Setup,IRQ,handler Setup IRQ handler,不懂
; * NAME : 44BINIT.S *
; * Version : 10.April.2000 *
; * Description: *
; * C start up codes *
; * Configure memory, Initialize ISR ,stacks *
; * Initialize C-variables *
; * Fill zeros into zero-initialized C-variables *
GET ..\inc\option.s
GET ..\inc\memcfg.s
;Memory Area
;GCS6 16bit(2MB) SDRAM(0xc000000-0xc1fffff)
;INTTABLE =0xc1fff00~0xc1fffff
;STACK =0xc7ffa00
;Interrupt Control
INTPND EQU 0x01e00004
INTMOD EQU 0x01e00008
INTMSK EQU 0x01e0000c
I_ISPR EQU 0x01e00020
I_CMST EQU 0x01e0001c
;Watchdog timer
WTCON EQU 0x01d30000
;Clock Controller
PLLCON EQU 0x01d80000
CLKCON EQU 0x01d80004
LOCKTIME EQU 0x01d8000c
;Memory Controller
REFRESH EQU 0x01c80024
;BDMA destination register
BDIDES0 EQU 0x1f80008
BDIDES1 EQU 0x1f80028
;Pre-defined constants
USERMODE EQU 0x10
FIQMODE EQU 0x11
IRQMODE EQU 0x12
SVCMODE EQU 0x13
ABORTMODE EQU 0x17
UNDEFMODE EQU 0x1b
MODEMASK EQU 0x1f
NOINT EQU 0xc0
PDATE EQU 0x1d2002C ;LEE
PCONE EQU 0x1d20028 ;LEE
;check if tasm.exe is used.
GBLL THUMBCODE
[ {CONFIG} = 16
THUMBCODE SETL {TRUE}
CODE32
THUMBCODE SETL {FALSE}
[ THUMBCODE
CODE32 ;for start-up code for Thumb mode
MACRO
$HandlerLabel HANDLER $HandleLabel
$HandlerLabel
sub sp,sp,#4 ;decrement sp(to store jump address)
stmfd sp!,{r0} ;PUSH the work register to stack(lr does't push because it return to original address)
ldr r0,=$HandleLabel ;load the address of HandleXXX to r0
ldr r0,[r0] ;load the contents(service routine start address) of HandleXXX
str r0,[sp,#4] ;store the contents(ISR) of HandleXXX to stack
ldmfd sp!,{r0,pc} ;POP the work register and pc(jump to ISR)
MEND
IMPORT |Image$$RO$$Limit| ; End of ROM code (=start of ROM data)
IMPORT |Image$$RW$$Base| ; Base of RAM to initialise
IMPORT |Image$$ZI$$Base| ; Base and limit of area
IMPORT |Image$$ZI$$Limit| ; to zero initialise
IMPORT Main ; The main entry of mon program
AREA Init,CODE,READONLY
ENTRY
b ResetHandler ;for debug
b HandlerUndef ;handlerUndef
b HandlerSWI ;SWI interrupt handler
b HandlerPabort ;handlerPAbort
b HandlerDabort ;handlerDAbort
b . ;handlerReserved
b HandlerIRQ
b HandlerFIQ
;***IMPORTANT NOTE***
;If the H/W vectored interrutp mode is enabled, The above two instructions should
;be changed like below, to work-around with H/W bug of S3C44B0X interrupt controller.
; b HandlerIRQ -> subs pc,lr,#4
VECTOR_BRANCH
ldr pc,=HandlerEINT0 ;mGA H/W interrupt vector table
ldr pc,=HandlerEINT1 ;
ldr pc,=HandlerEINT2 ;
ldr pc,=HandlerEINT3 ;
ldr pc,=HandlerEINT4567 ;
ldr pc,=HandlerTICK ;mGA
b .
b .
ldr pc,=HandlerZDMA0 ;mGB
ldr pc,=HandlerZDMA1 ;
ldr pc,=HandlerBDMA0 ;
ldr pc,=HandlerBDMA1 ;
ldr pc,=HandlerWDT ;
ldr pc,=HandlerUERR01 ;mGB
b .
b .
ldr pc,=HandlerTIMER0 ;mGC
ldr pc,=HandlerTIMER1 ;
ldr pc,=HandlerTIMER2 ;
ldr pc,=HandlerTIMER3 ;
ldr pc,=HandlerTIMER4 ;
ldr pc,=HandlerTIMER5 ;mGC
b .
b .
ldr pc,=HandlerURXD0 ;mGD
ldr pc,=HandlerURXD1 ;
ldr pc,=HandlerIIC ;
ldr pc,=HandlerSIO ;
ldr pc,=HandlerUTXD0 ;
ldr pc,=HandlerUTXD1 ;mGD
b .
b .
ldr pc,=HandlerRTC ;mGKA
b . ;
b . ;
b . ;
b . ;
b . ;mGKA
b .
b .
ldr pc,=HandlerADC ;mGKB
b . ;
b . ;
b . ;
b . ;
b . ;mGKB
b .
b .
