共3条
FTP信息代码全解[转帖]
![](http://uphotos.eepw.com.cn//thumb/avatar.jpg)
FTP信息代码全解 [推荐]
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
重新启动标志回应。这种情况下,信息是精确的并且不用特别的处理;可以这样看:标记 yyyy = mmm 中 yyyy是 用户进程数据流标记,mmmm是服务器端相应的标记(注意在标记和等号间的空格)
120 Service ready in nnn minutes.
服务在NNN时间内可用
125 Data connection already open; transfer starting.
数据连接已经打开,开始传送数据.
150 File status okay; about to open data connection.
文件状态正确,正在打开数据连接.
200 Command okay.
命令执行正常结束.
202 Command not implemented, superfluous at this site.
命令未被执行,此站点不支持此命令.
211 System status, or system help reply.
系统状态或系统帮助信息回应.
212 Directory status.
目录状态信息.
213 File status.
文件状态信息.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user. 帮助信息。关于如何使用本服务器或特殊的非标准命令。此回复只对人有用。
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
NAME系统类型。
220 Service ready for new user.
新连接的用户的服务已就绪
221 Service closing control connection.
控制连接关闭
225 Data connection open; no transfer in progress.
数据连接已打开,没有进行中的数据传送
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
正在关闭数据连接。请求文件动作成功结束(例如,文件传送或终止)
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
进入被动模式
230 User logged in, proceed. Logged out if appropriate.
用户已登入。 如果不需要可以登出。
250 Requested file action okay, completed.
被请求文件操作成功完成
257 "PATHNAME" created.
路径已建立
331 User name okay, need password.
用户名存在,需要输入密码
332 Need account for login.
需要登陆的账户
350 Requested file action pending further information
对被请求文件的操作需要进一步更多的信息
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
服务不可用,控制连接关闭。这可能是对任何命令的回应,如果服务认为它必须关闭
425 Can't open data connection.
打开数据连接失败
426 Connection closed; transfer aborted.
连接关闭,传送中止。
450 Requested file action not taken.
对被请求文件的操作未被执行
451 Requested action aborted. Local error in processing.
请求的操作中止。处理中发生本地错误。
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
请求的操作没有被执行。 系统存储空间不足。 文件不可用
500 Syntax error, command unrecognized. This may include errors such as command line too long.
语法错误,不可识别的命令。 这可能是命令行过长。
501 Syntax error in parameters or arguments.
参数错误导致的语法错误
502 Command not implemented.
命令未被执行
503 Bad sequence of commands.
命令的次序错误。
504 Command not implemented for that parameter.
由于参数错误,命令未被执行
530 Not logged in.
没有登录
532 Need account for storing files.
存储文件需要账户信息
550 Requested action not taken. File unavailable (e.g., file not found, no access).
请求操作未被执行,文件不可用。
551 Requested action aborted. Page type unknown.
请求操作中止,页面类型未知
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
对请求文件的操作中止。 超出存储分配
553 Requested action not taken. File name not allowed
请求操作未被执行。 文件名不允许
这种错误跟http协议类似,大致是:
2开头--成功
3开头--权限问题
4开头--文件问题
5开头--服务器问题
关键词: 信息 代码 全解 转帖 -------------
共3条
有奖活动 | |
5月直播——【探索边缘智能的未来——直播盛宴即将开启!】 | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 |
打赏帖 | |
换逻辑分析仪_STM32F103认识串口F103相关的知识认识被打赏18分 | |
“DFRobot盖革计数器模块评测”了解电离辐射对人体的危害被打赏8分 | |
“DFRobot盖革计数器模块评测”了解盖革计数器和电离辐射危害被打赏18分 | |
换逻辑分析仪_STM32F103_HAL库PWM呼吸灯被打赏23分 | |
换逻辑分析仪_STM32F103_(寄存器)PWM呼吸灯被打赏20分 | |
换逻辑分析仪STM32F103HAL库定时器被打赏13分 | |
换逻辑分析仪_STM32F103_(HAL库)驱动GPIO操作,点亮LED被打赏13分 | |
【分享评测,赢取加热台】+拆解一个儿童的python编程主控板被打赏20分 | |
【分享评测,赢取加热台】+拆解一个共享充电宝被打赏20分 | |
【换取手持数字示波器】+自制的STC无线调试器被打赏17分 |
