NRF24L01P通信
	    这几天一直在调试nrf24l01p的通信,终于调通了:
	控制器使用的是上次活动时买的烈火四轴飞行器的遥控器:
	    由于采用了freeRTOS系统,采用任务调度方式,同时管脚多,一粗心设错了就调不通。在小车上就因为SPI的中断调用函数放错了位置,用了很多时间才找出来。今天把代码贴上,省得以后再重复调。下面是遥控器的代码,每秒发送一次hello消息。有些函数用不多,例如receivePacket等,写上以备后用。
 * nrf24l01.c: nRF24L01(-p) TX mode low level driver
/* TODO:
 *  - Separate the SPI and GPIO driver from here.
 *  - Handle TX mode
#include "stdio.h"
#include <stdbool.h>
#include <string.h>
#include "nrf24l01.h"
#include "stm32f10x_conf.h"
#include "stm32f10x_rcc.h"
#include "stm32f10x_spi.h"
#include "stm32f10x_exti.h"
/*FreeRtos includes*/
#include "FreeRTOS.h"
#include "task.h"
#include "semphr.h"
#include "queue.h"
/* Defines for the SPI and GPIO pins used to drive the SPI Flash */
#define RADIO_GPIO_CS             GPIO_Pin_13
#define RADIO_GPIO_CS_PORT        GPIOC
#define RADIO_GPIO_CS_PERIF       RCC_APB2Periph_GPIOC
#define RADIO_GPIO_CE             GPIO_Pin_14
#define RADIO_GPIO_CE_PORT        GPIOC
#define RADIO_GPIO_CE_PERIF       RCC_APB2Periph_GPIOC
#define RADIO_GPIO_IRQ            GPIO_Pin_15
#define RADIO_GPIO_IRQ_PORT       GPIOC
#define RADIO_GPIO_IRQ_PERIF      RCC_APB2Periph_GPIOC
#define RADIO_GPIO_IRQ_SRC_PORT   GPIO_PortSourceGPIOC
#define RADIO_GPIO_IRQ_SRC        GPIO_PinSource15
#define RADIO_GPIO_IRQ_LINE       EXTI_Line15
#define RADIO_SPI                 SPI2
#define RADIO_SPI_CLK             RCC_APB1Periph_SPI2
#define RADIO_GPIO_SPI_PORT       GPIOB
#define RADIO_GPIO_SPI_SCK        GPIO_Pin_13
#define RADIO_GPIO_SPI_MISO       GPIO_Pin_14
#define RADIO_GPIO_SPI_MOSI       GPIO_Pin_15
#define NVIC_RADIO_PRI        13
/* Registers address definition */
#define REG_CONFIG      0x00  // 'Config' register address
#define REG_EN_AA       0x01  // 'Enable Auto Acknowledgment' register address
#define REG_EN_RXADDR   0x02  // 'Enabled RX addresses' register address
#define REG_SETUP_AW    0x03  // 'Setup address width' register address
#define REG_SETUP_RETR  0x04  // 'Setup Auto. Retrans' register address
#define REG_RF_CH       0x05  // 'RF channel' register address
#define REG_RF_SETUP    0x06  // 'RF setup' register address
#define REG_STATUS      0x07  // 'Status' register address
#define REG_OBSERVE_TX  0x08  // 'Observe TX' register address
#define REG_RPD         0x09  // 'Carrier Detect' register address
#define REG_RX_ADDR_P0  0x0A  // 'RX address pipe0' register address
#define REG_RX_ADDR_P1  0x0B  // 'RX address pipe1' register address
#define REG_RX_ADDR_P2  0x0C  // 'RX address pipe2' register address
#define REG_RX_ADDR_P3  0x0D  // 'RX address pipe3' register address
#define REG_RX_ADDR_P4  0x0E  // 'RX address pipe4' register address
#define REG_RX_ADDR_P5  0x0F  // 'RX address pipe5' register address
#define REG_TX_ADDR     0x10  // 'TX address' register address
#define REG_RX_PW_P0    0x11  // 'RX payload width, pipe0' register address
