ADS1 ADS1.2中怎么嵌入汇编语言呢?
各位大哥:
有个问题我不太明白,请问在ADS1。2的C编译环境下,怎么嵌入汇编程序呢?怎么调用由汇编语言做的函数呢?请指点一二,谢谢 答 1: 请教下面是热心的网友回复我,但是编译出错,请问是什么问题呢?
很多资料书籍都有介绍,方法如下:
__ARM
LDR R5,[R6]
答 2: 错误代码如下:
OS_ENTER_CRITICAL();
__ARM
LDR R5,[R6]
MRS r0, cpsr
temp =0x1234;
出错:
Error : C2456E: undeclared name, inventing 'extern int __ARM'
Main.c line 558
Error : (Serious) C2284E: expected ';' after command - inserted before '{'
Main.c line 558
Error : C2456E: undeclared name, inventing 'extern int LDR'
Main.c line 559
Error : (Serious) C2284E: expected ';' after command - inserted before 'R5'
Main.c line 559
Error : C2456E: undeclared name, inventing 'extern int R5'
Main.c line 559
Error : (Serious) C2291E: <expression> expected but found ''
Main.c line 559
Error : C2456E: undeclared name, inventing 'extern int R6'
Main.c line 559
Error : (Serious) C2284E: expected ';' after command - inserted before 'MRS'
Main.c line 560
Error : C2456E: undeclared name, inventing 'extern int MRS'
Main.c line 560
Error : (Serious) C2284E: expected ';' after command - inserted before 'r0'
Main.c line 560
Error : C2456E: undeclared name, inventing 'extern int r0'
Main.c line 560
Error : C2456E: undeclared name, inventing 'extern int cpsr'
Main.c line 561
Error : (Serious) C2284E: expected ';' after command - inserted before '}'
Main.c line 561
答 3: __asm 答 4: 哪位大哥指点一下吧哪位大哥指点一下吧 答 5: 不是告诉你了吗?把__ARM改成__asm就可以了 答 6: re__ARM -> __asm 答 7: 好了,请各位参考总算改好了,谢谢em_ldbb大哥,twentyone 大哥的指点。 下面贴出来让还有疑问的兄弟参考。
_asm
LDR R5,[R6] ;
ORR r0, r0, #0xC0 ;
很多资料书籍都有介绍,方法如下:
__ARM
LDR R5,[R6]
答 2: 错误代码如下:
__ARM
LDR R5,[R6]
MRS r0, cpsr
temp =0x1234;
出错:
Main.c line 558
Main.c line 558
Main.c line 559
Main.c line 559
Main.c line 559
Main.c line 559
Main.c line 559
Main.c line 560
Main.c line 560
Main.c line 560
Main.c line 560
Main.c line 561
Main.c line 561
_asm
LDR R5,[R6] ;
ORR r0, r0, #0xC0 ;
