通过开发板上的4 x1 key的S3和S4来控制继电器的吸合与断开,并控开发板的LED12亮与灭:
简单程序:
#include<STC12C5A60S2.H> //头文件
sbit S3 = P3 ^2;
sbit S4 = P3 ^3;
sbit RL1 = P3 ^7;
函数名:毫秒级CPU延时函数
调 用:DELAY_MS (?);
参 数:1~65535(参数不可为0)
返回值:无
结 果:占用CPU方式延时与参数数值相同的毫秒时间
备 注:应用于1T单片机时i<600,应用于12T单片机时i<125
void DELAY_MS (unsigned int a){
unsigned int i;
while( a-- != 0){
for(i = 0; i < 600; i++);
void main (void){ //主程序
while(1){
if (S3 == 0)
DELAY_MS (300);//消抖
RL1 = 1;
if (S4 == 0)
DELAY_MS (300);
RL1 = 0;
4x4键盘实验,LED 数码管显示:
原程序:
#include <string.h>
bit flag;
unsigned char leddisplay[] ={0};
sbit speaker = P1^0;
sbit led = P1^3;
#define KEY P3 //数据总线
unsigned int i;
while( a-- != 0){
蜂鸣器驱动子函数
void beep(void)
speaker = 1;
DELAY_MS(20);
speaker = 0;
DELAY_MS(20);
键盘扫描子函数
keyscan()
unsigned char a,b,c;
KEY = 0x0F;
if(KEY!= 0x0F)
DELAY_MS(125);
if(KEY!= 0x0F)
a = KEY;
KEY = 0xF0;
c = KEY;
a = a|c;
switch(a){
case 0xee: b = 0x39;beep();flag=1;break; //C
case 0xed: b = 0x5E;beep();flag=1;break; //D
case 0xeb: b = 0x79;beep();flag=1;break; //E
case 0xe7: b = 0x71;beep();flag=1;break; //F
case 0xde: b = 0x6F;beep();flag=1;break; //9
case 0xdd: b = 0x3F;beep();flag=1;break; //0
case 0xdb: b = 0x77;beep();flag=1;break; //A
case 0xd7: b = 0x7C;beep();flag=1;break; //B
case 0xbe: b = 0x6D;beep();flag=1;break; //5
case 0xbd: b = 0x7D;beep();flag=1;break; //6
case 0xbb: b = 0x07;beep();flag=1;break; //7
case 0xb7: b = 0x7F;beep();flag=1;break; //8
case 0x7e: b = 0x06;beep();flag=1;break; //1
case 0x7d: b = 0x5B;beep();flag=1;break; //2
case 0x7b: b = 0x4f;beep();flag=1;break; //3
case 0x77: b = 0x66;beep();flag=1;break; //4
default:flag=0;break; //
DELAY_MS(125);
return(b);
LED驱动子函数
void led_display(void)
unsigned char i;
for(i=0;i<8;i++)
P0 = leddisplay[i];
P2 = i;
DELAY_MS(2);
/* MAIN function */
int main (void)
unsigned char b,i,l=0;
speaker = 0;
P0 = 0x00;
while(1)
b = keyscan();
if(flag)
leddisplay[l] = b;
l=l+1;
if(l>8)
leddisplay[8] = b;
for(i=0;i<8;i++)
leddisplay[i]= leddisplay[i+1];
flag=0;
led_display();
AT24C02实验程序是参考STC官网的原程序,视频演示的内容为:
1、按S13键,并通过4x3键盘输入8位数(可以是数字,也可以是字母,但最右边四个键为功能键,限制输入,如果在输入过程中有误,需重新输入,则可按S16清除,然后重新输入。);
2、按S15键,将输入的8位数据存入AT24C02中;
3、按S14键,并通过4x3键盘输入8位数;
4、按S15键,如果第3步输入的数字与第1步输入的数字完全一样,则LED数码管显示“good”,并点亮开发板上的LED5,如果不完全一样,则LED数码管显示“Err”,并熄灭开发板上的LED5,可重新步骤3。
参考程序:
#include <string.h>
#include <INTRINS.H>
bit flag;
typedef unsigned char BYTE;
typedef unsigned short WORD;
sbit SCL = P1^1; //AT24C04的时钟
sbit SDA = P1^2; //AT24C04的数据
BYTE BUF[8]; //数据缓存区
BYTE code WriteDATA[] ={0};
BYTE code ReadDATA[] ={0};
unsigned char leddisplay[8] ={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char gooddisplay[8] ={0x6F,0x5C,0x5C,0x5E,0x00,0x00,0x00,0x00};
unsigned char errdisplay[8] ={0x79,0x50,0x50,0x00,0x00,0x00,0x00,0x00};
void Delay5us();
void Delay5ms();
void AT24C04_Start();
void AT24C04_Stop();
void AT24C04_SendACK(bit ack);
bit AT24C04_RecvACK();
void AT24C04_SendByte(BYTE dat);
BYTE AT24C04_RecvByte();
void AT24C04_ReadPage();
void AT24C04_WritePage();
sbit led = P1^3;
unsigned int i;
while( a-- != 0){
LED驱动子函数
unsigned char i;
for(i=0;i<8;i++)
P0 = leddisplay[i];
P2 = i;
DELAY_MS(2);
蜂鸣器驱动子函数
void beep(void)
speaker = 1;
DELAY_MS(20);
speaker = 0;
