“视频”不是“视屏”
你计数最多到12? 哪个按键是切换扫描速度的没看出来,貌似你是10以后才出现动态扫描的效果诶~
代码有点多,本人12,所以只做了12进制,S4是切换键,S1,S2,S3是计数键,视频在前面,希望大家看得懂。。。
#include "stm32f10x.h" #include "stm32_eval.h" GPIO_InitTypeDef GPIO_InitStructure; void RCC_Configuration(void) { RCC_DeInit(); RCC_HSICmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); RCC_HSEConfig(RCC_HSE_OFF); RCC_LSEConfig(RCC_LSE_OFF); RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); RCC_ADCCLKConfig(RCC_PCLK2_Div4); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2); } void GPIO_INIT() { //// 按键初始化 RCC_Configuration(); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOC, &GPIO_InitStructure); //// 数码管初始化 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOB, &GPIO_InitStructure); } void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } void delay_ms(u32 n) ///延时 { while(n--) delay_us(1000); } /** * @brief Main program. * @param None * @retval None */ int main(void) { int i,j,k,l; //定义变量 RCC_Configuration(); ///时钟初始化 GPIO_INIT(); ////管脚初始化 while(1){ ////切换键识别 if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_11)) {delay_ms(80); ///防抖 if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_11)){i++;}} ////切换键S4自加 ///S1 工作计数 if(i%3==0){ ///S1 工作计数 if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)) //按下S1 {delay_ms(80); ///防抖 if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){j++;}} ///S1自加 if(j>12){j=0;} //12个循环 GPIO_ResetBits(GPIOB,GPIO_Pin_1); //关闭PB1 GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); //关闭数码管管脚 switch(j){ case 0 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 1 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 2 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14); break; case 3 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5); break; case 4 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5); break; case 5 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5); break; case 6 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5); break; case 7 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12); break; case 8 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 9 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break; case 10 : ////动态扫描 GPIO_SetBits(GPIOB,GPIO_Pin_1);//导通个位三极管Q2 GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//个位显示0 delay_ms(5);//延时 GPIO_ResetBits(GPIOB,GPIO_Pin_1);//截止三极管Q2 GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//关闭数码管管脚 GPIO_SetBits(GPIOB,GPIO_Pin_15);//导通十位三极管Q1 GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);//十位显示 1 delay_ms(5); GPIO_ResetBits(GPIOB,GPIO_Pin_15);//截止Q1 GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//关闭数码管管脚 break; case 11 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(5); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(5); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 12 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14); delay_ms(5); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(5); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; } } ////S2工作计数 if(i%3==1){ if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))//S2工作 {delay_ms(80); if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){k++;}} ///S2自加 if(k>12){k=0;} GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); switch(k){ case 0 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8); break; case 1 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 2 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5); break; case 3 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5); break; case 4 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5); break; case 5 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5); break; case 6 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5); break; case 7 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12); break; case 8 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 9 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break; case 10 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); delay_ms(20); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(20); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 11 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(20); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(20); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 12 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14); delay_ms(20); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(20); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; } } ///S3工作计数 if(i%3==2){ if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)) {delay_ms(80); if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){l++;}} if(l>12){l=0;} GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); switch(l){ case 0 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8); break; case 1 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 2 