* @file GPIO/IOToggle/main.c
* @author MCD Application Team
* @version V3.5.0
* @date 08-April-2011
* @brief Main program body.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
© COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void GPIO_INIT()
//GPIOB(数码管)初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//按键初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOC, &GPIO_InitStructure);
//微秒延时
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
//毫秒延时
void delay_ms(u32 n)
while(n--)
delay_us(1000);
* @brief Main program.
* @param None
* @retval None
void Mode1(int i){//S1按键次数
if(i>15){i=0;}
GPIO_ResetBits(GPIOB,GPIO_Pin_1);
GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
switch(i){
case 0 :
GPIO_SetBits(GPIOB,GPIO_Pin_1);
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8);
break;
case 1 :
GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
break;
case 2 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5);
break;
case 3 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5);
break;
case 4 :
GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5);
break;
case 5 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5);
break;
case 6 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5);
break;
case 7 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
break;
case 8 :
GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
break;
case 9 :
GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
break;
case 10 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8);
GPIO_SetBits(GPIOB,GPIO_Pin_15);
delay_ms(1);
GPIO_ResetBits(GPIOB,GPIO_Pin_15);
GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
break;
case 11 :
delay_ms(1);
delay_ms(1);
break;
case 12 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5);
delay_ms(1);
break;
case 13 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5);
delay_ms(1);
break;
case 14 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5);
delay_ms(1);
break;
case 15 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5);
delay_ms(1);
break;
void Mode2(int i){//S2按键次数
if(i>15){i=0;}
switch(i){
case 0 :
break;
case 1 :
break;
case 2 :
break;
case 3 :
break;
case 4 :
break;
case 5 :
break;
case 6 :
break;
case 7 :
break;
case 8 :
break;
case 9 :
break;
case 10 :
delay_ms(200);
delay_ms(200);
break;
case 11 :
delay_ms(200);
delay_ms(200);
break;
case 12 :
delay_ms(200);
delay_ms(200);
break;
case 13 :
delay_ms(200);
delay_ms(200);
break;
case 14 :
delay_ms(200);
delay_ms(200);
break;
case 15 :
delay_ms(200);
delay_ms(200);
break;
int main(void)
int i = 0;
int count1 = 0, count2 = 0;//设置两个按键次数参数
RCC_Configuration();
GPIO_INIT();
GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
while(1){
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))//S3键按下
{delay_ms(80);
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){i++;}} //S3键处于按下时,i+1
switch(i%2){ //i求余
case 0 : //i为偶数
{ if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))//S1键按下
{delay_ms(80);
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){count1++;}}//S1键处于按下时,count1+1
if(count1>15){count1=0;}//如果S1按键次数超过15次,count2归0
Mode1(count1);}//进入S1按键记数
break;
case 1 : //i为奇数
{ if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))//S2键按下
{delay_ms(80);
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){count2++;}}//S2键处于按下时,count2+1
if(count2>15){count2=0;}//如果S2按键次数超过15次,count2归0
Mode2(count2);}//进入S2按键记数
break;
新的代码把两个记数程序声明成两个函数模块,然后在main函数调用,看起来更加简洁。
同时也把S2键在按下次数为双位数时,数码管的动态扫描延时增加。