#define REG_RX_PW_P1    0x12  // 'RX payload width, pipe1' register address
#define REG_RX_PW_P2    0x13  // 'RX payload width, pipe2' register address
#define REG_RX_PW_P3    0x14  // 'RX payload width, pipe3' register address
#define REG_RX_PW_P4    0x15  // 'RX payload width, pipe4' register address
#define REG_RX_PW_P5    0x16  // 'RX payload width, pipe5' register address
#define REG_FIFO_STATUS 0x17  // 'FIFO Status Register' register address
#define REG_DYNPD       0x1C
#define REG_FEATURE     0x1D
#define VAL_RF_SETUP_250K 0x26
#define VAL_RF_SETUP_1M   0x06
#define VAL_RF_SETUP_2M   0x0E
#define VAL_SETUP_AW_3B 1
#define VAL_SETUP_AW_4B 2
#define VAL_SETUP_AW_5B 3
/* nRF24L SPI commands */
#define CMD_R_REG              0x00
#define CMD_W_REG              0x20
#define CMD_R_RX_PAYLOAD       0x61
#define CMD_W_TX_PAYLOAD       0xA0
#define CMD_FLUSH_TX           0xE1
#define CMD_FLUSH_RX           0xE2
#define CMD_REUSE_TX_PL        0xE3
#define CMD_ACTIVATE           0x50
#define CMD_RX_PL_WID          0x60
#define CMD_W_ACK_PAYLOAD(P)  (0xA8|(P&0x0F))
#define CMD_W_PAYLOAD_NO_ACK   0xD0
#define CMD_NOP                0xFF
#define ACTIVATE_DATA   0x73
#define DUMMY_BYTE    0xA5
#define RADIO_PACKET_SIZE 32
#define RADIO_CONNECTED_TIMEOUT   (2000)
/*** Defines ***/
#define RADIO_RATE_250K 0
#define RADIO_RATE_1M   1
#define RADIO_RATE_2M   2
/* Usefull macro */
#define RADIO_EN_CS()  GPIO_ResetBits(RADIO_GPIO_CS_PORT, RADIO_GPIO_CS)
#define RADIO_DIS_CS() GPIO_SetBits(RADIO_GPIO_CS_PORT, RADIO_GPIO_CS)
#define RADIO_DIS_CE() GPIO_ResetBits(RADIO_GPIO_CE_PORT, RADIO_GPIO_CE)
#define RADIO_EN_CE()  GPIO_SetBits(RADIO_GPIO_CE_PORT, RADIO_GPIO_CE)
/* Synchronisation */
xSemaphoreHandle dataRdy;
xQueueHandle txQueue;
xQueueHandle rxQueue;
typedef struct _radioPacket
  char raw[RADIO_PACKET_SIZE];
} radioPacket;
static uint32_t lastPacketTick;
static bool radioIsInit;
 * SPI private methods *
static char spiSendByte(char byte)
  /* Loop while DR register in not emplty */
  while (SPI_I2S_GetFlagStatus(RADIO_SPI, SPI_I2S_FLAG_TXE) == RESET);
  /* Send byte through the SPI1 peripheral */
  SPI_I2S_SendData(RADIO_SPI, byte);
  /* Wait to receive a byte */
  while (SPI_I2S_GetFlagStatus(RADIO_SPI, SPI_I2S_FLAG_RXNE) == RESET);
  /* Return the byte read from the SPI bus */
  return SPI_I2S_ReceiveData(RADIO_SPI);
static char spiReceiveByte()
  return spiSendByte(DUMMY_BYTE);
 * nRF SPI commands, Every commands return the status byte      *
/* Read len bytes from a nRF24L register. 5 Bytes max */
unsigned char nrfReadReg(unsigned char address, char *buffer, int len)
  unsigned char status;
  int i;
  RADIO_EN_CS();
  /* Send the read command with the address */
  status = spiSendByte( CMD_R_REG | (address&0x1F) );
  /* Read LEN bytes */
