自己编写的一个小程序,功能是:时钟信号CLK1使数加1,CLK2使数减1,最后设置好的这个数要和一个给定的数进行大小比较。
可编译时报错,实在不知道怎么改:
Error: Can't resolve multiple constant drivers for net "D_OUT[7]" at zdz.vhd(15)
共6条
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY zdz IS
PORT(CLK1:IN STD_LOGIC; --加1单脉冲
CLK2:IN STD_LOGIC; --减1单脉冲
RST:IN STD_LOGIC;
DA :OUT STD_LOGIC; --LED指示信号
DATA:OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
END zdz;
ARCHITECTURE behav OF zdz IS
SIGNAL D_IN : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL D_OUT: STD_LOGIC_VECTOR(7 DOWNTO 0);
BEGIN
P1:PROCESS(CLK1,RST)
BEGIN
IF RST='1' THEN D_OUT<="10001000";
ELSIF CLK1'EVENT AND CLK1='1' THEN
D_OUT<=D_OUT+1;
END IF;
END PROCESS P1;
P2:PROCESS(CLK2,RST)
BEGIN
ELSIF CLK2'EVENT AND CLK2='1' THEN
D_OUT<=D_OUT-1;
END IF;
END PROCESS P2;
DATA<=D_OUT;
D_IN<="10101010";
P3:PROCESS(D_OUT)
BEGIN
IF D_OUT > D_IN THEN DA<='1';
ELSE DA<='0';
END IF;
END PROCESS P3;
END behav;
ENTITY zdz IS
RST:IN STD_LOGIC;
END zdz;
BEGIN
BEGIN
D_OUT<=D_OUT+1;
END IF;
END PROCESS P1;
BEGIN
D_OUT<=D_OUT-1;
END IF;
END PROCESS P2;
DATA<=D_OUT;
D_IN<="10101010";
P3:PROCESS(D_OUT)
BEGIN
ELSE DA<='0';
END IF;
END PROCESS P3;
END behav;
我改了一下,clk1和clk2为两个输入信号端,非时钟。
LIBRARY IEEE;
ENTITY zdz IS
PORT(CLK1:IN std_logic; --加1输入信号
CLK2:IN std_logic; --减1输入信号
RST:IN std_logic;
DA :OUT std_logic; --LED指示信号
DATA:OUT std_logic_vector(7 DOWNTO 0));
END zdz;
SIGNAL D_OUT: std_logic_vector(7 DOWNTO 0);
BEGIN
P1:PROCESS(CLK1,CLK2,RST)
BEGIN
IF RST='1' THEN D_OUT<="00001000";
ELSIF clk1='1' THEN
D_OUT<=D_OUT+1;
ELSIF clk2='1' THEN
D_OUT<=D_OUT-1;
END IF;
END PROCESS P1;
P3:PROCESS(D_OUT)
VARIABLE D_IN : STD_LOGIC_VECTOR(7 DOWNTO 0):="00001000";
BEGIN
ELSE DA<='0';
END IF;
END PROCESS P3;
DATA<=D_OUT;
END behav;
LIBRARY IEEE;
ENTITY zdz IS
RST:IN std_logic;
END zdz;
BEGIN
BEGIN
ELSIF clk1='1' THEN
D_OUT<=D_OUT+1;
ELSIF clk2='1' THEN
D_OUT<=D_OUT-1;
END IF;
END PROCESS P1;
P3:PROCESS(D_OUT)
BEGIN
ELSE DA<='0';
END IF;
END PROCESS P3;
DATA<=D_OUT;
END behav;
共6条
