电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » linked-list-cycle-ii
2018-02-01 13:23:09     打赏
Given a linked list, return the node where the cycle begins. If there is no cycle, returnnull.
Follow up:
Can you solve it without using extra space?
题意:找到循环链表的初始位置。
思路:
1.还是先用快慢指针方法,找出快慢指针相遇的点;
2.重新定义两个指针,一个为head,另一个为相遇的节点;
3.然后两个指针每次走一步,相遇点则是链表环的起点;
[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     ListNode* detectCycle(ListNode* head)
  5.     {
  6.         if (head==NULL)
  7.         {
  8.             return NULL;
  9.         }
  10.
  11.         ListNode* slow = head;
  12.         ListNode* fast = head;
  13.
  14.         while (fast!=NULL && fast->next!=NULL)
  15.         {
  16.             slow = slow->next;
  17.             fast = fast->next->next;
  18.
  19.             if (slow == fast)
  20.             {
  21.                 ListNode* node1 = head;
  22.                 ListNode* node2 = fast;
  23.                 while (node1!=node2)
  24.                 {
  25.                     node1 = node1->next;
  26.                     node2 = node2->next;
  27.                 }
  28.
  29.                 return node1;
  30.             }
  31.         }
  32.
  33.         return NULL;
  34.     }
  35. };
