用isim仿真Rapidio 时候崩溃了,错误如下:
ISim P.28xd (signature 0x1048c146)
This is a Full version of ISim.
ERROR: FATAL ERROR:ISim: This application has discovered an exceptional condition from which it cannot recover. Process will terminate. To search for possible resolutions to this issue, refer to the Xilinx answer database by going to http://www.xilinx.com/support/answers/index.htm and search with keywords 'ISim' and 'FATAL ERROR'. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.ERROR: The simulation failed to launch for the following reason:
The Simulation shut down unexpectedly during initialization. Please review the ISim log (isim.log) for details.
Please shut down ISim and retry the simulation. If the problem persists, please contact Xilinx support.
Time resolution is 1 fs
No active Database
Unable to execute live simulation command.
The simulation has terminated.
另外,求高手给些指点,怎么使用Rapidio ipcore。。。。。
想知道DSP传到FPGA里面的数据,怎么从Rapidio 里面读出来,这个需要自己去修改ipcore里面的什么地方?
反过来,FPGA向DSP传数据,该怎么写或者用Rapidio ?
谢谢啊,急!
有没有什么好的资料,给个资料名字就可以,自己去找。
新手,求指点。