  for(i=0; i<len; i++)
    buffer[i]=spiReceiveByte();
  RADIO_DIS_CS();
  return status;
/* Write len bytes a nRF24L register. 5 Bytes max */
unsigned char nrfWriteReg(unsigned char address, char *buffer, int len)
  int i;
  RADIO_EN_CS();
  /* Send the write command with the address */
  status = spiSendByte( CMD_W_REG | (address&0x1F) );
  /* Write LEN bytes */
    spiSendByte(buffer[i]);
  RADIO_DIS_CS();
  return status;
/* Write only one byte (useful for most of the reg.) */
unsigned char nrfWrite1Reg(unsigned char address, char byte)
  return nrfWriteReg(address, &byte, 1);
/* Read only one byte (useful for most of the reg.) */
unsigned char nrfRead1Reg(unsigned char address) {
  char byte;
  nrfReadReg(address, &byte, 1);
  return byte;
/* Sent the NOP command. Used to get the status byte */
unsigned char nrfNop()
  RADIO_EN_CS();
  status = spiSendByte(CMD_NOP);
  RADIO_DIS_CS();
  return status;
unsigned char nrfFlushRx()
  RADIO_EN_CS();
  status = spiSendByte(CMD_FLUSH_RX);
  RADIO_DIS_CS();
  return status;
unsigned char nrfFlushTx()
  RADIO_EN_CS();
  status = spiSendByte(CMD_FLUSH_TX);
  RADIO_DIS_CS();
  return status;
// Return the payload length
unsigned char nrfRxLength(unsigned int pipe)
  unsigned char length;
  RADIO_EN_CS();
  spiSendByte(CMD_RX_PL_WID);
  length = spiReceiveByte();
  RADIO_DIS_CS();
  return length;
unsigned char nrfActivate()
  RADIO_EN_CS();
  status = spiSendByte(CMD_ACTIVATE);
  spiSendByte(ACTIVATE_DATA);
  RADIO_DIS_CS();
  return status;
// Write the ack payload of the pipe 0
unsigned char nrfWriteTx(char *buffer, int len)
  int i;
  RADIO_EN_CS();
  status = spiSendByte(CMD_W_TX_PAYLOAD);
  RADIO_DIS_CS();
  return status;
unsigned char nrfWriteAck(unsigned int pipe, char *buffer, int len)
  int i;
  printf("send: %s",buffer);
  RADIO_EN_CS();
  status = spiSendByte(CMD_W_ACK_PAYLOAD(pipe));
//  status = spiSendByte(0xA8);
  RADIO_DIS_CS();
  return status;
// Read the RX payload
unsigned char nrfReadRX(char *buffer, int len)
  int i;
  RADIO_EN_CS();
  status = spiSendByte(CMD_R_RX_PAYLOAD);
  RADIO_DIS_CS();
  return status;
void nrfSetChannel(unsigned int channel)
  if (channel<126)
    nrfWrite1Reg(REG_RF_CH, channel);
void nrfSetDatarate(int datarate)
  switch(datarate)
    case RADIO_RATE_250K:
      nrfWrite1Reg(REG_RF_SETUP, VAL_RF_SETUP_250K);
      break;
    case RADIO_RATE_1M:
      nrfWrite1Reg(REG_RF_SETUP, VAL_RF_SETUP_1M);
      break;
    case RADIO_RATE_2M:
      nrfWrite1Reg(REG_RF_SETUP, VAL_RF_SETUP_2M);
      break;
void nrfSetAddress(unsigned int pipe, char* address)
  int len = 5;
//  ASSERT(pipe<6);
  if (pipe > 1)
    len = 1;
  nrfWriteReg(REG_RX_ADDR_P0 + pipe, address, len);
void nrfSetEnable(bool enable)
  if (enable)
    RADIO_EN_CE();
  else
    RADIO_DIS_CE();
unsigned char nrfGetStatus()
