编译内核时出现问题如下:
Samsung S3C4510 Ethernet driver version 0.1 (2002-02-20) <mac@os.nctu.edu.tw>
eth0: 00:40:95:36:35:34
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 512 bind 512)
VFS: Mounted root (romfs filesystem) readonly.
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/ \
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
Kernel panic: Attempted to kill init!
不知道是因为什么出现如上一句提示?此时超级终端不接受指示。我采用的是台湾网站的uClinux-Samsung-20020306.tar make menuconfig 时都是采用缺省设置。
