Hello, expert I've encountered an issue. This happens on a 32-bits 133MHzMIPS platform with Tornado2.2 I use the Tornado project environment to generate the run-time image "vxWorks_romCompress".It's 1Mbytes
in size. I burn it onto my 2M Flash memory. But after I started the system only
Attached TCP/IP interface to motfec unit 0
Atta
printed on the screen by COM1. Then system's dead. I think there may be something wrong with the Ram address allocation.Because a 9Mbytes application can be
compressed with the BSP,VxWorks, and run successfully in standalone mode. My application is 13Mbytes in archive format. Maybe something wrong when uncompressed code put onto the
Ram. The address allocation is:
Atta
---------------------- 0x02000000 = RAM_SIZE = RamTop | | | | | | | | | | | ROM image | |--------------------| 0x01C80000 = RAM_HIGH_ADRS | | | | | | | | | | | | |--------------------| | | | 0x00001000 = RAM_ADRS & RAM_LOW_ADRS | | | | exc vectors, bp anchor, exc msg, bootline | | | | ------------------ 0x00000000 = LOCAL_MEM_LOCAL_ADRS
But i don't know the uncompression process of VxWorks_RomCompress, and the location of the uncompressed
code in RAM.
So can you tell me where could the problem reside?
Or can you tell me more about the uncompression process.
THANKS A LOT.
