21号的作业,burden只能扔这里了。【更新: 时钟嘀嗒和18B20】
这是我制作的PCB图
焊之前的各种零件图已经最后的成品图。
最后说一下原理:我用的FT232的芯片,然后跳线帽控制VCC out的是5V还是3.3V,电源提示是红色LED灯,用绿色LED灯负极连接TX和RX,正极连1.5K电阻,电阻上拉到VCC in。这样可以在有数据传输的时候让绿色LED灯变亮。
* @file GPIO/IOToggle/main.c
* @author MCD Application Team
* @version V3.5.0
* @date 08-April-2011
* @brief Main program body.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
© COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void GPIO_INIT()
{ //GPIOA(跑马灯)的初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
GPIO_Init(GPIOA, &GPIO_InitStructure);
//GPIOC(LED)的初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|
GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
//延时微秒
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
//延时毫秒
void delay_ms(u32 n)
while(n--)
delay_us(1000);
* @brief Main program.
* @param None
* @retval None
int main(void)
RCC_Configuration();
GPIO_INIT();
while(1){
//LED转圈
GPIO_ResetBits(GPIOC,GPIO_Pin_3);//D4灯亮
delay_ms(50);
GPIO_SetBits(GPIOC,GPIO_Pin_3);//D4灯灭
GPIO_ResetBits(GPIOC,GPIO_Pin_2);//D3灯亮
delay_ms(50);
GPIO_SetBits(GPIOC,GPIO_Pin_2);//D3灯灭
GPIO_ResetBits(GPIOC,GPIO_Pin_1);//D2灯亮
delay_ms(50);
GPIO_SetBits(GPIOC,GPIO_Pin_1);//D2灯灭
GPIO_ResetBits(GPIOC,GPIO_Pin_0);//D1灯亮
delay_ms(50);
GPIO_SetBits(GPIOC,GPIO_Pin_0);//D1灯灭
GPIO_ResetBits(GPIOC,GPIO_Pin_4);//D5灯亮
delay_ms(50);
GPIO_SetBits(GPIOC,GPIO_Pin_4);//D5灯灭
GPIO_ResetBits(GPIOC,GPIO_Pin_5);//D6灯亮
delay_ms(50);
GPIO_SetBits(GPIOC,GPIO_Pin_5);//D6灯灭
GPIO_ResetBits(GPIOC,GPIO_Pin_6);//D7灯亮
delay_ms(50);
GPIO_SetBits(GPIOC,GPIO_Pin_6);//D7灯灭
GPIO_ResetBits(GPIOC,GPIO_Pin_7);//D8灯亮
delay_ms(50);
GPIO_SetBits(GPIOC,GPIO_Pin_7);//D8灯灭
//跑马灯不亮白色光
GPIO_ResetBits(GPIOA,GPIO_Pin_1);//蓝色亮
delay_ms(100);
GPIO_SetBits(GPIOA,GPIO_Pin_1);//蓝色灭
GPIO_ResetBits(GPIOA,GPIO_Pin_2);//红色亮
delay_ms(100);
GPIO_SetBits(GPIOA,GPIO_Pin_2);//红色灭
GPIO_ResetBits(GPIOA,GPIO_Pin_3);//绿色亮
delay_ms(100);
GPIO_SetBits(GPIOA,GPIO_Pin_3);//绿色灭
GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2);//紫色灭
delay_ms(100);
GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2);//紫色亮
GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3);//青色亮
delay_ms(100);
GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3);//青色灭
GPIO_ResetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3);//黄色亮
delay_ms(100);
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3);//黄色灭
LED和跑马灯的作业放同一代码了
有点强迫症,之前的只转一圈不好看,无聊加了个for循环给LED灯