  return nrfNop();
bool nrfInterruptActive(void)
  return (GPIO_ReadInputDataBit(RADIO_GPIO_IRQ_PORT, RADIO_GPIO_IRQ) == Bit_RESET);
/* Initialisation */
void nrfInit(void)
  SPI_InitTypeDef  SPI_InitStructure;
  EXTI_InitTypeDef EXTI_InitStructure;
  GPIO_InitTypeDef GPIO_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Enable SPI and GPIO clocks */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO |RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC,ENABLE);
  RCC_APB1PeriphClockCmd(RADIO_SPI_CLK, ENABLE);
  /* Configure SPI pins: SCK, MOSI, MISO */
  GPIO_InitStructure.GPIO_Pin = RADIO_GPIO_SPI_SCK
                    |RADIO_GPIO_SPI_MOSI| RADIO_GPIO_SPI_MISO;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_Init(RADIO_GPIO_SPI_PORT, &GPIO_InitStructure);
  /* Configure I/O for the Chip select */
  GPIO_InitStructure.GPIO_Pin = RADIO_GPIO_CS;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(RADIO_GPIO_CS_PORT, &GPIO_InitStructure);
  /* Configure I/O for the Chip Enable */
  GPIO_InitStructure.GPIO_Pin = RADIO_GPIO_CE;
  GPIO_Init(RADIO_GPIO_CE_PORT, &GPIO_InitStructure);
  /* Enable SYSCFG clock */
//  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  GPIO_InitStructure.GPIO_Pin = RADIO_GPIO_IRQ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_Init(RADIO_GPIO_IRQ_PORT, &GPIO_InitStructure);
  /* SPI configuration */
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(RADIO_SPI, &SPI_InitStructure);
  GPIO_EXTILineConfig(RADIO_GPIO_IRQ_SRC_PORT, RADIO_GPIO_IRQ_SRC);
  EXTI_InitStructure.EXTI_Line = RADIO_GPIO_IRQ_LINE;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* disable the chip select */
  RADIO_DIS_CS();
  /* disable the chip enable */
  RADIO_DIS_CE();
  NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = NVIC_RADIO_PRI;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Enable the SPI  */
  SPI_Cmd(RADIO_SPI, ENABLE);
u8 Nrf24l01_Check(void)
  char buf1[5]={0};
  char radioAddress[5] = {0xE1, 0xE2, 0xE3, 0xE4, 0xE5};
  u8 i;
  nrfWriteReg(0x30,radioAddress,5);
  nrfReadReg(REG_TX_ADDR,buf1,5);
  for(i=0;i<5;i++)
    if(buf1[i]!=radioAddress[i])
      break;
  if(i==5)
    return SUCCESS ;
  else
    return ERROR ;
//not used in TX mode
void nrfInterruptHandler(void)
  portBASE_TYPE  xHigherPriorityTaskWoken = pdFALSE;
  if(EXTI_GetITStatus(RADIO_GPIO_IRQ_LINE) != RESET)
    //To unlock RadioTask
    xSemaphoreGiveFromISR(dataRdy, &xHigherPriorityTaskWoken);
    if(xHigherPriorityTaskWoken == pdTRUE)
      portYIELD();
    EXTI_ClearITPendingBit(RADIO_GPIO_IRQ_LINE);
/*  Crazyflie  */
void nrfConfigure(void)
  int i;
  //Set radio address
  nrfSetAddress(0, radioAddress);
  //Set the radio channel
  nrfSetChannel(40);
  //Set the radio data rate 2M
  nrfSetDatarate(2);
  nrfWrite1Reg(REG_EN_RXADDR,0x01);//1
