keil4 安装+破解 开始
1、运行此mdk72_a应用程序
2、弹出窗口,next》 继续往下
3、勾选“我已阅读。。同意。。”(世界上最大的谎言~)
4.自定义安装路径
5、一定要填上,邮箱要像写得像邮箱
6、等待安装~。~
7、直接 Next》
8、这两项可以勾掉不要
9、此时桌面上出现了Keil4 的桌面快捷方式
10、现在开始破解
11、弹出窗口,先复制 CID
12、打开
13、弹出窗口,将CID粘贴进去>选择ARM>点击Generate>出现破解码,将破解码复制
14、将破解码粘贴出来>Add LIC>下面出现LIC Added Sucessfully,破解成功~
PS:
第一次打开,将破解码粘贴入上图的时候,出现的不是LIC Added Sucessfully,而是
*** ERROR R206: NO REGISTRY ACCESS, ADMINISTRATION RIGHTS REQUIRED
当时没意识到是@买西瓜送熙熙提示过的那个情况
只是把错误粘贴到网上搜索,搜到解决办法:
所以,不仅是win8,win7的破解应该也需要以管理员权限运行
——回复可见内容——
用STM32点亮LED&RGB,程序如下:
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void GPIO_INIT()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOA, ENABLE);//??PC,PA???
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//???PC0?PC7
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//????
GPIO_Init(GPIOC, &GPIO_InitStructure);//???PC
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//???PA1,PA2,PA3
GPIO_Init(GPIOA, &GPIO_InitStructure);//???PA
void delay_us(u32 n)//ÑÓʱº¯Êý
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)//ÑÓʱº¯Êý
while(n--)
delay_us(1000);
int main(void)
RCC_Configuration();
GPIO_INIT();
while(1)
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);//LED????
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_4);//ÁÁ
delay_ms(300);
GPIO_SetBits(GPIOC,GPIO_Pin_4);//²»ÁÁ
GPIO_ResetBits(GPIOC,GPIO_Pin_5);//ÁÁ
delay_ms(300);
GPIO_SetBits(GPIOC,GPIO_Pin_5);//²»ÁÁ
GPIO_ResetBits(GPIOC,GPIO_Pin_6);//ÁÁ
delay_ms(300);
GPIO_SetBits(GPIOC,GPIO_Pin_6);//²»ÁÁ
GPIO_ResetBits(GPIOC,GPIO_Pin_7);//ÁÁ
delay_ms(300);
GPIO_SetBits(GPIOC,GPIO_Pin_7);//²»ÁÁ
GPIO_ResetBits(GPIOC,GPIO_Pin_0);//ÁÁ
delay_ms(300);
GPIO_SetBits(GPIOC,GPIO_Pin_0);//²»ÁÁ
GPIO_ResetBits(GPIOC,GPIO_Pin_1);//ÁÁ
delay_ms(300);
GPIO_SetBits(GPIOC,GPIO_Pin_1);//²»ÁÁ
GPIO_ResetBits(GPIOC,GPIO_Pin_2);//ÁÁ
delay_ms(300);
GPIO_SetBits(GPIOC,GPIO_Pin_2);//²»ÁÁ
GPIO_ResetBits(GPIOC,GPIO_Pin_3);//ÁÁ
delay_ms(300);
GPIO_SetBits(GPIOC,GPIO_Pin_3);//²»ÁÁ
GPIO_ResetBits(GPIOA,GPIO_Pin_1);// ˦
delay_ms(1000);
GPIO_SetBits(GPIOA,GPIO_Pin_1);
GPIO_ResetBits(GPIOA,GPIO_Pin_2);// ºì
delay_ms(1000);
GPIO_SetBits(GPIOA,GPIO_Pin_2);
GPIO_ResetBits(GPIOA,GPIO_Pin_3);// ÂÌ
delay_ms(1000);
GPIO_SetBits(GPIOA,GPIO_Pin_3);
GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2);// ×Ï
delay_ms(1000);
GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2);
GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3);// ˦
delay_ms(1000);
GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3);
GPIO_ResetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3);// ³È
delay_ms(1000);
GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
这是关于循环点亮LED&RGB代码的修改及精简
这样就不必写太多次重复的循环
不大懂位操作,所以用这个方法啦
【方法:将GPIO_Pin_x 等需要的管脚直接放进数组里
循环的时候,利用数组内下标的变化来进行调用,省去许多麻烦】
后面的的作业请给我多一点点的时间~
被教师资格证残害过后,真的伤不起啊!
我会抓紧时间好好学的~请不要让我进决赛!
