功能如下:
Baud Rate Calculator-------------(与晶振相关的计算)
Actual baud, error rate, and character and bit timing.
Timer Calculator------------(定时器)
Allows settting of prescaler, desired timing (in millseconds, microseconds, or Hertz), whether computing base rate or toggled [double frequency], showing compare values, actual rate, and error percentage, and timer overflow periods.
TWI Calculator------------(TWI)
Computes TWI (I2C) frequencies based on register values as well as computing register values based on desired frequency.
Watchdog Calculator-------------(与看门狗相关的计算)
Computes times for number of 128kHz watchdog cycles.
FMUL Calculator-------------(与fmul相关的计算)
Computes AVR fractional multiplications.
32-bit Number Calculator
Converts between decimal (integer and floating point), hexadecimal integers, and IEEE-754 floating point. Can switch between little and big endian formatting.
ASCII Calculator-------------(与ASCII码相关的计算)
Computes between character strings, ASCII hex, and binary values.
对文件夹位置没有有要求,解压到一个文件夹后,如图
解压到一个文件夹后,最好在外面任意你想要的地方建一个[[快捷方式]],这样就好了,绿色的,很有用
软件截图
回复可见
——回复可见内容——
