给大家一个播放音乐的程序
我的蜂鸣器因为没有买到三极管所以不能用
让大家试一试吧
从网上看到的
#include <reg52.h>
#include <intrins.h>
#define FREQ 11059200
unsigned char code music_tab1[]={
//梁祝
0xcb,
0x35,0x16,0xb9,0x12,0x96,0x99,0xa5,
0xbd,0x99,0x96,0x15,0x13,0x15,0x62,
0x32,0x13,0xa7,0x26,0x25,0x16,0xa9,0x22,
0xa3,0xa9,0x96,0x15,0x16,0x99,0xe5,
0xbb,0x15,0xa7,0xaa,0x96,0x99,0xd5,
0x13,0x15,0x23,0x15,0x16,0x17,0x9a,0xd6,0x15,0x16,
0xb9,0x12,0x25,0x23,0x23,0x22,0x13,0x12,0x21,0x96,0x15,
0x43,0xc9,0x96,0x99,0x96,0x15,0x13,0x15,0x16,0x99,
0xd5,0x00,
unsigned char code music_tab2[]={ //康定情歌
0x23,0x25,0x26,0x16,0x15, 0x36,0x13,0x42,
0x23,0x25,0x26,0x16,0x15, 0x26,0x53,
0x23,0x25,0x26,0x16,0x15, 0x26,0x23,0x42,
0x25,0x23,0x12,0x13,0x12,0x11, 0x22,0xd6,
0x26,0xda, 0x25,0x53, 0x12,0x11,0xd6,
0xad,0x23,0x12,0x13,0x12,0x11, 0x22,0xd6,
0x00,
unsigned char code music_tab3[]={ //美酒加咖啡
0x55,0x23,0x25,0x26,0xa9,0x22, 0x73,
0x45,0x25,0x26,0x23,0x22,0x21,0x23, 0x72,
0x52,0x23,0x45,0x43, 0x22,0x21,0xa6,0x25,0x66,
0xc9,0xa6,0x25,0x23,0x25,0x26,0xa9, 0xf5,
0x45,0x23,0x25,0x46,0xc9, 0x22,0x13,0x12,0x21,0x22,0x63,
0x22,0x23,0x25,0x26,0x25,0x23,0x22,0x21, 0x72,
0xb9,0x12,0x23,0x25,0x22,0xa5,0xab,0x22, 0x71,
0x00,
unsigned char code music_tab4[]={ //北国之春
0x15,0x16,0x75, 0x15,0x16,0x55,0x13,0x15,0x16,0x15,0x16,0x99,0x12,0x13,
0x65,0x45,0x13,0x12,0x11,0x12, 0x73,
0x62,0x42,0x12,0x11,0x96,0x15, 0x76,
0x55,0x23,0x45,0xa9,0x22, 0x53,0x12,0x13,0x65,
0x52,0x22,0x42,0x21,0xa6, 0xe9,0x91,0x12,0x13,0x12,0x13,0x15,0x99,0x12,
//以上为过门
0x20,0x23,0x23,0x23,0x63, 0x22,0x23,0x23,0x22,0x41,0xa6,0x25,
0x53,0x22,0x21,0xa9,0x21,0xa6, 0x75,
0x26,0xa9,0x21,0xa6,0xc9,0x12,0x11,0x96,0x15,
0x23,0x25,0x25,0x26,0x45,0x21,0x22,
0x13,0x35,0x25,0xa9,0xa6,0x25,0x23,0x22, 0x71,
0x52,0x25,0x45,0x13,0x15,0x13,0x12, 0x21,0x41,0x22,0x43,0x45,
0x23,0x25,0x26,0xa9,0x42,0x12,0x33, 0x72,
0x51,0x22,0x43,0x22,0x21, 0xc6,0xc9,0x29,0xc6,0x45,0x23,0x23,
0x53,0x25,0x26,0x25,0x13,0x12,0x21, 0x62,0x42,0x23,0x25,
0x55,0x26,0x25,0x23,0x45, 0x26,0xa9,0x21,0x22,0x63,
0x52,0x22,0x22,0x13,0x12,0x21,0xa6,0xf9,
0x00,
unsigned char code music_l_tab[8]={0,1,2,3,4,6,8,16};//节拍延时单位
unsigned char code music_freq_tab[64]={ //音符定时器值表
0xff,0xea, //0 休止符
255-FREQ/24/131/256, //256-FREQ/24/x/256 //1 do 高字节
256-FREQ/24/131%256, //256-FREQ/24/x%256 //1 do 低字节
255-FREQ/24/147/256,256-FREQ/24/147%256, //2 re
255-FREQ/24/165/256,256-FREQ/24/165%256, //3 mi
255-FREQ/24/175/256,256-FREQ/24/175%256, //4 fa
255-FREQ/24/196/256,256-FREQ/24/196%256, //5 suo
