电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 删删作业【~渣渣作业停止更新~】
共67条 6/7 |‹ 2 3 4 5 6 7 跳转至
2014-11-26 22:45:37     打赏
51楼
按键中断
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
EXTI_InitTypeDef   EXTI_InitStructure;
GPIO_InitTypeDef   GPIO_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
/* Private function prototypes -----------------------------------------------*/
void EXTIkeyS1_Config(void);
void EXTIkeyS2_Config(void);
void EXTIkeyS3_Config(void);
void EXTIkeyS4_Config(void);
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
void USART_int(long BaudRate)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//推挽输出
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
  USART_InitStructure.USART_BaudRate = BaudRate;//usart传输波比特
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//一帧传输或接收8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//在帧结尾传输1个停止位
  USART_InitStructure.USART_Parity = USART_Parity_No;//奇偶失能
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//硬件流控制失能
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收使能,发送使能
  USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;//时钟低电平活动
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;//始终低电平
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;//时钟第二边缘进行数据捕获
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据的时钟不从SCLK输出
  USART_ClockInit(USART1, &USART_ClockInitStructure);//使能USART1时钟
  USART_Init(USART1, &USART_InitStructure);//初始化USART1
  USART_Cmd(USART1, ENABLE);//使能USART1外设
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能中断
  /* Configure four bit for preemption priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
  /* Enable the USART1 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
int main(void)
  RCC_Configuration();
  EXTIkeyS1_Config();
  EXTIkeyS2_Config();
  EXTIkeyS3_Config();
  EXTIkeyS4_Config();
  USART_int(115200);
  printf("Config done,waiting for interrupt......\r\n");
  while (1)
  /* Enable GPIOA clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  /* Configure PA.00 pin as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  /* Enable AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  /* Connect EXTI0 Line to PA.00 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
  /* Configure EXTI0 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line8;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable and set EXTI0 Interrupt to the lowest priority */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource9);
  EXTI_InitStructure.EXTI_Line = EXTI_Line9;
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource10);
  EXTI_InitStructure.EXTI_Line = EXTI_Line10;
  NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource11);
  EXTI_InitStructure.EXTI_Line = EXTI_Line11;
void EXTI15_10_IRQHandler(void)
	if(EXTI_GetITStatus(EXTI_Line11) != RESET)
     GPIO_SetBits(GPIOC,GPIO_Pin_6|GPIO_Pin_7);
     printf("S2 interrupt ......\r\n");
     EXTI_ClearITPendingBit(EXTI_Line9);
	if(EXTI_GetITStatus(EXTI_Line10) != RESET)
     GPIO_SetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5);
     printf("S1 interrupt ......\r\n");
     EXTI_ClearITPendingBit(EXTI_Line8);
void EXTI9_5_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line9) != RESET)
     GPIO_SetBits(GPIOC,GPIO_Pin_2|GPIO_Pin_3);
	if(EXTI_GetITStatus(EXTI_Line8) != RESET)
     GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1);
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
2014-11-26 22:53:32     打赏
52楼
0.5S闪烁——LED1 & LED2
1S闪烁——LED3 & LED4
1.5S闪烁——LED5 & LED8(我也不知道它为什么不闪)
#include "misc.h"
void RCC_Configuration(void);
void NVIC_Configuration(void);
void GPIO_Configuration(void);
void TIM2_Configuration(void);
void TIM3_Configuration(void);
void TIM7_Configuration(void);
int main(void)
 NVIC_Configuration();
 GPIO_Configuration();
 TIM2_Configuration();
 TIM3_Configuration();
 TIM7_Configuration();
 while (1) {
	/*每0.5s发生一次更新事件(进入中断服务程序) */
 TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
 TIM_TimeBaseStructure.TIM_Period = 17999;
 TIM_TimeBaseStructure.TIM_Prescaler = 1999;
 TIM_TimeBaseStructure.TIM_ClockDivision = 0;
 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
 TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
 TIM_ClearFlag(TIM2, TIM_FLAG_Update);
 TIM_ARRPreloadConfig(TIM2, DISABLE);
 TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
 TIM_Cmd(TIM2, ENABLE);
	/*每1s发生一次更新事件(进入中断服务程序)*/
 TIM_TimeBaseStructure.TIM_Period = 35999;
 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//计数方式
 TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);//初始化
 TIM_ClearFlag(TIM3, TIM_FLAG_Update);//清除更新标志位
