共1条
电子通讯计算机专业--最佳工作机会(shanghai)-更新后(补充)
只看楼主 1楼
Manufacturing Test Engineer
发布日期:2005-11-02 工作地点:上海市
招聘人数:2 工作年限:二年以上
薪水范围:面议 外语要求:英语 熟练
接受简历语言:中文或英文
职位描述:
Description:
A Manufacturing test engineer is responsible for guaranteeing specific product platforms are
tested from an ICT, Functional, System, and extended temperature perspective. The goal is to
achieve 100% coverage and confidence that the production product shipped will work as intended
under product requirement guidelines. The Manufacturing test Engineer position requires the
engineer to be familiar with telecommunications protocols such as SONET, Ethernet, DS3, and DS1
as well as basic IP and LAN network topologies.
NI Labview and TestStand will be utilized by the manufacturing test engineer to automate tests
at functional, system, and extended temperature test areas. Interaction with Operations for
testing handoff and debug is required as well as interaction with the contract manufacturer for
ICT installation and support. The Manufacturing test engineer should be familiar with all
aspects of testing process including, but not limited to and writing automated scripts/drivers,
design for test methodology, design for manufacturing, nodal/net coverage analysis, reading
schematics, reading system requirements documents, and boundary scan technology.
Candidate Background:
NI Labview and Teststand code development and debug experience
Test equipment driver experience
SONET and Ethernet experience
Scripting using Perl, Tcl/Tk, or C++
Ability to read schematics
Boundary scan BSDL
Familiar with ICT process and implementation at the CM
Manager of Manufacturing (Asia)
招聘人数:1 学 历:本科
工作年限:五年以上 薪水范围:面议
外语要求:英语 熟练 接受简历语言:中文和英文
职位描述:
Description:
Candidates must have a minimum of five years of experience providing interface work between
their company and an external Contract Manufacturer (CM). Prior experience should include
generating Requests For Proposals (RFP) for full turn-key manufacturing projects using CMs.
Currently, White Rick Networks USA is using Solectron as its CM and wishes to begin using a
similar Shanghai based CM for manufacturing.
The candidate will be responsible for coordinating all aspects of the manufacturing flow
between White Rock and the CM. This will include RFP, Bill of Material (BOM) management, test
requirements and design coordination, tracking yield and suggesting improvements, and
maintaining competitive analysis on other CM alternatives. The goal is to drop ship released
products from the CM to the customer.
Today, White Rock has one project ready to go to a local CM and depending upon its success, the
company is prepared to move all of its product line to China. This is a great opportunity for
someone to prove their capability and then grow with the position.
You must have extensive knowledge of Oracle in order to perform this job. All White Rock BOMs
are Oracle based and all part number tracking and ordering is through Oracle. Candidates
without Oracle experience need not apply as they will not be considered. The preferred
candidate is someone who is an upper-middle level team member of a company currently performing
the same goals with a CM. Long term success could lead to a Vice President of Manufacturing
(Asia) title and a supporting organization.
Alternatively, a candidate working at a large CM performing similar function (like PM or
Program Director) would be desirable. In either case you will need strong English speaking
skills as you will interface with the USA manufacturing group extensively. You must also be
able to work with minimal direction and in a remote capacity. The position will report to the
China General Manager and have a dotted line to the USA Vice President of Manufacturing.
Senior Level Element Management Software Engineer
招聘人数:1 学 历:本科
工作年限:五年以上 薪水范围:面议
职位描述:
Description:
Candidates will have a minimum of five years of experience in requirements analysis, design,
implementation and delivery of object-oriented, distributed software systems in a Java
development environment. Experience developing element management software is highly desired.
Candidates will be responsible for independently taking a feature all the way from design to
implementation and test. This will require technical strength and the ability to interact with
the team to ensure other features are integrated with the overall system.
Candidates will require excellent communications skills in Mandarin and average communication
skills in English to be able to translate system requirements to actual software design and to
effectively understand, debug and correct problems faced by the teams in China and the USA.
Candidates will require experience and knowledge of standard software development processes and
methodologies, and have a high commitment to software quality. Hands-on experience is required
in at least two of the following areas:
GUI design and implementation using Java Swing, HTML, Javascript.
TL1, SNMP, CMIS/CMIP.
Oracle 9i, JDBC, object-relational mapping tools.
Development of Java components using J2EE (EJB, JSP, Servlets).
Development in both Unix and Windows environments.
TMN knowledge including Fault, Configuration, Accounting, Performance, Security (FCAPS) areas.
A bachelor's or master's degree in electrical engineering or computer science is required, and
development experience in both Unix and Windows environments is highly desired.
High Speed Digital Design Engineer
招聘人数:3 学 历:本科
工作年限:二年以上 薪水范围:面议
接受简历语言:英文
职位描述:
Description:
Candidates will have a minimum of two years of experience in the design and development of
high-speed digital electrical design of complex circuit packs. He/she should be familiar with
CAD design systems, preferably Cadence, for schematic capture, signal analysis, and PCB layout
Candidates will be responsible for independently taking portions of a subsystem all the way
from design to implementation and test. This will require technical strength and the ability to
interact with the team to insure other subsystem parts are integrated with the overall system.
