回复可见啊,100多篇呢
——回复可见内容——
4G通讯产品的电源解决方案
80 Plus Silver Box Solution For PC Desktop Power Supply
97%高效BUS电源开发
2008中国电源节-杨旭-DC-DC变换器的集成与封装技术
A Practical Introduction toDigital Power Supply Design
Advanced Quality Planning Training
Agilent 开关电源测试方案
ATCA 电源要求与保持技术
Buck-Boost Converter Achieving up to 97% Efficiency at 12V-5A from 4-32V Input
C2000 Digital Power Supply Workshop
Considerations for On-Board Powering Using DC-DC Converters
Considerations When Designing with Isolation and Isolated Driver Devices
CoolMOS C6 The New Reference in the HV MOS market
CoolSET F3 Latch & Jitter Mode ICE3A1065LJ
DC-DC Module Technology and Trend
Digital Power Supply with F280x Digital Signal Controllers
Features & Benefits of Integrating Digital Power and Control
Field Applications Manager, Wirelineand MCU Products Silicon Laboratories
High Efficiency Power Supply from NXP Semiconductors
Infineon 900V CoolMOS
Infineon QR CooLSET-achieving higher efficiency and lower standby power
IR380X SupIRBuck针对消费类产品的高功率密度集成Buck变换器
L6928D high efficiency monolithic sychronous step down regulator
LED电源标准化设计路线
LED照明设计方向
Long Life,High PF for LED Driver with ST solutions
Multi-cell Li-ion Battery Protection Solution
NCP312x双路输出2.0 A及3.0 A开关调整器系列
NCP4302 反激式次级同步整流控制器
NXP Next Generation of HV Half-bridge Resonant Inverter
Power Design Applications and Tools
Power over Ethernet
Programmable Li -ION Battery Charger System for Portable Applications
Renesas Power Management Solution
Resonant Half Bridge LLC Controller enhance slim Digital TV design
SG3525 常规PWM控制器
SII DC-DC Products for PMP Power Management
SmartRectifier 产品系列 同步整流解决方案
Solving Power System Challenges
ST L6716-STripFET V MosFet
STMicroelectronics L6717A AM3 Solution for Desktop Power
THE BEST CHOICE FOR Green Power
The third generation non-isolated power module based on tunable loop
TI Plug -In Power Designing for Cost and Efficiency
Z-One 数字电源系统
便携产品电源芯片的应用技术
便携式手持设备的电源管理IC技术趋势
不使用桥路的升压PFC:单周控制的突破
采用 PowerWise®Simple Switcher 控制器简化负载点电源系统设计
采用半桥结构设计的高功率密度电源转换器
采用国半的 PWM 控制器提升高功率密度砖电源模块的性能
创新电源系统分析与测试方案
创新思维提高产品研发速度
单级功率因数校正与特殊功率因数校正
德州仪器数字电源解决方案
德州仪器系统电源解决方案
低功率多路输出次级控制器NCP4326
电磁干扰抑制器件中的片式元件
电压隔离放大器的优化设计
电源测试的标准、方法与发展趋势
电源系统分析与测试
恩智浦LED 绿色照明解决方案
恩智浦创新的液晶电视一体化电源及背光方案
反激变换器的变压器
改善功率密度和电源管理能力的数字控制技术
高效、准确的开关电源测试方案
高效率低待机功耗便携式设备电源方案
高性能EMI滤波器及其小型化技术
高性能的马达驱动方案,更加节能
功率电感耦合及在开关电源上的应用
功率管理 突破功率的限制
功率小于75 W的适配器方案
光耦的设计及电气特性解析
横河新型测试仪器及其在电源方面的应用
横河新型示波器在电源测试中的应用
基于中间母线控制的新型通信电源整体解决方案
开关电源电磁兼容及其研究新进展
开关电源原边数字控制系统的嵌入式高速隔离器件