255-FREQ/24/221/256,256-FREQ/24/221%256, //6 la
255-FREQ/24/248/256,256-FREQ/24/248%256, //7 xi
0xff,0xea, //0 休止符
255-FREQ/24/262/256,256-FREQ/24/262%256, //1 do
255-FREQ/24/294/256,256-FREQ/24/294%256, //2 re
255-FREQ/24/330/256,256-FREQ/24/330%256, //3 mi
255-FREQ/24/350/256,256-FREQ/24/350%256, //4 fa
255-FREQ/24/393/256,256-FREQ/24/393%256, //5 suo
255-FREQ/24/441/256,256-FREQ/24/441%256, //6 la
255-FREQ/24/495/256,256-FREQ/24/495%256, //7 xi
0xff,0xea, //0 休止符
255-FREQ/24/525/256,256-FREQ/24/525%256, //1 do
255-FREQ/24/589/256,256-FREQ/24/589%256, //2 re
255-FREQ/24/661/256,256-FREQ/24/661%256, //3 mi
255-FREQ/24/700/256,256-FREQ/24/700%256, //4 fa
255-FREQ/24/786/256,256-FREQ/24/786%256, //5 suo
255-FREQ/24/882/256,256-FREQ/24/882%256, //6 la
255-FREQ/24/990/256,256-FREQ/24/990%256, //7 xi
0xff,0xea, //0 休止符
255-FREQ/24/1049/256,256-FREQ/24/1049%256, //1 do
255-FREQ/24/1178/256,256-FREQ/24/1178%256, //2 re
255-FREQ/24/1322/256,256-FREQ/24/1322%256, //3 mi
255-FREQ/24/1400/256,256-FREQ/24/1400%256, //4 fa
255-FREQ/24/1572/256,256-FREQ/24/1572%256, //5 suo
255-FREQ/24/1665/256,256-FREQ/24/1665%256, //6 la
255-FREQ/24/1869/256,256-FREQ/24/1869%256, //7 xi
unsigned char code music_frequp_tab[64]={ //升半音
0xff,0xea, //0 休止符
255-FREQ/24/139/256, //1 do 高字节 //255-FREQ/24/x/256
256-FREQ/24/139%256, //1 do 低字节 //256-FREQ/24/x%256
255-FREQ/24/156/256,256-FREQ/24/156%256, //2 re
255-FREQ/24/175/256,256-FREQ/24/175%256, //3 mi
255-FREQ/24/185/256,256-FREQ/24/185%256, //4 fa
255-FREQ/24/208/256,256-FREQ/24/208%256, //5 suo
255-FREQ/24/234/256,256-FREQ/24/234%256, //6 la
255-FREQ/24/262/256,256-FREQ/24/262%256, //7 xi
0xff,0xea, //0 休止符
255-FREQ/24/278/256,256-FREQ/24/278%256, //1 do
255-FREQ/24/312/256,256-FREQ/24/312%256, //2 re
255-FREQ/24/350/256,256-FREQ/24/350%256, //3 mi
255-FREQ/24/371/256,256-FREQ/24/371%256, //4 fa
255-FREQ/24/416/256,256-FREQ/24/416%256, //5 suo
255-FREQ/24/467/256,256-FREQ/24/467%256, //6 la
255-FREQ/24/525/256,256-FREQ/24/525%256, //7 xi
0xff,0xea, //0 休止符
255-FREQ/24/556/256,256-FREQ/24/556%256, //1 do
255-FREQ/24/624/256,256-FREQ/24/624%256, //2 re
255-FREQ/24/700/256,256-FREQ/24/700%256, //3 mi
255-FREQ/24/742/256,256-FREQ/24/742%256, //4 fa
255-FREQ/24/833/256,256-FREQ/24/833%256, //5 suo
255-FREQ/24/935/256,256-FREQ/24/935%256, //6 la
255-FREQ/24/1049/256,256-FREQ/24/1049%256, //7 xi
0xff,0xea, //0 休止符
255-FREQ/24/1112/256,256-FREQ/24/1112%256, //1 do
255-FREQ/24/1248/256,256-FREQ/24/1248%256, //2 re