GPIO_InitTypeDef GPIO_InitStructure; //定义GPIO结构体
/*延时函数 微秒*/
u8 j;
while(n--)
for(j=0;j<10;j++);
/*延时函数 毫秒*/
while(n--)
delay_us(1000);
void GPIO_INIT()
//使能GPIO时钟 PC
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //RCC_APB2Periph_GPIOC 开启GPIOX的时钟 ENABLE\DISABLE 打开or关闭
//结构体配置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//引脚:使用使用PC^0-7
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //速度:配置晶振
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //模式:Out_PP推挽输出,可做输出,输入
//GPIO PC初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//RCC_APB2Periph_GPIOA 开启GPIOX的时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//引脚:使用使用PA^1-3
int main()
int i;
int c;
int a[8]={GPIO_Pin_0,GPIO_Pin_1,GPIO_Pin_2,GPIO_Pin_3,GPIO_Pin_4,GPIO_Pin_5,GPIO_Pin_6,GPIO_Pin_7}; //将各个端口放进数组,以简化混循环
int b[3]={GPIO_Pin_1,GPIO_Pin_2,GPIO_Pin_3}; //将各个端口放进数组,以简化循环
GPIO_INIT();
//无限循环
while(1)
//循环点亮D0-D7小灯
for(i=0;i<8;i++)
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); //输出高电平 先关掉PC^0-7
delay_ms(100);
GPIO_ResetBits(GPIOC,a[i]); //输出低电平 点亮LED
delay_ms(200);
GPIO_SetBits(GPIOC,a[i]); //输出高电平 熄灭LED
delay_ms(200);
//循环点亮RGB
for(c=0;c<3;c++)
GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3); //输出高电平 先关掉PA^1-3
delay_ms(100);
GPIO_ResetBits(GPIOA,b[c]); //输出低电平 点亮LED
delay_ms(300);
GPIO_SetBits(GPIOA,b[c]); //输出高电平 熄灭LED
delay_ms(100);
此代码实现按键s1按下,数码管数字+1
我使用switch函数,不过并不是把所有的数字一一列出来
而是通过使个位,十位的数字分别用Num函数输出
这样就避免了一个一个数字全部列出的麻烦
代码也比较简单易懂
值得注意的是
每打开一个数码管前要将数码管灯先关了,关了2次
不懂为什么,只关一次时的话
十位就会跳出奇怪的数字,搞了半天╮(╯_╰)╭
先上这个代码,稍修改一下再接着上
/*延时函数 微秒*/
u8 j;
while(n--)
for(j=0;j<10;j++);
/*延时函数 毫秒*/
while(n--)
delay_us(1000);
void GPIO_INIT()
//使能GPIO时钟 PB
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //RCC_APB2Periph_GPIOB 开启GPIOB的时钟 ENABLE\DISABLE 打开or关闭
//结构体配置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_1|GPIO_Pin_15;//数码管使用PB^5-9 12-14
//GPIO PB初始化
GPIO_Init(GPIOB, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //RCC_APB2Periph_GPIOB 开启GPIOB的时钟 ENABLE\DISABLE 打开or关闭
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;//按键使用PC8-11
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //模式:Out_PP推挽输出,可做输出,输入 !!!
void Num(int z)
switch(z)//分别点亮对应数字的数码管
case 0 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
case 1 : GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break;
case 2 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14); break;
case 3 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break;
case 4 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12); break;
case 5 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14); break;
case 6 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
case 7 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12); break;
case 8 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
case 9 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break;
int main()
int g=0,s=0; //i被按下的次数,g个位的数,s十位的数
GPIO_INIT();
GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
delay_ms(50); //关闭全部所用管脚
while(1)
GPIO_SetBits(GPIOB,GPIO_Pin_1); //打开个位数码管
Num(g); //用switch函数分别点亮个位,十位
delay_ms(5);
GPIO_ResetBits(GPIOB,GPIO_Pin_1); //关闭个位
GPIO_SetBits(GPIOB,GPIO_Pin_15); //打开十位
Num(s);
delay_ms(5);
GPIO_ResetBits(GPIOB,GPIO_Pin_15); //关掉十位数码管
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)) //判断按键是否被按下
delay_ms(100); //延时去抖
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)) //判断按键是否被按下 假如端口PC8为低电平
g++; //按键被按下,次数+1
if(g==10)
s++;
g=0;
最终代码完成
可实现按键切换
数字从00-99
感觉代码还算比较简朴,不复杂
挺好理解的
/*延时函数 微秒*/
u8 j;
while(n--)
for(j=0;j<10;j++);
/*延时函数 毫秒*/
while(n--)
delay_us(1000);
void GPIO_INIT()
//使能GPIO时钟 PB
//结构体配置
//GPIO PB初始化
void Num(int z)
int main()
int i=2,g=0,s=0,c=0,n=5; //i被按下的次数,n延时变量
int v[2]={GPIO_Pin_8,GPIO_Pin_9}; //作管脚切换用
int b[2]={0,1};
GPIO_INIT();
while(1)
delay_ms(n);
Num(s);
delay_ms(n);
//如果s3被按下,i根据按下次数的奇偶来切换0/1
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)) //判断按键是s3否被按下
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)) //再次判断按键是s3否被按下
c++;
i=c%2; //判断次数奇偶
//根据次数的奇偶来切换s1/s2
if(!GPIO_ReadInputDataBit(GPIOC,v[i])&&i==b[i]) //(哪个管脚,为1/0)
if(i==0) {n=5;} //延时为5
if(i==1) {n=50;} //延时为50
g++; //按键被按下,各位+1
if(g==10)
s++; //若个位为9,十位+1,个位置0
g=0;
| PCF8574功能模块及其使用被打赏¥20元 | |