;0xe0=EnterPWDN
ldr pc,=EnterPWDN
LTORG
HandlerFIQ HANDLER HandleFIQ
HandlerIRQ HANDLER HandleIRQ
HandlerUndef HANDLER HandleUndef
HandlerSWI HANDLER HandleSWI
HandlerDabort HANDLER HandleDabort
HandlerPabort HANDLER HandlePabort
HandlerADC HANDLER HandleADC
HandlerRTC HANDLER HandleRTC
HandlerUTXD1 HANDLER HandleUTXD1
HandlerUTXD0 HANDLER HandleUTXD0
HandlerSIO HANDLER HandleSIO
HandlerIIC HANDLER HandleIIC
HandlerURXD1 HANDLER HandleURXD1
HandlerURXD0 HANDLER HandleURXD0
HandlerTIMER5 HANDLER HandleTIMER5
HandlerTIMER4 HANDLER HandleTIMER4
HandlerTIMER3 HANDLER HandleTIMER3
HandlerTIMER2 HANDLER HandleTIMER2
HandlerTIMER1 HANDLER HandleTIMER1
HandlerTIMER0 HANDLER HandleTIMER0
HandlerUERR01 HANDLER HandleUERR01
HandlerWDT HANDLER HandleWDT
HandlerBDMA1 HANDLER HandleBDMA1
HandlerBDMA0 HANDLER HandleBDMA0
HandlerZDMA1 HANDLER HandleZDMA1
HandlerZDMA0 HANDLER HandleZDMA0
HandlerTICK HANDLER HandleTICK
HandlerEINT4567 HANDLER HandleEINT4567
HandlerEINT3 HANDLER HandleEINT3
HandlerEINT2 HANDLER HandleEINT2
HandlerEINT1 HANDLER HandleEINT1
HandlerEINT0 HANDLER HandleEINT0
;One of the following two routines CAN be used for non-vectored interrupt.
IsrIRQ ;using I_ISPR register.
sub sp,sp,#4 ;reserved for PC
stmfd sp!,{r8-r9}
;IMPORTANT CAUTION
;if I_ISPC isn't used properly, I_ISPR CAN be 0 in this routine.
ldr r9,=I_ISPR
ldr r9,[r9]
;cmp r9, #0x0 ;If the IDLE mode work-around is used,r9 may be 0 sometimes.
;beq %F2 ;move by lee
mov r8,#0x0
0
movs r9,r9,lsr #1
bcs %F1
add r8,r8,#4
b %B0
1
ldr r9,=HandleADC
add r9,r9,r8
ldr r9,[r9]
str r9,[sp,#8]
ldmfd sp!,{r8-r9,pc}
;2
;ldmfd sp!,{r8-r9}
;add sp,sp,#4
;subs pc,lr,#4
;* START *
ResetHandler
ldr r0,=WTCON ;watch dog disable
ldr r1,=0x0
str r1,[r0]
ldr r0,=INTMSK
ldr r1,=0x07ffffff ;all interrupt disable
str r1,[r0]
;* Set clock control registers *
ldr r0,=LOCKTIME
ldr r1,=0xfff
str r1,[r0]
[ PLLONSTART
ldr r0,=PLLCON ;temporary setting of PLL
ldr r1,=((M_DIV<<12)+(P_DIV<<4)+S_DIV) ;Fin=10MHz,Fout=60MHz
str r1,][r0]
ldr r0,=CLKCON
ldr r1,=0x7ff8 ;All unit block CLK enable
str r1,[r0]
;* change BDMACON reset value for BDMA *
ldr r0,=BDIDES0
ldr r1,=0x40000000 ;BDIDESn reset value should be 0x40000000
str r1,[r0]
ldr r0,=BDIDES1
str r1,[r0]
;* Set memory control registers *
ldr r0,=SMRDATA
ldmia r0,{r1-r13}
ldr r0,=0x01c80000 ;BWSCON Address
stmia r0,{r1-r13}
;* Initialize stacks *
ldr sp, =SVCStack ;Why?
