上来视频卡卡你看
通过LCD显示出来AD的数据并通过串口发送出去!
iic 通信
幸亏有zhengningwei同志提醒,要不然我还在苦苦追寻为什么读出来不对的数据那!
有时候看多了反而给淡忘了!
哎哎!
有成长一步啊!
void statr()
SDA=1;
delay1();
SCL=1;
delay1();
SDA=0;
delay1();
void stop()
SDA=0;
delay1();
SCL=1;
delay1();
SDA=1;
delay1();
void acknow()
SCL=1;
delay1();
if(SDA==0)
delay1();
SCL=0;
delay1();
void write1byte(unchar addr)
unchar run;
run=addr;
for(x=0;x<8;x++)
SCL=0;
delay1();
run=run<<1;
SDA=CY;
delay1();
SCL=1;
delay1();
SCL=0;
delay1();
SDA=1;
delay1();
unchar read1byte()
unchar com;
for(x=0;x<8;x++)
SCL=1;
delay1();
com=com<<1|SDA;
SCL=0;
delay1();
return(com);
main()
statr();
write1byte(0xae);
acknow();
write1byte(0x00);
acknow();
write1byte(0x04);
acknow();
write1byte(0x05);
acknow();
stop();
delay(100);
statr();
write1byte(0xae);
acknow();
write1byte(0x00);
acknow();
write1byte(0x04);
acknow();
statr();
write1byte(0xaf);
acknow();
aa=read1byte();
stop();
P2=0X01;
//P1=0XFD;
P37=1;
P0=tabol[aa];
P37=0;
delay(50);
while(1);
