电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » balanced-binary-tree
2018-01-22 17:20:28     打赏
Given a binary tree, determine if it is height-balanced.
For this problem, a height-balanced binary tree is defined as a binary tree in which the depth of the two subtrees of every node never differ by more than 1.
判断给定的二叉树是否为平衡二叉树
思路:因为平衡二叉树要求左右子树的深度差值不超过1
这里先实现一个辅助函数,计算二叉树的深度;
最后采用递归的思想来完成;
[cpp] view plain copy
  1. class Solution {
  2. public:
  3.     bool isBalanced(TreeNode*  root)
  4.     {
  5.         if (root==NULL)
  6.         {
  7.             return true;
  8.         }
  9.
  10.         int left = help(root->left);
  11.         int right = help(root->right);
  12.
  13.         if (left-right>=-1 && left-right<=1)
  14.         {
  15.             if (isBalanced(root->left) && isBalanced(root->right))
  16.             {
  17.                 return true;
  18.             }
  19.         }
  20.
  21.         return false;
  22.     }
  23.
  24.     int help(TreeNode* root)
  25.     {
  26.         if (root==NULL)
  27.         {
  28.             return 0;
  29.         }
  30.
  31.         if (root->left==NULL && root->right==NULL)
  32.         {
  33.             return 1;
  34.         }
  35.
  36.         return max(help(root->left), help(root->right)) + 1;
  37.     }
  38. };
2018-01-23 09:18:07     打赏
呀~~
楼主这是与国际接轨了
