共3条
TCL2543 求TCL2543的程序-以前有过这样的帖子,可现在找不到了
答 1:
希望能对你有用#include <reg52.h>
#include <stdio.h>
#include <intrins.h>
#define uchar unsigned char
#define ulong unsigned long
#define uint unsigned int
extern delay(uchar d_time);
sbit cl_1543 = P1^2;
sbit di_1543 = P1^3;
sbit do_1543 = P1^4;
sbit cs_1543 = P1^5;
uint ad_1543(uchar port){ //括号里面的参数为地址参数
uint data ad_date;uchar data i,ad_temp;
ad_date = 0;
cl_1543=0;
delay(5);
cs_1543=0;
do_1543 = 1;
port<<=4;
ad_date = 0;
for (i=0;i<4;i++) //把通道号打入1543
if(port&0x80){di_1543 = 1;}
else{di_1543 = 0;}
cl_1543=1;
delay(5);
cl_1543=0;
port<<=1;
ad_date <<=1;
if (do_1543) ad_date |= 0x0001;
else ad_date &= 0xfffe;
for (i=0;i<6;i++)
ad_date <<=1;
cl_1543=1;
delay(5);
cl_1543=0;
cs_1543 = 1;
//ad_date &= 0xfffe;
//ad_date >>=2;
ad_temp = ad_date;
return (ad_date);
答 2: 谢谢,我明天就试试
#include <stdio.h>
ad_date = 0;
cl_1543=0;
delay(5);
cs_1543=0;
do_1543 = 1;
port<<=4;
ad_date = 0;
else{di_1543 = 0;}
cl_1543=1;
delay(5);
cl_1543=0;
port<<=1;
ad_date <<=1;
for (i=0;i<6;i++)
ad_date <<=1;
cl_1543=1;
delay(5);
cl_1543=0;
cs_1543 = 1;
//ad_date >>=2;
ad_temp = ad_date;
return (ad_date);
答 2: 谢谢,我明天就试试
共3条
