This Virtex™-5 application note describes an SFI-4.1 interface, a 16-channel, source-synchronous LVDS interface operating at SDR. The transmitter requires 16 LVDS pairs for data and one LVDS pair for the forwarded clock. The receiver also requires 16 LVDS pairs for data and one LVDS pair for the source-synchronous clock input.The timing of the receiver is described in depth and characterized in hardware.
xapp856.pdf
共1条
SFI-4.1 16-Channel SDR Interface with Bus Alignment
关键词: SFI-4.1 16-Channel Interf
共1条