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5); break; case 3 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5); break; case 4 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5); break; case 5 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5); break; case 6 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5); break; case 7 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12); break; case 8 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 9 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break; case 10 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); delay_ms(50); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(50); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 11 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(50); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(50); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 12 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14); delay_ms(50); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(50); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; } } } }
串口控制LED转速
这代码之前改来改去改到弄不出了,害得昨晚白忙活,现在终于被我弄回来了,代码先这样,待改进争取做得更好
密码 12
视频地址:http://player.youku.com/player.php/sid/XODIxNTQ1NzI4/v.swf
#include "stm32f10x.h" #include "stm32_eval.h" #include "math.h" #include "stdio.h" #define buff_size 16; char rx_buff[],rx_buff_count=0; GPIO_InitTypeDef GPIO_InitStructure; void RCC_Configuration(void) { RCC_DeInit(); RCC_HSICmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); RCC_HSEConfig(RCC_HSE_OFF); RCC_LSEConfig(RCC_LSE_OFF); RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); RCC_ADCCLKConfig(RCC_PCLK2_Div4); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2); } void GPIO_INIT() { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); } void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } void delay_ms(u32 n) { while(n--) delay_us(1000); } void USART_int(long BaudRate) { //
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* PA10 USART1_Rx */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate;//?????? USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1 USART_InitStructure.USART_Parity = USART_Parity_No;//???? USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//?????????? USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_ClockInit(USART1, &USART_ClockInitStructure); USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); /* Configure four bit for preemption priority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4); /* Enable the USART1 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; // NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } /*void func(void) { int i,j; GPIO_SetBits(GPIOC,0x00ff); i=0x0010; for(j=1;j<=4;j++) { i>>=1; GPIO_ResetBits(GPIOC,i); delay_ms(60); GPIO_SetBits(GPIOC,i); } i=0x0008; for(j=1;j<=4;j++) { i<<=1; GPIO_ResetBits(GPIOC,i); delay_ms(60); GPIO_SetBits(GPIOC,i); } }*/ void USART_SendStr(char *str) { while((*str)!='\0') {USART_SendData(USART1,*str++); while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); } } char strcmp(char *S,char *C,char LEN) { char count; for(count=0;count>=1; GPIO_ResetBits(GPIOC,i); delay_ms(60); GPIO_SetBits(GPIOC,i); } i=0x0008; for(j=1;j<=4;j++) { i<<=1; GPIO_ResetBits(GPIOC,i); delay_ms(60); GPIO_SetBits(GPIOC,i); }}break;} case 8: flag = strcmp(S,"time=100",8); if(flag==1) {while(1){GPIO_SetBits(GPIOC,0x00ff); i=0x0010; for(j=1;j<=4;j++) { i>>=1; GPIO_ResetBits(GPIOC,i); delay_ms(100); GPIO_SetBits(GPIOC,i); } i=0x0008; for(j=1;j<=4;j++) { i<<=1; GPIO_ResetBits(GPIOC,i); delay_ms(100); GPIO_SetBits(GPIOC,i); }}break;} case 9: flag = strcmp(S,"time=1000",9); if(flag==1) {while(1){ GPIO_SetBits(GPIOC,0x00ff); i=0x0010; for(j=1;j<=4;j++) { i>>=1; GPIO_ResetBits(GPIOC,i); delay_ms(1000); GPIO_SetBits(GPIOC,i); } i=0x0008; for(j=1;j<=4;j++) { i<<=1; GPIO_ResetBits(GPIOC,i); delay_ms(1000); GPIO_SetBits(GPIOC,i); }}break;} } } } void input_ASK() { char j; commcmp(rx_buff,rx_buff_count); rx_buff_count=0; for (j=0;j"); } int main(void) { RCC_Configuration(); GPIO_INIT(); USART_int(9600); USART_SendStr("SyStem booting......\r\n"); USART_SendStr("\n>"); while(1){} } /*int main(void) { char str[]="hello,gxnu\r\n"; unsigned char flag; RCC_Configuration(); GPIO_INIT(); USART_int(9600); GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); delay_ms(100); GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); USART_SendStr("SyStem booting......\r\n"); USART_SendStr("\n>"); while(1){ } }*/ void USART1_IRQHandler(void) { while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET) { } if(USART_ReceiveData(USART1)==0x0d) {input_ASK();} else { USART_SendData(USART1,USART_ReceiveData(USART1)); rx_buff[rx_buff_count]= USART_ReceiveData(USART1); rx_buff_count++; } USART_ClearFlag(USART1, USART_FLAG_RXNE); }
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 | |
汽车电子中巡航控制系统的使用被打赏10分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏100分 |
