源程序为51FPGA的串口收发程序
`timescale 1ns / 1ps
module UART_tx(sys_clk,
sys_rstn,
rx_data,
rx_int,
rs232_tx,
clk_bps,
bps_start
input sys_clk;
input sys_rstn;
input [7:0]rx_data;
input clk_bps;
input rx_int;
output rs232_tx;
output bps_start;
reg rx_int0,rx_int1,rx_int2;
reg [9:0] tx_data;
reg bps_start_r;
reg tx_en;
reg [3:0]num;
reg rs232_tx_r;
wire neg_rx_int;
always @(posedge sys_clk or negedge sys_rstn)
begin
if(!sys_rstn)
begin
rx_int0 <=1'b0;
rx_int1 <=1'b0;
rx_int2 <=1'b0;
end
else
begin
rx_int0 <=rx_int;
rx_int1 <=rx_int0;
rx_int2 <=rx_int1;
end
end
assign neg_rx_int=rx_int2 & (~rx_int1);
begin
if(!sys_rstn)
begin
bps_start_r <=1'bz;
tx_en <=1'b0;
tx_data <=8'd0;
end
else if(neg_rx_int)
begin
bps_start_r <=1'b1;
tx_en <=1'b1;
tx_data <={1'b1,rx_data,1'b0};
end
else if(num==4'd10)
begin
bps_start_r <=1'b0;
tx_en <=1'b0;
end
end
begin
if(!sys_rstn)
begin
num<=4'd0;
rs232_tx_r<=1'b1;
end
else if(tx_en)
begin
if(clk_bps)
begin
num<=num+1'd1;
rs232_tx_r<=tx_data[num];
end
else if(num==4'd10)
num<=4'd0;
end
end
assign bps_start =bps_start_r;
assign rs232_tx =rs232_tx_r;
endmodule
对于程序里的黄色那条语句我有个不解。我知道一个这个程序的串口收发是10为,起始位+数据+停止位,前后加两位是表示起始位和停止位,但是起始位是0,结束位是1啊。望大神解答下。