Candidates will require excellent communications skills in Mandarin and basic communication
skills in English to be able to translate system requirements to actual hardware design and to
Candidates will require knowledge of standard hardware development processes and methodologies,
and have a high commitment to hardware quality. Hands-on experience with embedded processors
and exposure to developing and debugging hardware/software is required as well as exposure to
use of emulators, BDM’s, logic-analyzers, etc.
A bachelor's or master's degree in electrical or computer engineering is required, with
experience in PowerPC, SONET, EoS, DS3, and DS1 standards highly desired.
System Test Automation Engineers
招聘人数:2 学 历:本科
工作年限:一年以上 薪水范围:面议
外语要求:英语 熟练 接受简历语言:英文
职位描述:
Description
Design, create, and execute automated test scripts for Telecommunications
equipment. Job entails analyzing and writing automated Perl scripts from manual test cases,
creating interface libraries to test equipment, and designing and creating tools to aid the
test organization. Candidate should have strong programming skills, be able to handle sockets
(Telnet, FTP), objects, and data structures. Knowledge of TL1 specification/syntax is helpful.
Prior software testing experience preferred. Knowledge of SDH/SONET and Ethernet
hardware/software integration is a plus. White Rock is looking for people that have a strong
desire to learn, work in a multi-national environment, and advance their career.
Preferred Experience:
1 Previous telecommunications equipment testing experience
2 Strong knowledge of the Perl or other programming language
3 Understanding of sockets, objects, libraries, and data structures
4 Experience with TL1 specifications/syntax
5 Knowledge in Tcl and Tk helpful
6 Telecom protocol knowledge in MLPPP, Frame Relay, Qos, VLAN, E3, DS3, E1, T1, Ethernet
7 Working experience with Smartbits, Adtech, Agilent, and HP Omniber test sets
8 Able to work in a fast paced and team environment
9 Must have better than average English verbal and written skills
ASIC Design/Verification Engineer
招聘人数:9 学 历:本科
工作年限:五年以上 薪水范围:面议
接受简历语言:中文或英文
职位描述:
Description:
Write, maintain and verify VHDL RTL code to meet functional specifications. Detailed knowledge
of SONET (STS and VT processing) or SDH standards is preferred. Synthesis and static timing
analysis (Synopsys Primetime) experience is required. Candidate should be well versed in
efficient, high speed, synchronous design techniques. C and Perl programming skills desired.
Experience with System C, PLI/FLI and QuickBench experience is also highly desirable.
Essential Duties & Responsibilities:
§ Create/maintain VHDL RTL designs to meet functional specifications
§ Provide synthesis and physical design support
§ Static Timing Analysis
§ Write and execute a verification test plan
§ Create and automate test cases using C and Perl languages
§ Able to work in a team environment
§ Must have good English verbal and written skills
Real Time Embedded Software Engineer
招聘人数:25 学 历:本科
工作年限:三年以上 薪水范围:面议
外语要求:英语 良好 接受简历语言:英文
职位描述:
Description:
Candidates will be responsible for independently taking a subsystem all the way from design to
the team to insure subsystems are integrated with the overall system.
Candidates will require knowledge of standard software development processes and methodologies,
and have a high commitment to software quality. Hands-on experience with embedded processors
and RTOS, C and assembler languages, with exposure to developing and debugging low-level
(interrupts/hardware-access) multitasking/multiprocessing, shared-memory and message-passing
programming is required as well as exposure to use of emulators, BDMs, logic-analyzers, etc.
A bachelor's or master's degree in electrical engineering or computer science is required, with
experience in SONET, IP/OSI/datacomm stacks and protocols, OSE and/or VxWorks, and PowerPC
highly desired.
Hardware Engineering Manager
招聘人数:1 学 历:本科
工作年限:五年以上 薪水范围:面议
接受简历语言:英文
职位描述:
Description:
Candidates will have a minimum of five years of direct experience in the design and development
of high-speed digital electrical design of complex circuit packs. He/she should be familiar
with CAD design systems, preferably Cadence, for schematic capture, signal analysis, and PCB
layout
Candidates will be responsible for leading and coaching engineers in taking portions of a
subsystem all the way from design to implementation and test. This will require technical
strength and the ability to interact with the team members to insure other subsystem parts are
The Hardware manager will be responsible for schedule planning, recruiting, and staff
development.
Candidates should have prior management but outstanding candidates with successful team
leadership roles will be considered. This job requires great leadership potential, strong
technical knowledge, strong ethics, the ability and desire to mentor younger engineers, and the
desire to work with your peers in the United States.
The position will report to the Director of Hardware/ASIC who is located in the USA so it is
critical that the candidate be self-motivated, highly organized, and have average to good
English skills.
A bachelor's or master's degree in electrical engineering is required.
关键词: 电子 通讯 计算机 专业 最佳 工作机会 shan
共1条
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
打赏帖 | |
玩转“DFRobot盖革计数器模块”准备工作认识模块知识分享被打赏30分 | |
老胖子聊电路--分析一个反馈电路被打赏50分 |
