The PCI™ Local Bus Specification defines a number of power and reset requirements. When considered in an FPGA implementation, these create several challenges that must be addressed for long term reliability and broad interoperability. This application note applies to compliant PCI applications using Spartan™-3 Generation FPGAs, and is relevant to other Xilinx FPGA families, as well as related PCI applications.
xapp457.pdf
共1条
Powering and Configuring Spartan-3 Generation FPGAs in Compliant PCI Application
关键词: Powering Configuring Spar
共1条
