也不算是完全完成了VGA篇的作业,只是把代码写好了,还没有来得及下载验证,因为手边没有VGA 线(这个都没有?!我的人生就是一个茶几,上面布满了各种杯具。。。
),在网上买的还没到。就先把代码交了,请@51FPGA 及各位大神指点谬误。
代码如下:
`timescale 1ns / 1ps
// Company:
// Engineer: Charles Wang
// Create Date: 08/06/2014
// Design Name: VGA
// Module Name: VGA
// Project Name:VGA
// Target Devices: EP4CE6E22C8
// Tool versions: Quartus II 13.1
// Description: 实现VGA彩色信号显示(800 X 600 X 60Hz)
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
// 部分代码移植自51FPGA源代码
module VGA(clk,rst_n,switch,hsync,vsync,disp_RGB);
input clk;//50 MHz 总线时钟
input rst_n;//异步复位,低电平有效
input [1:0]switch;//显示方式开关输入
output hsync;//行同步
output vsync;//场同步
output [2:0]disp_RGB;//RGB 输出
///////////////////////////寄存器及wire 定义//////////////////////////////////////////
reg [2:0]data;
reg [2:0]h_dat;
reg [2:0]v_dat;
reg [9:0]hcount;
reg [9:0]vcount;
wire vga_clk;
wire hcount_ov;
wire vcount_ov;
wire data_act;
wire hsync;
wire vsync;
PLL_VGA PLL(.inclk0(clk),.c0(vga_clk));//使用PLL IP核 产生40MHz vga_clk 时钟
parameter
hsync_end = 10'd127,
hdat_begin = 10'd215,
hdat_end = 10'd1015,
hpixel_end = 10'd1055,
vsync_end = 10'd3,
vdat_begin = 10'd26,
vdat_end = 10'd626,
vline_end = 10'd627;
always @(posedge vga_clk)
begin
if (hcount_ov)
hcount <= 10'd0;
else
hcount <= hcount + 10'd1;
end
assign hcount_ov = (hcount == hpixel_end);
//场扫描
begin
if (hcount_ov)
begin
if (vcount_ov)
vcount <= 10'd0;
else
vcount <= vcount + 10'd1;
end
end
assign vcount_ov = (vcount == vline_end);
//数据、同步信号输
assign dat_act = ((hcount >= hdat_begin) && (hcount < hdat_end))
&& ((vcount >= vdat_begin) && (vcount < vdat_end));
assign hsync = (hcount > hsync_end);
assign vsync = (vcount > vsync_end);
assign disp_RGB = (dat_act) ? data : 3'h00;
//************************显示数据处理部分*******************************
begin
case(switch[1:0])
2'd0: data <= h_dat; //选择横彩条
2'd1: data <= v_dat; //选择竖彩条
2'd2: data <= (v_dat ^ h_dat); //产生棋盘格
2'd3: data <= (v_dat ~^ h_dat); //产生棋盘格
endcase
end
always @(posedge vga_clk) //产生竖彩条
begin
if(hcount < 131)
v_dat <= 3'h7; //白
else if(hcount < 263)
v_dat <= 3'h6; //黄
else if(hcount < 395)
v_dat <= 3'h5; //青
else if(hcount < 527)
v_dat <= 3'h4; //绿
else if(hcount < 659)
v_dat <= 3'h3; //紫
else if(hcount < 791)
v_dat <= 3'h2; //红
else if(hcount < 923)
v_dat <= 3'h1; //蓝
else
v_dat <= 3'h0; //黑
end
always @(posedge vga_clk) //产生横彩条
begin
if(vcount < 79)
h_dat <= 3'h7; //白
else if(vcount < 158)
h_dat <= 3'h6; //黄
else if(vcount < 237)
h_dat <= 3'h5; //青
else if(vcount < 316)
h_dat <= 3'h4; //绿
else if(vcount < 395)
h_dat <= 3'h3; //紫
else if(vcount < 474)
h_dat <= 3'h2; //红
else if(vcount < 553)
h_dat <= 3'h1; //蓝
else
h_dat <= 3'h0; //黑
end
endmodule
由于我这里的ga_clk 是有PLL IP 核产生的,不知道怎么用modelsim 仿真,还请@51FPGA 及各位大神指点。
不过,到是对51FGPA 的源代码进行了仿真,请@51FPGA 及各位大神指点谬误,代码如下:
`timescale 1ns / 1ps ////////////////////////////////////////////////////////////////////////////////// // Company: // Engineer: Charles Wang // // Create Date: 08/07/2014 // Design Name: vga_tb // Module Name: vga_tb // Project Name:vga_tb // Target Devices: EP4CE6E22C8 // Tool versions: Quartus II 13.1 // Description: VGA test bench // // Dependencies: // // Revision: // Revision 0.01 - File Created // Additional Comments: // ////////////////////////////////////////////////////////////////////////////////// module vga_tb(); reg clk; reg rst_n; reg [1:0]switch; wire [2:0]disp_RGB; wire hsync; wire vsync; VGA vga_test(.rst_n(rst_n),.clock(clk),.switch(switch),.disp_RGB(disp_RGB),.hsync(hsync),.vsync(vsync)); ///////////////////////////////////////////////////////////////////////////////// initial begin rst_n = 1'b0; #10 rst_n = 1'b1; #10 clk = 1'b0; forever begin #10 clk = ~clk; end end initial begin switch = 2'b00; #1000000 switch = 2'b01; #1000000 switch = 2'b10; #1000000 switch = 2'b11; end endmodule
波形如下:
