共3条
1/1															1							跳转至页
		ICCAVR,V6,30B,M169,M8 最新的ICCAVR V6.30B。特别指出M169可以开发了,已有货;M8细化了
  02/05/2004 - V6.30B
IDE
- AppBuilder fixes for M169 LCD
- Scroll mouse now works correctly under all OS and mouse brands
Compiler
- Fixed a bug where the compiler was not copying stacked arguments to
registers if the function is a MONITOR function (normal functions are
fine).
- The debug line information was accidentally foobar'ed for the body
of for loops. This affected listing file and the debug information
Library
- Fixed bug in cstrncmp (thanks JA)
Utilities
- Include ICCAVRMapFileSummy.exe (thanks JA)
01/17/2004 - V6.30A
IDE
- Added device support for ATMega48, M88, and M168. No support for ISP
and AppBuilder yet.
- Changed STK500 ISP Lock/Fuse Bits write to encode the bit values in
HEX as required by the stk500.exe program
Header Files
- Added iom48v.h, iom88v.h, and iom168v.h (once again thanks to JA) 答 1: 请教双龙: TQFP32的M8是否都是带L的?带L的M8在5V供电时是否能在16MHZ下长期正常工作?
答 2: M169价格是多少?不能有了就行啊,知道价格和才能决定用还是不用 答 3: 又更新了 答 4: 这个ATMEL不要整得跟瘟到死一样好不好。产品老是不定型谁敢用啊。 答 5: 鉴于M8的销售势头良好,从容量、开发工具考虑推出M48、M88、M168系列芯片,管脚与M8兼容,增加单线调试功能,解决仿真问题。
推出M48,主要从价格出发,容量小一半,价格更便宜。这款优先推出。
M88与M8基本一致,功能略有增加,以上芯片同时销售。
					IDE
Compiler
fine).
Library
Utilities
01/17/2004 - V6.30A
IDE
and AppBuilder yet.
Header Files
共3条
1/1															1							跳转至页