DELAY_MS(20);
键盘扫描子函数
keyscan()
KEY = 0x0F;
if(KEY!= 0x0F)
DELAY_MS(125);
if(KEY!= 0x0F)
a = KEY;
KEY = 0xF0;
c = KEY;
a = a|c;
switch(a){
DELAY_MS(125);
return(b);
向AT24C04写1页(16字节)数据
将TESTDATA开始的16个测试数据写如设备的00~0F地址中
BYTE i;
AT24C04_Start(); //起始信号
AT24C04_SendByte(0xa0); //发送设备地址+写信号
AT24C04_SendByte(0x00); //发送存储单元地址
for (i=0; i<8; i++)
AT24C04_SendByte(leddisplay[i]);
AT24C04_Stop(); //停止信号
从AT24C04读取1页(16字节)数据
将设备的00~0F地址中的数据读出存放在DATA区的BUF中
BYTE i;
AT24C04_SendByte(0xa1); //发送设备地址+读信号
for (i=0; i<8; i++)
BUF[i] = AT24C04_RecvByte();
if (i == 8)
AT24C04_SendACK(1); //最后一个数据需要会NAK
else
AT24C04_SendACK(0); //回应ACK
延时5微秒(STC12C5A60S2@12M)
不同的工作环境,需要调整此函数
此延时函数是使用1T的指令周期进行计算,与传统的12T的MCU不同
void Delay5us()
BYTE n = 4;
while (n--)
_nop_();
_nop_();
延时5毫秒(STC12C5A60S2@12M)
不同的工作环境,需要调整此函数
void Delay5ms()
WORD n = 2500;
while (n--)
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
起始信号
SDA = 1; //拉高数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 0; //产生下降沿
Delay5us(); //延时
SCL = 0; //拉低时钟线
停止信号
void AT24C04_Stop()
SDA = 0; //拉低数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 1; //产生上升沿
Delay5us(); //延时
发送应答信号
入口参数:ack (0:ACK 1:NAK)
SDA = ack; //写应答信号
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
接收应答信号
SCL = 1; //拉高时钟线
Delay5us(); //延时
CY = SDA; //读应答信号
SCL = 0; //拉低时钟线
Delay5us(); //延时
return CY;
向IIC总线发送一个字节数据
BYTE i;
for (i=0; i<8; i++) //8位计数器
dat <<= 1; //移出数据的最高位
SDA = CY; //送数据口
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
AT24C04_RecvACK();
从IIC总线接收一个字节数据
BYTE i;
BYTE dat = 0;
SDA = 1; //使能内部上拉,准备读取数据
dat <<= 1;
SCL = 1; //拉高时钟线
Delay5us(); //延时
dat |= SDA; //读数据
SCL = 0; //拉低时钟线
Delay5us(); //延时
return dat;
/* MAIN function */
int main (void)
unsigned char a=1,b,i,j,m,k=1,l=0;
speaker = 0;
P0 = 0x00;
while(1)
b = keyscan();
if(flag)
if(b==0x39)
for(i=0;i<8;i++)
leddisplay[i]= 0x08;
flag=0;
do{
b = keyscan();
if(flag && b!=0x39 && b!=0x5e && b!=0x79 && b!=0x71)
leddisplay[l] = b;
l=l+1;
if(l>8)
leddisplay[8] = b;
for(i=0;i<8;i++)
flag=0;
if(b==0x71)
for(i=0;i<8;i++){
leddisplay[i]= 0x08;}
l=0;
flag=0;
led_display();
}while( b!=0x79);
P0 = 0x00;
flag=0;
if(b==0x5e)
for(i=0;i<8;i++)
flag=0;
l=0;
do{
b = keyscan();
leddisplay[l] = b;
l=l+1;
if(l>8)
leddisplay[8] = b;
for(i=0;i<8;i++)
flag=0;
if(b==0x71)
for(i=0;i<8;i++){
l=0;
flag=0;
led_display();
}while( b!=0x79);
flag=0;
k=0;
AT24C04_ReadPage();
for(m=0;m<8;m++)
if(BUF[m]==leddisplay[m])
k++;
if(k==8)
{led=0;
for(i=0;i<8;i++){
leddisplay[i] = gooddisplay[i];}
if(k!=8)
led=1;
for(j=0;j<8;j++){
leddisplay[j] = errdisplay[j];}
do{
b=keyscan();
led_display();
}while(b!=0x5e);
flag=0;
P0=0x00;
| 有奖活动 | |
| 2026年“我要开发板活动”第三季,开始了! | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| PTC与NTC功能常规对比被打赏¥14元 | |
| 【分享开发笔记,赚取电动螺丝刀】关于3pin锂电池接口的介绍/使用被打赏¥16元 | |
| 以启明云端ESP32P4开发板实现TF卡读写功能被打赏¥28元 | |
| 【分享开发笔记,赚取电动螺丝刀】树莓派5串口UART0配置被打赏¥25元 | |
| 【STM32F103ZET6】17:分享在Rtos项目中断管理的使用经验被打赏¥23元 | |
| 【STM32F103ZET6】16:分享在中断中恢复串口任务,遇到的问题被打赏¥31元 | |
| 在FireBeetle2ESP32-C5上实现温度大气压检测及显示被打赏¥21元 | |
| 【分享开发笔记,赚取电动螺丝刀】SAME51双串口收发配置被打赏¥27元 | |
| Chaos-nano操作系统在手持式VOC检测设备上的应用被打赏¥37元 | |
| 【分享开发笔记,赚取电动螺丝刀】关于在导入第三方库lib时,wchart类型冲突的原因及解决方案被打赏¥30元 | |
,拍得不好,不好意思自荐。。。
