下面是我捕捉的数据,各位高手能否帮忙解决一下
./src/include,./src/include/lwip,./src/include/netif,./src/include/ipv6/lwip,./src/include/ipv4/lwip,./src/arch/msvc6/include
code:0x4A CHAT sending 'AT&F&C1&D2' CHAT expecting 'OK' CHAT -- got it CHAT aborting on 'BUSY' CHAT aborting on 'NO CARRIER' CHAT timeout set to 60 seconds CHAT sending '\dATDT \T' CHAT expecting 'CONNECT' CHAT -- got it CHAT delaying 2 seconds CHAT layer up making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=0, len=24 PPP/LCP ReqSent: rcvd ConfReq, id=16, len=29 checking MRU=1500 LCP REQ: result=ConfAck, option=01, length=4 making MRU=1500 checking ACCM=0x000A0000 LCP REQ: result=ConfAck, option=02, length=6 making ACCM=0x000A0000 checking Auth Protocol=0xC023 LCP REQ: result=ConfAck, option=03, length=4 making Auth Protocol=0xC023 checking Protocol compression LCP REQ: result=ConfAck, option=07, length=2 making Protocol compression checking Addr/Ctrl compression LCP REQ: result=ConfAck, option=08, length=2 making Addr/Ctrl compression LCP REQ: result=ConfRej, option=11, length=4 making unimplemented type 11 LCP REQ: result=ConfRej, option=13, length=3 making unimplemented type 13 PPP/LCP ReqSent: sent ConfRej, id=16, len=8 PPP/LCP ReqSent: rcvd ConfAck, id=0, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=1, len=24 PPP/LCP ReqSent: rcvd ConfReq, id=16, len=29 checking MRU=1500 LCP REQ: result=ConfAck, option=01, length=4 making MRU=1500 checking ACCM=0x000A0000 LCP REQ: result=ConfAck, option=02, length=6 making ACCM=0x000A0000 checking Auth Protocol=0xC023 LCP REQ: result=ConfAck, option=03, length=4 making Auth Protocol=0xC023 checking Protocol compression LCP REQ: result=ConfAck, option=07, length=2 making Protocol compression checking Addr/Ctrl compression LCP REQ: result=ConfAck, option=08, length=2 making Addr/Ctrl compression LCP REQ: result=ConfRej, option=11, length=4 making unimplemented type 11 LCP REQ: result=ConfRej, option=13, length=3 making unimplemented type 13 PPP/LCP ReqSent: sent ConfRej, id=16, len=8 PPP/LCP ReqSent: rcvd ConfAck, id=1, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=2, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=2, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=3, len=24 PPP/LCP ReqSent: rcvd ConfReq, id=16, len=29 checking MRU=1500 LCP REQ: result=ConfAck, option=01, length=4 making MRU=1500 checking ACCM=0x000A0000 LCP REQ: result=ConfAck, option=02, length=6 making ACCM=0x000A0000 checking Auth Protocol=0xC023 LCP REQ: result=ConfAck, option=03, length=4 making Auth Protocol=0xC023 checking Protocol compression LCP REQ: result=ConfAck, option=07, length=2 making Protocol compression checking Addr/Ctrl compression LCP REQ: result=ConfAck, option=08, length=2 making Addr/Ctrl compression LCP REQ: result=ConfRej, option=11, length=4 making unimplemented type 11 LCP REQ: result=ConfRej, option=13, length=3 making unimplemented type 13 PPP/LCP ReqSent: sent ConfRej, id=16, len=8 PPP/LCP ReqSent: rcvd ConfAck, id=3, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=4, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=4, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=5, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=5, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=6, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=6, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=7, len=24 PPP/LCP ReqSent: rcvd ConfReq, id=16, len=29 checking MRU=1500 LCP REQ: result=ConfAck, option=01, length=4 making MRU=1500 checking ACCM=0x000A0000 LCP REQ: result=ConfAck, option=02, length=6 making ACCM=0x000A0000 checking Auth Protocol=0xC023 LCP REQ: result=ConfAck, option=03, length=4 making Auth Protocol=0xC023 checking Protocol compression LCP REQ: result=ConfAck, option=07, length=2 making Protocol compression checking Addr/Ctrl compression LCP REQ: result=ConfAck, option=08, length=2 making Addr/Ctrl compression LCP REQ: result=ConfRej, option=11, length=4 making unimplemented type 11 LCP REQ: result=ConfRej, option=13, length=3 making unimplemented type 13 PPP/LCP ReqSent: sent ConfRej, id=16, len=8 PPP/LCP ReqSent: rcvd ConfAck, id=7, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=8, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=8, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=9, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=9, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=10, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=10, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=11, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=11, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=12, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=12, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=13, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=13, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=14, len=24 PPP/LCP ReqSent: rcvd ConfAck, id=14, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression PPP/LCP ReqSent: sent ConfReq, id=15, len=24 PPP/LCP ReqSent: rcvd ConfReq, id=16, len=29 checking MRU=1500 LCP REQ: result=ConfAck, option=01, length=4 making MRU=1500 checking ACCM=0x000A0000 LCP REQ: result=ConfAck, option=02, length=6 making ACCM=0x000A0000 checking Auth Protocol=0xC023 LCP REQ: result=ConfAck, option=03, length=4 making Auth Protocol=0xC023 checking Protocol compression LCP REQ: result=ConfAck, option=07, length=2 making Protocol compression checking Addr/Ctrl compression LCP REQ: result=ConfAck, option=08, length=2 making Addr/Ctrl compression LCP REQ: result=ConfRej, option=11, length=4 making unimplemented type 11 LCP REQ: result=ConfRej, option=13, length=3 making unimplemented type 13 PPP/LCP ReqSent: sent ConfRej, id=16, len=8 PPP/LCP ReqSent: rcvd ConfAck, id=15, len=24 making MRU=1500 making ACCM=0x000A0000 making Magic Number=0x167E41C6 making Protocol compression making Addr/Ctrl compression LCP ACK: valid PPP/LCP AckRcvd; Timeout PPP/LCP AckRcvd; Request retry exceeded CHAT delaying 1 seconds CHAT sending '+++' CHAT delaying 1 seconds CHAT expecting 'OK'