 TIM_ARRPreloadConfig(TIM3, DISABLE);//预装载寄存器的内容被立即上传到影子寄存器上
 TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);//使能中断源
 TIM_Cmd(TIM3, ENABLE);//使能
	/*每1.5s发生一次更新事件(进入中断服务程序)*/
 TIM_TimeBaseStructure.TIM_Period = 53999;
 TIM_TimeBaseInit(TIM7, &TIM_TimeBaseStructure);
 TIM_ClearFlag(TIM7, TIM_FLAG_Update);
 TIM_ARRPreloadConfig(TIM7, DISABLE);
 TIM_ITConfig(TIM7, TIM_IT_Update, ENABLE);
 TIM_Cmd(TIM7, ENABLE);
  SystemInit();
 /* TIM3 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM3|RCC_APB1Periph_TIM7, ENABLE);
 /* GPIOC clock enable */
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);//使能PD时钟,使能IO时钟
  GPIO_ResetBits(GPIOD,GPIO_Pin_2);//蜂鸣器
 /* Enable the TIM2 gloabal Interrupt*/
 NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
	/* Enable the TIM3 gloabal Interrupt*/
 NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
	/* Enable the TIM7 gloabal Interrupt*/
 NVIC_InitStructure.NVIC_IRQChannel = TIM7_IRQn;
 GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_7;
#include "stm32f10x_it.h"
void TIM2_IRQHandler(void)
 if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) {
  /* Clear TIM2 update interrupt */
  TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
  GPIO_WriteBit(GPIOC, GPIO_Pin_0|GPIO_Pin_1, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_0|GPIO_Pin_1)));
 void TIM3_IRQHandler(void)
 if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) {
  /* Clear TIM3 update interrupt */
  TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
  GPIO_WriteBit(GPIOC, GPIO_Pin_2|GPIO_Pin_3, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_2|GPIO_Pin_3)));
void TIM7_IRQHandler(void)
 if (TIM_GetITStatus(TIM7, TIM_IT_Update) != RESET) {
  /* Clear TIM7 update interrupt */
  TIM_ClearITPendingBit(TIM7, TIM_IT_Update);
  GPIO_WriteBit(GPIOC,GPIO_Pin_4|GPIO_Pin_7, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_4|GPIO_Pin_7)));
2014-11-27 13:02:40     打赏
53楼
妹纸,能不能把复制粘贴的打印内容稍微改改
2014-11-27 13:25:59     打赏
54楼
手抖
2014-12-04 14:32:06     打赏
55楼
#include
void delay_us(u32 n)
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
void  delay_ms(u32 n)
	while(n--)
	delay_us(1000);
{ SystemInit();
  GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void PWM_Config()
  uint16_t PrescalerValue = 0;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
	/* TIM2 clock enable */
  /* GPIOA  enable */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
	  /* Compute the prescaler value */
  PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 0x07FF;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);
  /* PWM1 Mode configuration: Channel3 */
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
  /* PWM1 Mode configuration: Channel4 */
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  TIM_ARRPreloadConfig(TIM2, ENABLE);
void PWM_TEST()
{ unsigned int temp0=0,temp1=0,temp2=0,i;
while(1){
   for(i=1;i<=7;i++)
	switch(i){
	 case 1:temp0=2047,temp1=1024,temp2=512;
	 TIM_SetCompare2(TIM2,temp0); delay_ms(200);
         TIM_SetCompare3(TIM2,temp1); delay_ms(200);
         TIM_SetCompare4(TIM2,temp2); delay_ms(200);break;
         case 2:temp0=2047,temp1=512,temp2=1024;
         case 3:temp0=1024,temp1=2047,temp2=512;
         case 4:temp0=1024,temp1=512,temp2=2047;
         TIM_SetCompare4(TIM2,temp2); delay_ms(200); break;
	case 5:temp0=512,temp1=2047,temp2=1024;
        case 6:temp0=512,temp1=1024,temp2=512;
        case 7:temp0=2047,temp1=2047,temp2=2047;
int main(void)
  USART_int(115200);
	printf(" config done...\r\n");
	PWM_Config();
	delay_ms(1000);
	while(1)
		PWM_TEST();
  while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
  while (1)
#endif
2014-12-08 21:44:51     打赏
56楼
不错,有点意思了
2014-12-15 22:43:38     打赏
57楼
pwm_rgb_adC
#include
#define VREF 3.3
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
  SystemInit();
    /* PA10 USART1_Rx  */
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
void PWM_Config()
  /* GPIOA  enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO  , ENABLE);
void ADC_CONFIG(){
    ADC_InitTypeDef ADC_InitStructure;
    #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  /* ADCCLK = PCLK2/2 */
  RCC_ADCCLKConfig(RCC_PCLK2_Div2);
#else
  /* ADCCLK = PCLK2/4 */
#endif
  ADC_DeInit(ADC1);//复位ADC1,重设外设ADC1寄存器
  /* Enable ADC1 and GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
    /* Configure PB0 (ADC Channel14) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//模拟输入引脚
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//独立工作模式
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;//扫描方式
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//连续转换
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//外部触发禁止
