现在我在vivado中做了一个基于axi总线测量频率的ip核,不知道在sdk中怎么读出频率计数值,
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 2019/07/20 11:04:26
// Design Name:
// Module Name: meas_freq
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module meas_freq(
input clk_100M, //100MHz系统时钟
input square ,
output wire [27:0] CNTCLK, //闸门内系统时钟周期计数
output wire [27:0] CNTSQU //闸门内待测方波时钟周期计数
parameter GATE_TIME = 28'd99_999_999;//实际闸门计数是99_999_999,仿真时设为10ms
reg square_r0 = 1'b0;
reg square_r1 = 1'b0;
reg square_r2 = 1'b0;
reg square_r3 = 1'b0;
reg [27:0] cnt1 = 28'd0; //产生 1s 的闸门信号的计数器
reg gate = 1'b0; //闸门信号
reg gatebuf = 1'b0; //与方波同步之后的闸门信号
reg gatebuf1 = 1'b0;//同步闸门信号延时一拍
reg [27:0] cnt2 = 28'd0;
reg [27:0] cnt2_r = 28'd0;
reg [27:0] cnt3 = 28'd0;
reg [27:0] cnt3_r = 28'd0;
// reg [27:0] CNTCLK= 28'd0;
// reg [27:0] CNTSQU= 28'd0;
wire square_pose,square_nege;
wire gate_start,gate_end;
//使方波和100MHz时钟同步并捕捉待测方波的边沿
always @ (posedge clk_100M)
begin
square_r0 <= square;
square_r1 <= square_r0;//将外部输入的方波打两拍
square_r2 <= square_r1;
square_r3 <= square_r2;
end
assign square_pose = square_r2 & ~square_r3;
assign square_nege = ~square_r2 & square_r3;
begin
IF(cnt1 == GATE_TIME)begin
cnt1 <= 28'd0;
gate <= ~gate;//产生 1s 的闸门信号
end
else begin
cnt1 <= cnt1 + 1'b1;
end
end
always @ (posedge clk_100M )
begin
if(square_pose == 1'b1)begin
gatebuf <= gate;//使闸门信号与待测方波同步,保证一个闸门包含整数个方波周期
end
gatebuf1 <= gatebuf;//将同步之后的闸门信号打一拍,用于捕捉闸门信号的边沿
end
assign gate_start = gatebuf & ~gatebuf1;//表示闸门开始时刻
assign gate_end = ~gatebuf & gatebuf1;//闸门结束时刻
//计数系统时钟周期
begin
if(gate_start == 1'b1)begin
cnt2 <= 28'd1;
end
else if(gate_end == 1'b1)begin
cnt2_r <= cnt2;//将所得结果保存在cnt2_r中,并将计数器清零
cnt2 <= 28'd0;
end
else if(gatebuf1 == 1'b1)begin//在闸门内计数系统时钟周期
cnt2 <= cnt2 + 1'b1;end
end
//计数待测方波周期数
begin
cnt3 <= 28'd0;
end
cnt3_r <= cnt3;//将所得结果保存在cnt3_r中,并将计数器清零
cnt3 <= 28'd0;
end
else if(gatebuf1 == 1'b1 && square_nege == 1'b1)begin//在闸门内计数待测方波周期数(数闸门内方波的下降沿)
cnt3 <= cnt3 + 1'b1;
end
end
assign CNTCLK = cnt2_r;
assign CNTSQU = cnt3_r;
endmodule
共3条
vivado中自定义IP应用
共3条