  nrfWrite1Reg(REG_EN_AA,0x01);
  //address length
  nrfWrite1Reg(REG_SETUP_AW,3);
  nrfWriteReg(REG_TX_ADDR,radioAddress,5);
  nrfWrite1Reg(REG_SETUP_RETR,0x0);
  nrfWrite1Reg(REG_STATUS,0xfe);
  //Power the radio, Enable the DS interruption, set the radio in PRX mode
  nrfWrite1Reg(REG_CONFIG, 0x0e);
  // Enable the dynamic payload size and the ack payload for the pipe 0
  nrfWrite1Reg(REG_FEATURE, 0x06);
  nrfWrite1Reg(REG_DYNPD, 0x01);
  //Flush TX
  for(i=0;i<3;i++)
    nrfFlushTx();
  printf("radiolink initNRF24L01 over\r\n");
void radiolinkTask(void *param)
  unsigned char dataLen;
  static radioPacket p;
  while (1)
//    xSemaphoreTake(dataRdy, portMAX_DELAY);
    lastPacketTick = xTaskGetTickCount();
    nrfSetEnable(false);
    //Fetch all the data (Loop until the RX Fifo is NOT empty)
    while( !(nrfRead1Reg(REG_FIFO_STATUS)&0x01) )
      dataLen = nrfRxLength(0);
      if (dataLen>RADIO_PACKET_SIZE)          //If a packet has a wrong size it is dropped
        nrfFlushRx();
      else                     //Else, it is processed
        nrfReadRX(p.raw, dataLen);
        xQueueSend( rxQueue, &p, 0);
    //Push the data to send (Loop until the TX Fifo is full or there is no more data to send)
    while( (uxQueueMessagesWaiting((xQueueHandle)txQueue) > 0) && !(nrfRead1Reg(REG_FIFO_STATUS)&0x20) )
      xQueueReceive(txQueue, &p, 0);
      nrfWriteAck(0,p.raw, RADIO_PACKET_SIZE);
      printf("nrfWriteAck over\r\n");
    //clear the interruptions flags
    nrfWrite1Reg(REG_STATUS, 0x70);
    //Re-enable the radio
    nrfSetEnable(true);
void radiolinkTest(void)
  if( Nrf24l01_Check() == SUCCESS){
    printf("Nrf24l01 Check returns SUCCESS\r\n");
  }else{
    printf("Nrf24l01 Check returns ERROR\r\n");
  return;
 * Public functions,
 * finish all the nrf24l01 iniaialization.
void radiolinkInit()
  if(radioIsInit)
    return;
  /* Initialise the semaphores */
  vSemaphoreCreateBinary(dataRdy);
  /* Queue init */
  txQueue = xQueueCreate(3, sizeof(radioPacket));
  rxQueue = xQueueCreate(3,  sizeof(radioPacket));
  nrfInit();
  radiolinkTest();
  nrfConfigure();
  /* Start Tx tasks */
  xTaskCreate(radiolinkTask, (const signed char *)"radiolinkTask",
              configMINIMAL_STACK_SIZE, NULL, /*priority*/2, NULL);
  vTaskSetApplicationTaskTag(0, (pdTASK_HOOK_CODE)TASK_RADIO_ID_NBR);
  radioIsInit = true;
void radiolinkReInit(void)
  if (!radioIsInit)
    return;
  nrfConfigure();
/*public functions*/
int sendPacket(unsigned char *p)
  xQueueSend(txQueue, p, 0);
  return 0;
int receivePacket(unsigned char * pk)
  xQueueReceive( rxQueue, pk, portMAX_DELAY);
  return 0;
void radioTestTask(void *param)
  unsigned char buff[RADIO_PACKET_SIZE] = "Hello,this is controller\r\n";
  while(1)
    vTaskDelay(1000);//send a hello message one time in a second
    sendPacket(buff);
