温湿度传感器已经接到香蕉派上许久了,虽然wiringpi也通过了,但是编程能力有限,一直没有读出温湿度来
找到相关代码
if(!Mode)
printf("Raspi-SHT21 V3.0.0 by Martin Steppuhn (www.emsystech.de) [" __DATE__ " " __TIME__"]\n");
printf("Options:\n");
printf(" S : [20.0 99]\n");
printf(" L : [temperature=20.0][humidity=99]\n");
printf(" C : [Temperature,20,0][Humidity,99]\n");
printf("RaspberryHwRevision=%i\r\n",HwRev);
if(HwRev < 2) I2C_Open("/dev/i2c-0"); // Hardware Revision 1.0
else I2C_Open("/dev/i2c-1"); // Hardware Revision 2.0
I2C_Setup(I2C_SLAVE, 0x40);
uint8 SHT21_Read(int16 *temperature,uint8 *humidity)
uint32 val;
uint8 buf[4];
Sht21Error = 0;
//=== Softreset ==================================================
I2C_Write1(0xFE); // softreset < 15ms
DelayMs(50);
//=== Temperature =================================================
I2C_Write1(0xF3); // start temperature measurement
DelayMs(260); // Temperature@14Bit typ=66ms max=85ms
I2C_Read(buf,3); // read temperature data
if(buf[2] == CalcSht21Crc(buf,2)) // check CRC
val = buf[0];
val <<= 8;
val += buf[1];
val &= 0xFFFC;
// T = -46,85 + 175,72 * St/65535 da 1/10K --> * 10
// T = -468,5 + 1757,2 * St/65535 verinfachen
// T = -468,5 + St / 37,2956.. damit Konstante ganzzahlig wird mit 2 erweitern
// T = -937 + 2*St / 37,2956.. Bruch f黵 Division mit 256 erweitern
// T = (-937 + (St * 512) / (37,2956.. * 256) ) / 2
// T = (((St * 512) / 9548) - 937) / 2
// val = (((val * 512) / 9548) - 937) / 2;
*temperature = ((val * 512) / 9548);
*temperature = ((*temperature) - 937) / 2;
else
Sht21Error |= ERROR_SHT21_CRC_TEMP;
//=== Humidity ===================================================
I2C_Write1(0xF5); // start humidity measurement
DelayMs(60); // RH@12Bit typ=22ms max=20ms
I2C_Read(buf,3); // read humidity data
val = buf[0];
val <<= 8;
val += buf[1];
val &= 0xFFFC;
// T = -6 + 125* Srh/65535
// T = -6 + Srh / 524,28
// T = -6 + (Srh * 256) / 134215 | *256 wegen Numerik erweitern
val = ((val * 256) / 134215) - 6;
*humidity = val;
else
if(I2cError) Sht21Error |= ERROR_SHT21_I2C;
return Sht21Error;
相比较之下wiringpi写得比较抽象,怪不得没用好呢,慢慢习惯吧
union i2c_smbus_data
uint8_t byte ;
uint16_t word ;
uint8_t block [I2C_SMBUS_BLOCK_MAX + 2] ; // block [0] is used for length + one more for PEC
struct i2c_smbus_ioctl_data
char read_write ;
uint8_t command ;
int size ;
union i2c_smbus_data *data ;
static inline int i2c_smbus_access (int fd, char rw, uint8_t command, int size, union i2c_smbus_data *data)
struct i2c_smbus_ioctl_data args ;
args.read_write = rw ;
args.command = command ;
args.size = size ;
args.data = data ;
return ioctl (fd, I2C_SMBUS, &args) ;
| OrangePiZero2W系统被打赏¥33元 | |
