共10条
[求助]下载了一个SDS74缺少license文件?
你说的也太多拉, 你自己需要啥
我现在只有:
struct feature feature_tbl[] = {
/*v_name f_name f_ver opt_attr1 opt_attr2*/
#if 0
#if defined(POWER_PC) && POWER_PC
{"sdsid", "KERNEL_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "BDM8XX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "BDM8XXX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "SIMPPC_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "SIMPPCX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "PSMPPC_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "PSMPPCX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "PRBPPC_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "PRBPPCX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "PSOSPPC_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "MONPPC_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
#else
{"sdsid", "KERNEL_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
#endif
{"sdsid", "BDMMCF_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "PSOS68K_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "PSM68K_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "PSM68KX_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "BDM68K_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "BDM68KX_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "SIM68K_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "SIM68KX_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "PERIPH_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "MON68K_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "MON68KX_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "HP68K_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
{"sdsid", "HP68KX_PC", "99.1231","VENDOR_STRING=SDS","SN=TempLicense",0,},
#endif
{"sdsid", "BDM4XX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "BDM4XXX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "BDM5XX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "BDM5XXX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "PERIPH_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "JAVA_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "EST8XX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "EST8XXX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "HP4XX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "HP4XXX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "HP5XX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "HP5XXX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "HP6XX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "HP6XXX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "HP8XX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "HP8XXX_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{"sdsid", "VXWPPC_PC", "99.1231","VENDOR_STRING=SDSI","SN=SDSISI0018388",0,},
{ 0,0,0,0,0, },
你按表格式填充你需要的feature,我也许能帮你
共10条
有奖活动 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
