1/1															1							跳转至页
		LPC213X,214X 没有道理啊。。学过深入浅出LPC213X/214X书的朋友请看下。
  书上P366原程序(看门狗益出复位实验程序),我把它照书抄一遍,运行和
ZLG给的不一样,,真是没有道理啊。。。救救我啊。。
原抄的程序如下:
#include "config.h"
#define BEEP 1<<7
#define LED1 1<<18
#define KEY1 1<<16
#define KEY2 1<<17
int main(void)
uint32 i,j;
PINSEL0 = 0x0;
PINSEL2 = PINSEL2&(~0x08);
IO0DIR = BEEP;
IO1DIR = LED1;
IO0SET = BEEP;
while((WDMOD&0x04) == 0x04)
for(j=0;j<0xFFFFF;j++);
if((IO0SET&BEEP) == 0)
IO0SET = BEEP;
if((IO0PIN& KEY2 ) == 0)
WDMOD = 0x00;
else
IO0CLR = BEEP;
WDTC = 0xFF000;
WDMOD = 0x03;
WDFEED = 0xAA;
WDFEED = 0x55;
while(1)
while((IO0PIN&KEY1) == 0);
for(j = 0;j<0x0FF;j++)
for(i = 0;i<0x0FFF;i++)
WDFEED = 0xAA;
WDFEED = 0x55;
if((IO1SET&LED1) == 0)
IO1SET = LED1;
else
IO1CLR = LED1;
} 答 1: 喂狗馈送序列被你人为地分开了 for(i = 0;i<0x0FFF;i++)
WDFEED = 0xAA;
WDFEED = 0x55;
等效为:
for(i = 0;i<0x0FFF;i++){
WDFEED = 0xAA;
WDFEED = 0x55;
是抄错了吧.喂狗馈送序列被你人为地分开了... 答 2: re:您抄错了:
WDFEED = 0xAA;
WDFEED = 0x55;
原文为:
for(j = 0;j<0x0FF;j++) //LED1闪烁周期控制
for(i = 0;i<0x0FFF;i++); <-----有个分号。 这是喂狗周期控制
WDFEED = 0xAA;
WDFEED = 0x55;
原抄的程序如下:
#include "config.h"
#define BEEP 1<<7
#define LED1 1<<18
#define KEY1 1<<16
#define KEY2 1<<17
int main(void)
uint32 i,j;
PINSEL0 = 0x0;
IO0DIR = BEEP;
IO1DIR = LED1;
IO0SET = BEEP;
IO0SET = BEEP;
WDMOD = 0x00;
else
IO0CLR = BEEP;
WDTC = 0xFF000;
WDMOD = 0x03;
WDFEED = 0xAA;
WDFEED = 0x55;
while(1)
WDFEED = 0xAA;
WDFEED = 0x55;
IO1SET = LED1;
else
IO1CLR = LED1;
WDFEED = 0xAA;
WDFEED = 0x55;
等效为:
WDFEED = 0xAA;
WDFEED = 0x55;
WDFEED = 0xAA;
WDFEED = 0x55;
原文为:
WDFEED = 0xAA;
WDFEED = 0x55;
1/1															1							跳转至页
