树莓的基本环境已经搭建完了,但是有个问题是,如果由于网络变动,导致PI的ip地址发生变化,那么就无法通过ssh进入PI,所以为了能正确获得PI的ip,可以在开机的时候通过PI发送邮件给自己的邮箱,告诉你PI的IP。
1. 写一个python脚本startup_mailer.py,用来发送邮件(参考elinux.org/RPi_Email_IP_On_Boot_Debian) #!/usr/bin/env python
import subprocess import smtplib
import socket
import datetime
from email .mime. text import MIMEText
from email .mime. multipart import MIMEMultipart
from email .mime. image import MIMEImage
mailto = 'send email Address'
gmail_user = 'Your gmail Address'
gmail_password = 'Your gmail password'
def send_mail(to_list ,sub):
smtpserver = smtplib.SMTP('smtp.gmail.com' ,587)
smtpserver .ehlo()
smtpserver .starttls()
smtpserver .ehlo()
smtpserver .login( gmail_user,gmail_password )
today = datetime.date.today
arg = 'ip route list'
p = subprocess.Popen(arg ,shell= True,stdout =subprocess.PIPE)
data = p. communicate()
split_data = data[ 0].split ()
ipaddr = split_datap[split_data.index ('src')+ 1]
PI_ip = 'Your ip is %s' % ipaddr
content = "<a href = 'http://xdocutju.com'>"+PI_ip +"</a>"+"<br><img src=" +"cid:img1"+">"
msgText = MIMEText(content,_subtype ='html', _charset='gb2312' )
fp = open( '/home/pi/ocr_pi.png','rb' )
msgImg = MIMEImage(fp.read ())
fp.close()
msgImg .add_header('Content-ID','<img1>' )
msgRoot = MIMEMultipart('multipart')
msgRoot = attach(msgText)
msgRoot = attach(msgImg)
msgRoot ['Subject'] = sub
msgRoot ['From'] = gmail_user
msgRoot ['To'] = to_list
smtpserver .sendmail(gmail_user,[to_list ],msgRoot.as_string())
smtpserver .quit()
return True
if __name__ == '__main__'
if send_main(mailto,'hello from PI' ):
print "send success"
else
print "send fail"
2. 将脚本startup_mailer.py移至/etc/init.d/目录下
修改其权限:sudo chmod +x /etc/init.d/startup_mailer.py
代码测试: sudo /etc/init.d/startup_mailer.py start
.png)
将脚本加入启动清单,重启,成功
sudo update-rc.d startup_mailer.py defaults
.png)
如果以后要删除这个任务,sudo update-rc.d startiup_mailer.py remove
Done!
