我想在Vxwork中挂钩子,捕捉IP数据包。在2.0中可以用etherInputHookAdd实现,可在2.2下似乎没有,不知哪个函数可以实现此功能,请大家不吝赐教。
我想用硬件电路+vxworks系统来实现!
Tornado2.2以后把这个模块去掉了,代之的是BPF模块。
文档vxworks_network_programmers_guide_5.5.pdf里面的原话:
Remove any code your xxattach( ) included to support the implementation of the
etherInputHook( ) and etherOutputHook( ) routines. Etherhooks are no longer
supported. Similar functionality is now provided using BPF (see 3.2.1 BPF, the BSD
Packet Filter, p.20)
