想要了解嵌入式行业经济发展 & 欧盟工业发展趋势吗?速点>>
电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » Verilog仿真与实际需求不一致,求大神帮看看问题出在na
2018-08-17 14:03:44    评分
需求描述:XB_HIGH_IN输入下降沿时,H_Trig_OUT立即输出一个负脉冲
仿真结果:H_Trig_OUT输出的波形有4个clk的延时,求大神指教是什么导致了这4个clk的延迟
程序代码:
module TESTCODE(
         input XB_HIGH_IN,
         input clk,
         input rst,
         output reg H_Trig_OUT
parameter T100us = 12'd3;
reg  H_fir,H_sec;
reg  H_change_trig;
reg  H_vld;
reg  [11:0]H_count;
always@(posedge clk or negedge rst)
if(!rst)
         begin
         H_fir<=1'b1;
         H_sec<=1'b1;
         H_change_trig<=1'b0;
         end
else
  begin
  H_fir<=XB_HIGH_IN;
  H_sec<=H_fir;
  H_change_trig<=~H_fir&H_sec;//下降沿
  End
//输出负脉冲
always @(posedge clk or negedge rst)
if(!rst)
begin
H_count<=12'd0;
H_vld<=1'b0;
H_Trig_OUT<=1'b1;
end
else
begin
         if(H_change_trig==1'b1)H_vld<=1'b1;
         if(H_vld==1'b1)
         begin
                   H_count<=H_count+1'b1;
                   H_Trig_OUT<=1'b0;
                   if(H_count==T100us)
                            begin
                                     H_count<=12'd0;
                                     H_vld<=1'b0;
                                     H_Trig_OUT<=1'b1;
                            end
         end
end
endmodule
测试代码:
module test;
         // Inputs
         reg XB_HIGH_IN;
         reg clk;
         reg rst;
         // Outputs
         wire H_Trig_OUT;
         // Instantiate the Unit Under Test (UUT)
         TESTCODE uut (
                   .XB_HIGH_IN(XB_HIGH_IN),
                   .clk(clk),
                   .rst(rst),
                   .H_Trig_OUT(H_Trig_OUT)
parameter period =250;///////40MHZ
         initial begin
                   // Initialize Inputs
                   XB_HIGH_IN = 1;
                   clk = 0;
                   rst = 0;
                   // Wait 100 ns for global reset to finish
                   #100;
      rst = 1;
                   // Add stimulus here
                   forever begin
                   #(period/2);
                   clk=~clk;
                   end
         end
  initial begin
                   forever begin
                   #(period*20);
                   XB_HIGH_IN<=1'b1;
                   #(period*20);
                   XB_HIGH_IN<=1'b0;
                   end
         end
endmodule
仿真波形图:
仿真波形图
关键词: Verilog     仿真     不一致     波形
