电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » 【一点一滴学嵌入式Linux】VirtualBox and scientific
共13条 2/2 ‹ 1 2 跳转至页
2013-10-15 15:27:36     打赏
11楼
2013-10-22 16:39:44     打赏
12楼
1 download src
sudo apt-get install ant (not neccesary)
install jdk
sudo tar -xvf jdk-7u25-linux-x64.tar.gz (in root directory)
sudo vi /etc/profile
JAVA_HOME=/jre1.7.0_25:/jsd1.7.0_25
PATH=$JAVA_HOME/bin:$PATH CLASSPATH=.:$JAVA_HOME/lib/dt.jar:$JAVA_HOME/lib/tools.jar sourc /etc/profile sudo apt-get install maven sudo apt-get install cmake findbugs (in eclipse-help-eclipse marketplace) protocolbuffer  download protobuf-2.5.0.tar make clean ./configure --prefix=/usr/local make make check sudo make install sudo /etc/ld.so.conf.d/libprotobuf.conf /usr/local/lib sudo ldconfig protoc --version (check ) 2 BUILDING.TXT cd hadoop-maven-plugins mvn install cd .. mvn eclipse:eclipse -DskipTests
eclipse-file-import-existing projects into workspace building distributions: mvn package -Pdist,native,docs -DskipTests -Dtar
2013-10-25 20:02:45     打赏
13楼
 10-25
http://beagleboard.org/Getting%20Started
  (http://www.embest-tech.cn/community/thread-3088-1-1.html 中国版)
  download usb drive (英文版中可以选择不同驱动)
  use google chrome, connect to beaglebone black(http://192.168.7.2)
 download putty
    host : 192.168.7.2   port : 20       use ssh,open and can use shell,login as :root   ,no passward
 in putty
    date + "%F %T" -s "2013/10/25 19:53:00"   同步时间后,(秒可以不精确)使用https://192.168.7.2 进入个gateone
   localhost  22  root  进入shell
 http://192.168.7.2:3000 enter iDE
共13条 2/2 ‹ 1 2 跳转至页