bl InitStacks
;* Setup IRQ handler *
ldr r0,=HandleIRQ ;This routine is needed
ldr r1,=IsrIRQ ;if there isn't 'subs pc,lr,#4' at 0x18, 0x1c
str r1,[r0]
;* Copy and paste RW data/zero initialized data *
LDR r0, =|Image$$RO$$Limit| ; Get pointer to ROM data
LDR r1, =|Image$$RW$$Base| ; and RAM copy
LDR r3, =|Image$$ZI$$Base|
;Zero init base => top of initialised data
CMP r0, r1 ; Check that they are different
BEQ %F1
0
CMP r1, r3 ; Copy init data
LDRCC r2, [r0], #4 ;--> LDRCC r2, [r0] + ADD r0, r0, #4
STRCC r2, [r1], #4 ;--> STRCC r2, [r1] + ADD r1, r1, #4
BCC %B0
1
LDR r1, =|Image$$ZI$$Limit| ; Top of zero init segment
MOV r2, #0
2
CMP r3, r1 ; Zero init
STRCC r2, [r3], #4
BCC %B2
[ :LNOT:THUMBCODE
B Main ;Don't use main() because ......
B .
[ THUMBCODE ;for start-up code for Thumb mode
orr lr,pc,#1
bx lr
CODE16
b Main ;Don't use main() because ......
b .
CODE32
;* The function for initializing stack *
InitStacks
;Don't use DRAM,such as stmfd,ldmfd......
;SVCstack is initialized before
;Under toolkit ver 2.50, 'msr cpsr,r1' CAN be used instead of 'msr cpsr_cxsf,r1'
mrs r0,cpsr
bic r0,r0,#MODEMASK
orr r1,r0,#UNDEFMODE|NOINT
msr cpsr_cxsf,r1 ;UndefMode
ldr sp,=UndefStack
orr r1,r0,#ABORTMODE|NOINT
msr cpsr_cxsf,r1 ;AbortMode
ldr sp,=AbortStack
orr r1,r0,#IRQMODE|NOINT
msr cpsr_cxsf,r1 ;IRQMode
ldr sp,=IRQStack
orr r1,r0,#FIQMODE|NOINT
msr cpsr_cxsf,r1 ;FIQMode
ldr sp,=FIQStack
bic r0,r0,#MODEMASK|NOINT
orr r1,r0,#SVCMODE
msr cpsr_cxsf,r1 ;SVCMode
ldr sp,=SVCStack
;USER mode is not initialized.
mov pc,lr ;The LR register may be not valid for the mode changes.
;* The function for entering power down mode *
;void EnterPWDN(int CLKCON);
EnterPWDN
mov r2,r0 ;r0=CLKCON
ldr r0,=REFRESH
ldr r3,[r0]
mov r1, r3
orr r1, r1, #0x400000 ;self-refresh enable
str r1, [r0]
nop ;Wait until self-refresh is issued. May not be needed.
nop ;If the other bus master holds the bus, ...
nop ; mov r0, r0
nop
nop
nop
nop
;enter POWERDN mode
ldr r0,=CLKCON
str r2,[r0]
;wait until enter SL_IDLE,STOP mode and until wake-up
ldr r0,=0x10
0 subs r0,r0,#1
bne %B0
;exit from DRAM/SDRAM self refresh mode.
ldr r0,=REFRESH
str r3,[r0]
mov pc,lr
LTORG
SMRDATA DATA
;* Memory configuration has to be optimized for best performance *
;* The following parameter is not optimized. *
;*** memory access cycle parameter strategy ***
; 1) Even FP-DRAM, EDO setting has more late fetch point by half-clock
; 2) The memory settings,here, are made the safe parameters even at 66Mhz.
; 3) FP-DRAM Parameters:tRCD=3 for tRAC, tcas=2 for pad delay, tcp=2 for bus load.
; 4) DRAM refresh rate is for 40Mhz.
;bank0 16bit BOOT ROM 32M
;bank1 8bit USB(PDIUSBD12)
;bank2 16bit IDE
;bank3 16bit net(RTL8019AS)
;bank4 no
;bank5 no
;bank6 16bit SDRAM 8M
;bank7 no
[ BUSWIDTH=16
DCD 0X11110101 ;Bank0=OM][1:0], Bank1~Bank7=16bit
| ;BUSWIDTH=32
DCD 0x22222220 ;Bank0=OM[1:0], Bank1~Bank7=32bit
DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) ;GCS0
DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) ;GCS1
DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) ;GCS2
DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) ;GCS3
DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) ;GCS4
DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) ;GCS5
[ BDRAMTYPE="DRAM"
DCD ((B6_MT<<15)+(B6_Trcd<<4)+(B6_Tcas<<3)+(B6_Tcp<<2)+(B6_CAN)) ;GCS6 check the MT value in parameter.a
DCD ((B7_MT<<15)+(B7_Trcd<<4)+(B7_Tcas<<3)+(B7_Tcp<<2)+(B7_CAN)) ;GCS7
| ;"SDRAM"
DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) ;GCS6
DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) ;GCS7
DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT) ;REFRESH RFEN=1, TREFMD=0, trp=3clk, trc=5clk, tchr=3clk,count=1019
DCD 0x10 ;SCLK power down mode, BANKSIZE 32M/32M
DCD 0x20 ;MRSR6 CL=2clk
DCD 0x20 ;MRSR7
ALIGN
AREA RamData, DATA, READWRITE
^ (_ISR_STARTADDRESS-0x500)
UserStack # 256 ;c1(c7)ffa00
SVCStack # 256 ;c1(c7)ffb00
UndefStack # 256 ;c1(c7)ffc00
AbortStack # 256 ;c1(c7)ffd00
IRQStack # 256 ;c1(c7)ffe00
FIQStack # 0 ;c1(c7)fff00
^ _ISR_STARTADDRESS
HandleReset # 4
HandleUndef # 4
HandleSWI # 4
HandlePabort # 4
HandleDabort # 4
HandleReserved # 4
HandleIRQ # 4
HandleFIQ # 4
;Don't use the label 'IntVectorTable',
;because ARMasm.exe CANn't recognize this label correctly.
;the value is different with an address you think it may be.
;IntVectorTable
HandleADC # 4
HandleRTC # 4
HandleUTXD1 # 4
HandleUTXD0 # 4
HandleSIO # 4
HandleIIC # 4
HandleURXD1 # 4
HandleURXD0 # 4
HandleTIMER5 # 4
HandleTIMER4 # 4
HandleTIMER3 # 4
HandleTIMER2 # 4
HandleTIMER1 # 4
HandleTIMER0 # 4
HandleUERR01 # 4
HandleWDT # 4
HandleBDMA1 # 4
HandleBDMA0 # 4
HandleZDMA1 # 4
HandleZDMA0 # 4
HandleTICK # 4
HandleEINT4567 # 4
HandleEINT3 # 4
HandleEINT2 # 4
HandleEINT1 # 4
HandleEINT0 # 4 ;0xc1(c7)fff84
END
请问下面这个代码由什么用:
str r1,[r0]
答 1: 就是安装IRQ中断处理程序啊!就是安装IRQ中断处理程序啊!相当于把IsrIRQ开始的地址存放到HandleIRQ这个地址上,而HandleIRQ这个地址就是IRQ中断向量地址 答 2: 向量中断VS非向量中断先谢谢kingpoo,我看过S3C44B0X的介绍,上面说如果是向量中断模式的话,当ARM7TDMI受到IRG中断请求时,ARM7TDMI就会执行在0x00000018的指令,然后跳到相应中断的服务程序。上面的程序在0x00000018的指令就是b HandlerIRQ,而这里又把HandleIRQ指向IsrIRQ这个非向量中断处理程序。越搞越糊涂了,请kingpoo和大家再说说看怎么会事? 答 3: 等待回复等待回复。。。 答 4: 说明使用的是非向量中断啊 答 5: 谢谢kingpoo这样就有点可以理解了,谢谢kingpoo。
; * Description: *
GET ..\inc\option.s
GET ..\inc\memcfg.s
;Memory Area
;STACK =0xc7ffa00
;Interrupt Control
;Watchdog timer
;Clock Controller
;Memory Controller
USERMODE EQU 0x10
FIQMODE EQU 0x11
IRQMODE EQU 0x12
SVCMODE EQU 0x13
ABORTMODE EQU 0x17
UNDEFMODE EQU 0x1b
MODEMASK EQU 0x1f
NOINT EQU 0xc0
GBLL THUMBCODE
[ {CONFIG} = 16
CODE32
[ THUMBCODE
MACRO
$HandlerLabel
MEND
ENTRY
b HandlerIRQ
b HandlerFIQ
VECTOR_BRANCH
b .
b .
b .
b .
b .
b .
b .
b .
b . ;
b . ;
b . ;
b . ;
b . ;mGKA
b .
b .
b . ;
b . ;
b . ;
b . ;
b . ;mGKB
b .
b .
