000100";
          WHEN 3 => DOUT<="00001000";
          WHEN 4 => DOUT<="00010000";
          WHEN 5 => DOUT<="00100000";
          WHEN 6 => DOUT<="01000000";
          WHEN 7 => DOUT<="10000000";
          WHEN OTHERS => NULL;
        END CASE;
      END PROCESS;
    END behave;
解(3):if_else语句
     3到8译码器设计(if_else语句实现)
    LIBRARY IEEE;
    END decoder3to8;
    BEGIN
      PROCESS (DIN)
      BEGIN
      IF    CONV_INTEGER(DIN)=0 THEN DOUT<="00000001";
      ELSIF CONV_INTEGER(DIN)=1 THEN DOUT<="00000010";
      ELSIF CONV_INTEGER(DIN)=2 THEN DOUT<="00000100";
      ELSIF CONV_INTEGER(DIN)=3 THEN DOUT<="00001000";
      ELSIF CONV_INTEGER(DIN)=4 THEN DOUT<="00010000";
      ELSIF CONV_INTEGER(DIN)=5 THEN DOUT<="00100000";
      ELSIF CONV_INTEGER(DIN)=6 THEN DOUT<="01000000";
      ELSIF CONV_INTEGER(DIN)=7 THEN DOUT<="10000000";
      END IF;
      END PROCESS;
    END behave;
解(4):移位操作符
    3到8译码器设计(移位操作实现)
    LIBRARY IEEE;
    END decoder3to8;
    BEGIN
      DOUT<="00000001" SLL CONV_INTEGER(DIN);
    END behave;
3-14
--解:用循环语句设计一个7人投票表决器,及一个4位4输出最大数值检测电路。
    LIBRARY  IEEE;
    ENTITY vote_7 IS
      PORT( DIN:  IN STD_LOGIC_VECTOR(6 DOWNTO 0);--7位表决输入(1:同意,0:不同意)
            G_4: OUT STD_LOGIC;
           CNTH: OUT STD_LOGIC_VECTOR(2 DOWNTO 0));
    END vote_7;
    ARCHITECTURE BHV OF vote_7 IS
    BEGIN
      PROCESS(DIN)
        VARIABLE Q: STD_LOGIC_VECTOR(2 DOWNTO 0);
      BEGIN
        Q:="000";
        FOR n IN 0 TO 6 LOOP
          IF(DIN(n)='1') THEN Q:=Q+1; END IF;
        END LOOP;
        CNTH<=Q;
        IF Q>=4 THEN G_4<='1'; ELSE G_4<='0'; END IF;
      END PROCESS;
    END BHV;