255-FREQ/24/1400/256,256-FREQ/24/1400%256, //3 mi
255-FREQ/24/1484/256,256-FREQ/24/1484%256, //4 fa
255-FREQ/24/1618/256,256-FREQ/24/1618%256, //5 suo
255-FREQ/24/1764/256,256-FREQ/24/1764%256, //6 la
255-FREQ/24/1968/256,256-FREQ/24/1968%256, //7 xi
unsigned char temp_TH1;
unsigned char temp_TL1;
// 音乐_编码2 -- IO定义 //
sbit PIN_MSC=P1^0; // 音乐输出端口 //
// 音乐_编码2 -- 函数原型//
void music_delay(unsigned char x); //音乐节拍延时
void music_play(unsigned char *msc); //播放音乐子程序
// 音乐_编码2 -- 函数 //
void music_int_t1 (void) interrupt 3 using 1 //定时中断1//
PIN_MSC=~PIN_MSC;
TH1=temp_TH1;
TL1=temp_TL1;
void music_delay(unsigned char n) //延时 125*n 毫秒
unsigned char i=125,j;
do {
do {
for (j=0; j<230; j++) _nop_(); //j=(11159KHz/12-10)/4
}while(--i);
}while(--n);
void music_play(unsigned char *msc) //音乐
unsigned char music_freq=32; //音高
unsigned char music_long; //节拍
unsigned char music_data=0; //音符数据
bit music_up=0; //升半音
bit music_break=0; //断奏
temp_TH1=0xff;
temp_TL1=0xea; //关输出(输出超声波)
TMOD=0x11; //T0:16位定时器、T1:16位定时器
// ET0=0; //关T0定时器中断
ET1=1; //开T1定时器中断
while (*msc != 0x00)
music_data=*msc & 0x07;
music_long=*msc>>4;
if (music_long != 0) //是音符
if (*msc >=128) //需升降调
if (((*msc) & 0x08) == 0)
{if (music_freq >= 16) music_freq -= 16;} //音高下降
else
{if (music_freq < 48) music_freq += 16;} //音高上升
if (music_up==1) //升半音
temp_TH1=music_frequp_tab[(music_freq + (music_data <<1))];
temp_TL1=music_frequp_tab[(music_freq + (music_data <<1)+1)];
else //不升半音
temp_TH1=music_freq_tab[(music_freq + (music_data <<1))];
temp_TL1=music_freq_tab[(music_freq + (music_data <<1)+ 1)];
if (music_break) //断奏
music_delay(music_l_tab[music_long&0x07]-1);
temp_TH1=0xff;
temp_TL1=0xea;
music_delay(1);
else //连奏
music_delay(music_l_tab[music_long&0x07]);
else //是功能码
switch(music_data)
case 0x04:
music_up=0; //不升半音
break;
case 0x05:
music_up=1; //升半音
break;
case 0x06:
music_break=0; //断奏
break;
case 0x07:
music_break=1; //连奏
break;
default:
break;
msc++;
ET1=0; //播放结束,关T1中断
PIN_MSC=1; //关输出
// temp_TH1=0xff;
// temp_TL1=0xea; //关输出(输出超声波)
// ET0=1; //开T0定时器中断
// TMOD=0x51; //T0:16位定时器、T1:16位计数器
void main(void) //示例
// 设置定时器--------------------------------------
TMOD = 0x11; // TMOD: 定时器1:模式1:16位;定时器2:模式1:16 位 //
// TCON = 0x50; // TCON: 定时器 1运行; 定时器 2运行 //
// 设置并开启中断:
IP = 0x08; //中断优先寄存器IP:|D7_x |x|x |PS|PT1|PX1|PT0|D0_PX0|//
IE = 0x88; //中断允许寄存器IE:|D7_EA|x|ET2|ES|ET1|EX1|ET0|D0_EX0|//
for (;;) {
//在此调用键盘和显示函数//
music_play(music_tab1);
music_play(music_tab2);
music_play(music_tab3);
music_play(music_tab4);
