在使用gdbserver时,出现以下错误:
uclinux端:
/var/tmp> gdbserver :3000 hello
Process hello created; pid = 26
code at 0025a058 - 0025dbf8, data at 0025dbf8
Remote debugging using :3000
readchar: Got EOF
Remote side has terminated connection. GDBserver will reopen the connection.
远程linux端:
[root@vivian test]# gdb hello.gdb
GNU gdb Red Hat Linux (5.3post-0.20021129.18rh)
Copyright 2003 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "i386-redhat-linux-gnu"...
(gdb) target remote 10.192.192.166:3000
Remote debugging using 10.192.192.166:3000
Couldn't establish connection to remote target
Reply contains invalid hex digit 59
(gdb)
哪位大虾能给点指导啊,这是什么问题?
问题已经解决了!由于板子用的是68k系列,Linux端应该用m68k-elf-gdb.hello和hello.gdb都是由m68k-elf-gcc编译生成的。
[align=right][color=#000066][此贴子已经被作者于2004-9-7 15:24:58编辑过][/color][/align]
| OrangePiZero2W系统被打赏¥33元 | |
