13楼
16楼
传一个用VB写的关于温度计的上位机,配合单片机串口程序在电脑端实时显示温度曲线
Public sina As Variant Public sinb As Variant Public sinc As Variant Public sind As Variant Public sine As Variant Public i As Variant Private Sub Command1_Click() If Command1.Caption = "关闭串口" Then MSComm1.PortOpen = False Command1.Caption = "打开串口" Timer1.Enabled = False Else Command1.Caption = "关闭串口" MSComm1.CommPort = Combo1.Text MSComm1.Settings = "" '"Combo2.text"'","'" combo3.text "'", "'" combo4.text "'" , "'"combo5.text "'"" MSComm1.InputMode = 0 MSComm1.PortOpen = True Timer1.Enabled = True End If End Sub Private Sub Form_Load() Dim i As Integer '生成串口号 For i = 1 To 20 With Combo1 .AddItem i End With Next Combo2.AddItem "600" Combo2.AddItem "1200" Combo2.AddItem "2400" Combo2.AddItem "4800" Combo2.AddItem "9600" Combo2.AddItem "57600" Combo2.AddItem "115200" Combo3.AddItem "n" Combo3.AddItem "e" Combo3.AddItem "o" Combo3.AddItem "s" Combo3.AddItem "m" Combo4.AddItem "8" Combo4.AddItem "9" Combo5.AddItem "1" Combo5.AddItem "1.5" Combo5.AddItem "2" i = 100 sina = 0 sind = 1400 sinc = 0 End Sub Private Sub Timer1_Timer() Dim buf$ Dim v As Double buf = Trim(MSComm1.Input) If Len(buf) <> 0 Then sina = sinc sinb = sind v = Asc(buf) + 256 '只传了低八位,所以直接加256,相当于把接受的数据& 0001 0000 0000 v = v / 10 Text1.Text = Text1.Text + Str(v) + Chr(13) + Chr(10) sinc = (sina + 100) sind = (Asc(buf) * 20) sine = Val(2000) Form1.Picture1.Line (sina, 5000 - sinb)-(sinc, 5000 - sind), sine If sinc = 10000 Then Picture1.Cls sina = 0 sinc = 0 End If End If End Sub Private Sub cmdquite_chick() MSComm1.PortOpen = False Unload Me End Sub
等一会再传一个EXE可执行文件
程序数据处理比较特殊
uint tmp() //get the temperature { float tt; uchar a,b; dsreset(); delay(1); tmpwritebyte(0xcc); tmpwritebyte(0xbe); a=tmpread(); b=tmpread(); temp=b; temp<<=8; //two byte compose a int variable temp=temp|a; tt=temp*0.0625; temp=tt*10+0.5; return temp; }
这个是单片机读18B20,传感器是12数据,但是我们只传送了低八位,因为常温状态下第九位为1,所以加256
ii =tmp(); // SBUF=ii>>8; // while(TI==0);//???????? // TI=0;//?????? // SBUF=ii; while(TI==0);//???????? TI=0;//??????
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
电流检测模块MAX4080S被打赏10分 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏10分 |
