uint16_t LCD_ReadReg(uint8_t LCD_Reg)
/* Write 16-bit Index (then Read Reg) */
LCD->LCD_REG = LCD_Reg;
/* Read 16-bit Reg */
return (LCD->LCD_RAM);
void LCD_WriteRAM(uint16_t RGB_Code)
/* Write 16-bit GRAM Reg */
LCD->LCD_RAM = RGB_Code;
* @brief Reads the LCD RAM.
* @param None
* @retval LCD RAM Value.
uint16_t LCD_ReadRAM(void)
LCD->LCD_REG = LCD_REG_34; /* Select GRAM Reg */
return LCD->LCD_RAM;
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