;0xe0=EnterPWDN
ldr pc,=EnterPWDN
LTORG
stmfd sp!,{r8-r9}
;IMPORTANT CAUTION
ldr r9,=I_ISPR
ldr r9,[r9]
mov r8,#0x0
0
movs r9,r9,lsr #1
bcs %F1
add r8,r8,#4
b %B0
1
ldr r9,=HandleADC
add r9,r9,r8
ldr r9,[r9]
str r9,[sp,#8]
;2
;ldmfd sp!,{r8-r9}
;add sp,sp,#4
;subs pc,lr,#4
;* START *
ResetHandler
ldr r1,=0x0
str r1,[r0]
ldr r0,=INTMSK
str r1,[r0]
ldr r0,=LOCKTIME
ldr r1,=0xfff
str r1,[r0]
[ PLLONSTART
str r1,][r0]
ldr r0,=CLKCON
str r1,[r0]
ldr r0,=BDIDES0
str r1,[r0]
ldr r0,=BDIDES1
str r1,[r0]
ldr r0,=SMRDATA
ldmia r0,{r1-r13}
stmia r0,{r1-r13}
bl InitStacks
str r1,[r0]
BEQ %F1
0
BCC %B0
1
MOV r2, #0
2
STRCC r2, [r3], #4
BCC %B2
[ :LNOT:THUMBCODE
B .
orr lr,pc,#1
bx lr
CODE16
b .
CODE32
InitStacks
mrs r0,cpsr
bic r0,r0,#MODEMASK
ldr sp,=UndefStack
ldr sp,=AbortStack
ldr sp,=IRQStack
ldr sp,=FIQStack
orr r1,r0,#SVCMODE
ldr sp,=SVCStack
EnterPWDN
ldr r0,=REFRESH
ldr r3,[r0]
mov r1, r3
str r1, [r0]
nop ; mov r0, r0
nop
nop
nop
nop
;enter POWERDN mode
ldr r0,=CLKCON
str r2,[r0]
ldr r0,=0x10
0 subs r0,r0,#1
bne %B0
ldr r0,=REFRESH
str r3,[r0]
mov pc,lr
LTORG
SMRDATA DATA
;bank2 16bit IDE
;bank4 no
;bank5 no
;bank7 no
[ BUSWIDTH=16
| ;BUSWIDTH=32
[ BDRAMTYPE="DRAM"
| ;"SDRAM"
DCD 0x20 ;MRSR7
ALIGN
^ _ISR_STARTADDRESS
HandleReset # 4
HandleUndef # 4
HandleSWI # 4
HandlePabort # 4
HandleDabort # 4
HandleReserved # 4
HandleIRQ # 4
HandleFIQ # 4
;IntVectorTable
HandleADC # 4
HandleRTC # 4
HandleUTXD1 # 4
HandleUTXD0 # 4
HandleSIO # 4
HandleIIC # 4
HandleURXD1 # 4
HandleURXD0 # 4
HandleTIMER5 # 4
HandleTIMER4 # 4
HandleTIMER3 # 4
HandleTIMER2 # 4
HandleTIMER1 # 4
HandleTIMER0 # 4
HandleUERR01 # 4
HandleWDT # 4
HandleBDMA1 # 4
HandleBDMA0 # 4
HandleZDMA1 # 4
HandleZDMA0 # 4
HandleTICK # 4
HandleEINT4567 # 4
HandleEINT3 # 4
HandleEINT2 # 4
HandleEINT1 # 4
END
请问下面这个代码由什么用:
str r1,[r0]
| Chaos-nano:专为低资源单片机设计的轻量级协作式异步操作系统(ATMEGA328P轻量级操作系统)—— 详细介绍被打赏¥16元 | |
| FPGA配置被打赏¥10元 | |
| Chaos-nano协作式异步操作系统:赋能MicrochipAVR8位单片机的革新之路被打赏¥15元 | |
| 基于esp32开发时串口工具的注意点被打赏¥24元 | |
| 基于FireBeetle2ESP32-C5开发板的舵机控制被打赏¥20元 | |
| 【分享开发笔记,赚取电动螺丝刀】MAX78000开发板制作的电子相册被打赏¥32元 | |
| 基于FireBeetle2ESP32-C5开发板的超声波测距及显示被打赏¥21元 | |
| FireBeetle2ESP32-C5上RTC电子时钟的实现被打赏¥25元 | |
| 【分享开发笔记,赚取电动螺丝刀】MAX78000开发板读取SD卡被打赏¥23元 | |
| 【S32K3XX】Standby RAM 重启后数据异常问题调查被打赏¥38元 | |
