终于按格式发帖成功,图为刚刚用调温刀头烙铁焊的主控芯片。 kangyan139 ARM DIY进程帖
附上流水灯源程序
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Version : V2.0.1
* Date : 06/13/2008
* Description : Main program body.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/*LED灯相关定义*/
#define RCC_GPIO_LED RCC_APB2Periph_GPIOE /*LED使用的GPIO时钟*/
#define LEDn 4 /*LED数量*/
#define GPIO_LED GPIOE /*LED灯使用的GPIO组*/
#define DS1_PIN GPIO_Pin_5 /*DS1使用的GPIO管脚*/
#define DS2_PIN GPIO_Pin_4 /*DS2使用的GPIO管脚*/
#define DS3_PIN GPIO_Pin_3 /*DS3使用的GPIO管脚*/
#define DS4_PIN GPIO_Pin_2 /*DS4使用的GPIO管脚*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef GPIO_InitStructure;
ErrorStatus HSEStartUpStatus;
u8 count=0;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Delay(vu32 nCount);
void Turn_On_LED(u8 LED_NUM);
/* Private functions ---------------------------------------------------------*/
* Function Name : main
* Description : Main program.
* Input : None
* Output : None
* Return : None
int main(void)
/* LED灯使用的GPIO管脚模式*/
RCC_APB2PeriphClockCmd(RCC_GPIO_LED, ENABLE); /*使能LED灯使用的GPIO时钟*/
GPIO_InitStructure.GPIO_Pin = DS1_PIN|DS2_PIN|DS3_PIN|DS4_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIO_LED, &GPIO_InitStructure); /*使用的LED灯相关的GPIO口初始化*/
GPIO_SetBits(GPIO_LED,DS1_PIN|DS2_PIN|DS3_PIN|DS4_PIN);/*关闭所有的LED指示灯*/
while(1)
Turn_On_LED(count%4); //点亮一个LED灯
count++;
Delay(0x2FFFFF);
// GPIO_ResetBits(GPIO_LED,DS1_PIN);
// GPIO_ResetBits(GPIO_LED,DS2_PIN);
// GPIO_ResetBits(GPIO_LED,DS3_PIN);
// GPIO_ResetBits(GPIO_LED,DS4_PIN);
// Delay(0x2FFFFF);
/*点亮对应灯*/
switch(LED_NUM)
case 0:
GPIO_ResetBits(GPIO_LED,DS1_PIN); /*点亮DS1灯*/
break;
case 1:
GPIO_ResetBits(GPIO_LED,DS2_PIN); /*点亮DS2灯*/
break;
case 2:
GPIO_ResetBits(GPIO_LED,DS3_PIN); /*点亮DS3灯*/
break;
case 3:
GPIO_ResetBits(GPIO_LED,DS4_PIN); /*点亮DS4灯*/
break;
default:
GPIO_ResetBits(GPIO_LED,DS1_PIN|DS2_PIN|DS3_PIN|DS4_PIN); /*点亮所有的灯*/
break;
* Function Name : Delay
* Description : Inserts a delay time.
* Input : nCount: specifies the delay time length.
* Output : None
* Return : None
for(; nCount != 0; nCount--);
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
| 有奖活动 | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| SWM221CBT7显示开发板及其使用被打赏¥20元 | |
| 揭秘Chaos-nano:ArduinoProMini轻量级操作系统开发框架深度解析与实战应用被打赏¥19元 | |
恭喜呀!!
今下午终于把最小系统焊好啦~如图,并且可以用J-link读取芯片了,下一步写个流水灯进去看看哦!
