This application note describes the controller and data capture technique for high-performance DDR2 SDRAM interfaces. This data capture technique uses the Input Serializer/Deserializer (ISERDES) and Output Double Data Rate (ODDR) features available in every Virtex®-5 I/O.
xapp858.pdf
共1条
High-Performance DDR2 SDRAM Interface in Virtex-5 Devices
关键词: High-Performance SDRAM In
共1条