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//数据右对齐
  ADC_InitStructure.ADC_NbrOfChannel = 1;//用于转换的通道数
  ADC_Init(ADC1, &ADC_InitStructure);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
int Get_ADC(){
     /* ADC1 regular channel configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);// 初始化第八通道
    /* Enable ADC1 reset calibration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
    return ADC_GetConversionValue(ADC1);
void TEST()
    float Volt=0.00;
    unsigned int temp0,temp1,temp2,ADValue = 0;
    while(1){
      ADValue = Get_ADC();
      Volt = VREF*ADValue/4095;
      printf("===============================\r\n");
      printf("The ADC value is:%d\r\n",ADValue);
      printf("The Volt is:%f V\r\n",Volt);
      TIM_SetCompare2(TIM2, temp0);
      TIM_SetCompare3(TIM2, temp1);
      TIM_SetCompare4(TIM2, temp2);
    if(ADValue>0)
				 temp0=ADValue/1024;
                 temp1=ADValue/502;
                 temp2=ADValue/1;
int main(void)
    USART_int(115200);
    ADC_CONFIG();
    Get_ADC();
    PWM_Config();
    delay_ms(200);
    while(1)
       TEST();
			 delay_ms(100);
  while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
  while (1)
#endif
2014-12-15 22:44:57     打赏
58楼
IIC计数
#include <stdio.h>
#define VREF 3.3
unsigned char i=0;
unsigned char count=0;
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
int Display[10]={ GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8,
                    GPIO_Pin_9|GPIO_Pin_12,
                    GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5,
                  GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5,
                    GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5,
                    GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5,
                  GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5,
                    GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12,
                  GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14,
                    GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14 };
void Dis_number(unsigned char i)
    char one=0,ten=0;
    one=i%10; ten=i/10;
    GPIO_SetBits(GPIOB,GPIO_Pin_1);
    GPIO_ResetBits(GPIOB,Display[one]);
    delay_ms(10);
    GPIO_ResetBits(GPIOB,GPIO_Pin_1);
    GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
    GPIO_SetBits(GPIOB,GPIO_Pin_15);
    GPIO_ResetBits(GPIOB,Display[ten]);
    delay_ms(10);
    GPIO_ResetBits(GPIOB,GPIO_Pin_15);
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //72HMz
  RCC_PLLCmd(ENABLE);
	   //SystemInit();
    USART_InitStructure.USART_BaudRate = BaudRate;//??????
void GPIO_INIT()
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
void Iic1_Init(void)
        I2C_InitTypeDef I2C_InitStructure;
       	RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
        //PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA
        /* Configure IO connected to IIC*********************/
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10 | GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
        I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;//配置I2C模式
        I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;//该参数只有在I2C工作在快速模式下有意义
        I2C_InitStructure.I2C_OwnAddress1 = 0xA0;//设置第一个设备自身地址
        I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;//使能应答
        I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;//地址为7位
        I2C_InitStructure.I2C_ClockSpeed = 400000;//时钟速率 400KHZ
        I2C_Cmd(I2C2, ENABLE);
        I2C_Init(I2C2, &I2C_InitStructure);
        I2C_AcknowledgeConfig(I2C2, ENABLE);
void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte)
        while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));
        I2C_GenerateSTART(I2C2,ENABLE);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT));
        I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
        I2C_SendData(I2C2, write_address);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
        I2C_SendData(I2C2, byte);
        I2C_GenerateSTOP(I2C2, ENABLE);
        do
                /* Send START condition */
                I2C_GenerateSTART(I2C2, ENABLE);
                /* Read I2C2 SR1 register */
                /* Send EEPROM address for write */
                I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter);
        }while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002));
        /* Clear AF flag */
        I2C_ClearFlag(I2C2, I2C_FLAG_AF);
        /* STOP condition */
unsigned char I2C2_ReadByte(unsigned char  id, unsigned char read_address)
