刚开始学arm,看2410addr.h文件时有些不明白,请教各位下:
#ifdef __BIG_ENDIAN
#define rUTXH0 (*(volatile unsigned char *)0x50000023) //UART 0 Transmission Hold
#define rURXH0 (*(volatile unsigned char *)0x50000027) //UART 0 Receive buffer
#define rUTXH1 (*(volatile unsigned char *)0x50004023) //UART 1 Transmission Hold
#define rURXH1 (*(volatile unsigned char *)0x50004027) //UART 1 Receive buffer
#define rUTXH2 (*(volatile unsigned char *)0x50008023) //UART 2 Transmission Hold
#define rURXH2 (*(volatile unsigned char *)0x50008027) //UART 2 Receive buffer
#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000023)=(unsigned char)(ch) //写操作
#define RdURXH0() (*(volatile unsigned char *)0x50000027) //读操作
#define WrUTXH1(ch) (*(volatile unsigned char *)0x50004023)=(unsigned char)(ch)
#define RdURXH1() (*(volatile unsigned char *)0x50004027)
#define WrUTXH2(ch) (*(volatile unsigned char *)0x50008023)=(unsigned char)(ch)
#define RdURXH2() (*(volatile unsigned char *)0x50008027)
#define UTXH0 (0x50000020+3) //Byte_access address by DMA
#define URXH0 (0x50000024+3)
#define UTXH1 (0x50004020+3)
#define URXH1 (0x50004024+3)
#define UTXH2 (0x50008020+3)
#define URXH2 (0x50008024+3)
此上为大端模式串口的寄存器. #define UTXH0 (0x50000020+3) //Byte_access address by DMA.这句,我不理解是干什么的,
第一没有采用和前面类似的volatile定义,
第二地址和上面是重复的.
第三,不知道Byte_access address by DMA是什么意思?
谢谢指点!