        unsigned char temp;
        while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){}
        I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter);
        I2C_SendData(I2C2, read_address);
        I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
        I2C_AcknowledgeConfig(I2C2, DISABLE);
        while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED)));
        temp = I2C_ReceiveData(I2C2);
        return temp;
void EXTI9_5_IRQHandler(void)  //s1
     i++;
     I2C2_WriteByte(0xA0,0,i);
int main(void)
  USART_int(115200);
  GPIO_INIT();
	Iic1_Init();
	EXTIkeyS1_Config();
	delay_ms(1000);
	while(1)
     count=I2C2_ReadByte(0xA0,0);
     Dis_number(count);
  while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
  while (1)
#endif
2014-12-15 22:47:14     打赏
59楼
SPI_串口显示
#include <stm32f10x.h>
#include <stdio.h>
#include "spi_flash.h"
#define VREF 3.3
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define RxBufferSize1   (countof(TxBuffer1) - 1)
#define countof(a)      (sizeof(a) / sizeof(*(a)))
#define  BufferSize (countof(Tx_Buffer)-1)
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
#define  FLASH_WriteAddress     0x00000
#define  FLASH_ReadAddress      FLASH_WriteAddress
#define  FLASH_SectorToErase    FLASH_WriteAddress
#define  sFLASH_ID              0xEF3015     //W25X16
//#define  sFLASH_ID              0xEF4015   //W25Q16
#define buff_size  16;
char rx_buff_count=0;
uint8_t Tx_Buffer[4096] ;  //发送缓冲
uint8_t Rx_Buffer[BufferSize];  //接受缓冲
__IO uint32_t DeviceID = 0;  //装置ID
__IO uint32_t FlashID = 0; //闪存ID
__IO TestStatus TransferStatus1 = FAILED;  //状态测试
/**************延时函数*******************/
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
void Delay(__IO uint32_t nCount);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
char *int_to_string(int number,char *strnum)//整形数据转换为字符型
int j=0,i=0,n=0;
char temp;
while(number>0)
*(strnum+j)=number%10+48;
j++;
number=number/10;
n++;
for(i=0;i<n/2;i++)
temp=*(strnum+j+i-n);
*(strnum+j+i-n)=*(strnum+j-i-1);
*(strnum+j-i-1)=temp;
strnum[n]='\0';
return strnum;
  RCC_DeInit();
  RCC_DeInit();//将RCC寄存器重设为缺省值
  RCC_HSICmd(ENABLE);//使能内部高速晶振
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//HSI晶振返回reset
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//选择HSI作为系统时钟
  RCC_HSEConfig(RCC_HSE_OFF);//HSE晶振关
  RCC_LSEConfig(RCC_LSE_OFF);//LSE晶振关
  RCC_PLLCmd(ENABLE);//使能PLL状态
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);//ADC时钟=PCLK/4
  RCC_PCLK2Config(RCC_HCLK_Div1);//APB2时钟=HCLK
  RCC_PCLK1Config(RCC_HCLK_Div2);//APB1时钟=HCLK/2
  RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHB时钟=系统时钟
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//选择PLL作为系统时钟
  GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
        - One Stop Bit
        - No parity
  while(BufferLength--)
    if(*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
  for(; nCount != 0; nCount--);
void ADC_CONFIG(){
#else
#endif
ADC_DeInit(ADC1);
  /* Enable ADC1 */
int Get_ADC(){
void SPI_TEST()
    int i=0;
    int ADValue = 0;
    float Volt=0.00;
    char shuzu[100];
    for(i=0;i<5;i++){
      delay_ms(500);
    printf("\r\n这是一个2M SPI总线flash(W25X16)测试 \r\n");
    SPI_FLASH_Init();
    /* Get SPI Flash Device ID */
    DeviceID = SPI_FLASH_ReadDeviceID();
    Delay( 200 );
    /* Get SPI Flash ID */
    FlashID = SPI_FLASH_ReadID();
    printf("\r\n FlashID is 0x%X,  Manufacturer Device ID is 0x%X\r\n", FlashID, DeviceID);
    /* Check the SPI Flash ID */
    if (FlashID == sFLASH_ID)  /* #define  sFLASH_ID  0xEF3015 */
        printf("\r\n 检测到华邦flash W25X16 !\r\n");
        /* Erase SPI FLASH Sector to write on */
        SPI_FLASH_SectorErase(FLASH_SectorToErase);
        /*写缓存并发送*/
        SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
        printf("\r\n写入的数据是:%s \r\t", Tx_Buffer);
        /* 读出刚才写入的数据*/
        SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
        printf("\r\n读出的数据是:%s \r\n", Rx_Buffer);
        TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
        if( PASSED == TransferStatus1 )
            printf("\r\n 2M SPI总线flash(W25X16)测试成功!\n\r");
        else
            printf("\r\n 2M SPI总线flash(W25X16)测试失败!\n\r");
    }// if (FlashID == sFLASH_ID)
    else
        printf("\r\n 未检测到 W25X16 ID!\n\r");
    SPI_Flash_PowerDown();
    printf("\r\n=================================================\n\r");
int main(void)
  USART_int(115200);
  ADC_CONFIG();
  Get_ADC();
  delay_ms(1000);
  while(1){
	SPI_TEST();
    delay_ms(1000);
  while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
  while (1)
#endif
2014-12-16 15:22:11     打赏
60楼
这个是占坑的节奏么?
